Hello all,,, I picked up a TDS 540 for 85 bucks and it had 3 errors on the self test. I took it apart and washed the boards and did not see any damage on the PCB's. tested again and booted with out errors and I then replaced all the caps and it's working just fine.
My question is,, Should I go through the power supply and replace the rest of the caps? I haven't seen much about doing that.
Thanks for you time!!
