Thanks Everyone, I guess this was a RTFM kind of issue because it is there in the Manual (if not the Spec sheet) I guess I should have pushed harder to get my Boss to approve the Keysight. Oh well, the Scope on it is still pretty decent. I'll just put this in my back pocket of experiences for more fuel to the "This is why you buy good quality instruments and not just the cheap ones" That 2.5V - 1/2 amplitude should really be spelled out in the datasheet. Keysight actually spells out the formula for the offset in their datasheet. (and has a 20Vpp generator)
It's never going to work though: Fans need amps to drive them, there's no way you can expect a signal generator to drive a fan directly.
I'm thinking he's working with a fan that has a dedicated PWM input for speed regulation, like most pc fans. The motor power is provided by a dedicated power input.
That is correct, The fan has a dedicated PWM control on it.
OP might get lucky and the 0->2.5V pulses are enough for the fan's controller logic to see
The spec sheet for the fan says it wants min 2.3V for V
H and I did try it, unfortunately no dice.
It's not an obvious solution, but if your fan circuit is not grounded at all (battery operated on your bench) then you can get your 0-5V signal by setting generator CH1 to your 5Vp-p square wave and CH2 to -2.5V offset. Then use appropriate connectors and use the output of CH2 as your "ground" and CH1 as the PWM input. Don't connect anything from ground or the BNC shells to the fan circuit. Don't do this if your fan is connected to anything other than a totally isolated, battery-powered simple circuit.
I think I'll just move on to using the PWM from my Raspberry Pi Pico instead of risking the horrible consequences if anything in that connection goes wrong :-) Or bring my Keysight in from home.
Not that the DS1104Z-S is a bad scope, but issues like this are why I prefer dedicated gear over all-in-one types.
Yeah I normally agree, but I don't have enough use for one to get a whole other instrument, this was just part of the "Playing around" stage of getting this fan up and working. and now I'm wishing I hadn't spend the extra $200 US on the one with the signal generator, because I'm not certain what I'm going to be able to use it for. most of what I deal with is PWM like what I'm doing here.
