@cncjerry thanks for the update. Hopefully this list will be helpful to others.
My SDG1025 arrived today, despite the rather long timescales for delivery suggested by the seller which was between 26th Jan and some time in Feb so I'm pleased.
I like the SDG1025 which I find very intuitive to use. I found most of the functions just by playing around. I was hoping for the frequency counter to have a higher resolution, but it seems to mostly have 6 digits after the decimal point, offering a resolution of 1Hz at 10Mhz. So I shan't be ditching my TF830 counter/timer which is 10 times better at 0.1Hz. Could be wrong as I'm still figuring the unit out. To access the frequency counter, you press Utility, 1/3, 2/3 and press counter.
The 10MHz ref is at the back and to enable it, you press Utility, 1/3, System, 1/2, and CLKSource. It would be nice if the display showed you which clock source it was using. It's a bit of a faff to go through the menus to check. My TF830 displays "Ext" on the LCD which I find helpful. I think I'll pop this into Siglent as a feature request.
Anyway, this isn't supposed to be a review of the SDG830 so the interesting bits as far as the 10MHz ref go are as follows:
The output of the BG7TBL works fine driving both my TF830 and the SDG1025 directly with no amplification, just a 50 ohm terminator on the end of the chain to stop those reflections
Just as a sanity check, I connected up the 10MHz to the TF830 and SDG1025 and generated a 10MHz sine wave which was fed back into the TF830. With a 10 second gate time and corresponding 0.1Hz resolution, the display was bang on the money (carry + 0.0000000Mhz) and rock solid so that's a good start.
Well after all this messing around with standards, for some reason I really feel the urge to drive my £1.00 quartz clock from the pound shop from the GPSDO. But that's another thread.
Thanks for reading and all those that have contributed
Steve
