Author Topic: UNI-T UTD2042C possible Hack?? Serial Commands!??  (Read 2565 times)
Offline vandersonpcTopic starter
« on: January 29, 2014, 10:19:19 am »
Hi Guys,
I teardown My UNI-TREND UTD2042C 40Mhz scope and found it uses the same board than UTD2102, a 100MHz model from the same manufacturer. I tried to apply the same commands described on the Rigol DS1052 hack, but it didn't work. Looks like the Uni-T units are not compatible with the IEE488 commands. I tried to install the UTD2102 firmware, but the unit refuses to get it and show a message that firmware is not compatible with the current unit.
So, have you guys any experience hacking this UNI-T units? Or know which serial protocol it uses?Or how to change the model number through USB or RS232!?
Please, any help you very much appreciated!
Many Thanks!
Cheers, Vanderson
Offline Rerouter
Re: UNI-T UTD2042C possible Hack?? Serial Commands!??
« Reply #1 on: January 29, 2014, 10:42:25 am »
as its a different unit and very likely to be a different firmware variant to the rigol your likely going to need to start out at square one with finding out what the differences are between the 2 firmwares,
« Reply #2 on: January 29, 2014, 10:57:13 am »
Yes, my first thought was that the UNI-T units were compatible with IEE488 as the Rigol Units are. Even Tektronics, Agilent, etc. which have a programming manual for they units.
My UNI-T UTD2042 uses the same MCU than Rigol units (Analog Devices ADSP-BF531) and the same Altera Cyclone FPGA, but I know the Rigol firmware is not compatible with my unit.
Cheers, Vanderson
