Products => Test Equipment => Topic started by: dadler on June 26, 2015, 09:17:27 pm
Hi all-
I have a DSA815-TG.
I also recently picked up the tekbox near field probes that Dave semi-reviewed in a mailbag segment:
http://www.tekbox.net/test-equipment/tbps01-emc-near-field-probes-tbwa2-wideband-amplifier (http://www.tekbox.net/test-equipment/tbps01-emc-near-field-probes-tbwa2-wideband-amplifier)
https://www.youtube.com/watch?v=CQgJmmn-eSE (https://www.youtube.com/watch?v=CQgJmmn-eSE)
I have the TBWA2/40db set with the 40db amplifier.
Is there any risk in connecting these directly up to (with or without the amplifier) the front-end of the DSA815?
I have a full-set of mini-circuits 2W attenuators, but would prefer to not use them unless necessary.
I ask because I've seen a few posts recently mentioning things like static electricity frying the front-end of SA's. The DSA815 has a blocking cap on the frontend, but I don't know if that ameliorates most of the risk in this context.
I also had one of the near field probes hooked up through the 40db amplifier, and I was trying to demodulate FM radio into the headphone jack (just for fun). The DSA818 would sporadically report "412 DA overrange due to volume adjustment in FM.". I have no idea what this error means, and I couldn't find any references to it on the web. Hope it doesn't mean I broke something.
I know essentially nothing about RF and bought the DSA815 mainly as a learning tool, so be gentle (if possible).
Thanks,
Dustin
The maximum input level is noted just underneath the RF input connector on the DSA815. There it states that the maximum input level is +20dBm. You do not want to exceed that specification.
Sure, that's the max power level. It also states max 50v DC. I'm going to assume the power rating is for all power/frequencies, not just those measured by the SA. Without a power meter I don't see how I can truly know if I am overdriving the input of the SA.
Aurora posted in another thread recently that he felt static electricity could fry the front-end of SAs.
I'm not so sure about this, so I started this thread.
