Author Topic: Scopes with logarithmic timescale  (Read 1043 times)
Online eTobeyTopic starter
  • Virtual Features for the SDS800XHD -> My website
    • Virtual feature script
« on: December 23, 2024, 05:59:28 pm »
Which scopes have a logarithmic timescale that one can afford ( ~2500€)? I guess there will only be old ones that fit into this category? Maybe there are some USB scopes that could be hacked to use its data and plot it via external program?
"Sometimes, after talking with a person, you want to pet a dog, wave at a monkey, and take off your hat to an elephant." (Maxim Gorki)
My current top list of issues on the SDS800X HD:
https://www.eevblog.com/forum/testgear/sds800x-hd-bug-reports-firmware/msg5766323/#msg5766323
Online TheoB
Re: Scopes with logarithmic timescale
« Reply #1 on: December 23, 2024, 07:45:24 pm »
I've seen your plots for the square wave problem you have. That shows you already are able to make them. It's a very special display mode that is easy to implement by plotting with semilogx. You only have to tell what is time zero. It can be the trigger moment or a small time before the trigger. It's that what you need?
« Reply #2 on: December 23, 2024, 10:41:38 pm »
Yes, but its a bit of work. And i like to work less ;-)
Online TheoB
« Reply #3 on: December 24, 2024, 09:22:44 am »
Example of how you can do that with python. I tried it with a Rigol DHO802 but I think it should work with any scope supporting SCPI commands|:
import pyvisa
import matplotlib.pyplot as plt
import numpy as np
rm = pyvisa.ResourceManager()
my_instrument = rm.open_resource('TCPIP::192.168.1.8::INSTR')
print(my_instrument.query('*IDN?'))
my_instrument.write(":WAV:SOURCE CHAN1")
my_instrument.write(":WAV:MODE RAW")
my_instrument.write(":WAV:FORM WORD")
my_instrument.write(":STOP")
# get the data from the scope
data = {}
data["yincr"] = float(my_instrument.query(":WAVeform:YINCrement?"))
data["yorg"] = float(my_instrument.query(":WAVeform:YORIGIN?"))
data["yref"] = float(my_instrument.query(":WAVeform:YREFERENCE?"))
data["xincr"] = float(my_instrument.query(":WAVeform:XINCrement?"))
data["xorg"] = float(my_instrument.query(":WAVeform:XORIGIN?"))
data["mdepth"] = float(my_instrument.query(":ACQuire:MDEPth?"))
data["sr"] = float(my_instrument.query(":ACQuire:SRATe?"))
data["y"] = my_instrument.query_binary_values(":WAVeform:data?", datatype='H', is_big_endian=False, container=np.array)
data["y"] = (data["y"] - data["yref"] - data["yorg"]) * data["yincr"]
# Reconstruct the x-axis
N = len(data["y"])
data["x"] = np.linspace(0, N * data["xincr"], N)
data["x"] = data["x"] + data["xorg"]
fig, ax = plt.subplots(3, figsize=(10, 12))
#labels
ax[0].set_xlabel("time (s)")
ax[1].set_xlabel("logx from triggerpoint")
ax[2].set_xlabel("symlog")
ax[0].set_ylabel("V")
ax[1].set_ylabel("V")
ax[2].set_ylabel("V")
ax[0].plot(data["x"], data["y"], "-")
ax[0].grid(True)
ax[1].semilogx(data["x"], data["y"], "g-")
ax[1].grid(True)
ax[2].plot(data["x"], data["y"], "r-")
# threshold should be 10e-9 not 2e-9 for nicer plot
linthreshold = 10 ** int(np.log10(data["xincr"]))
ax[2].set_xscale('symlog', linthresh=linthreshold)
ax[2].grid(True)
plt.show()
my_instrument.write(":RUN")
« Last Edit: December 24, 2024, 09:28:58 am by TheoB »
Offline Andreas
« Reply #4 on: December 24, 2024, 10:39:54 am »
Hello,
My PicoScope (USB-Ocilloscope) can do this directly:
Define a math function log(T) (add 1 ns to avoid log(0)) and define Range from -9 to -1 for 1ns to 100 ms.
use the math channel as x-axis
thats all.
Upper screen shows Channel A (log Time)
lower screen shows Channel A (Time)
the question is:
- what bandwith and time resolution do you need
- what amplitude resolution do you need 8/10/12/14/16 Bits
with best regards
Andreas
« Last Edit: December 24, 2024, 10:51:07 am by Andreas »
« Reply #5 on: December 28, 2024, 01:03:16 pm »
Thats nice. Could you measure the time it takes to get the data from the scope?
That is awesome, i was already thinking about these scopes, since i find the GUI of the SDS800X HD so bad, i thought when having to use a PC/keyboard, i can switch to a laptop with picoscope alltogether.
Does every model has this ability?
Offline Andreas
« Reply #6 on: December 28, 2024, 04:01:18 pm »
Hello,
The math functions are part of the software on PC.
So in principle every model has this ability.
The low end models (PS2xxxA) may not have enough memory at higher sample frequencies for longer aquisitions.
with best regards
Andreas
Online TheoB
« Reply #7 on: December 28, 2024, 04:10:07 pm »
I calculatedmeasured roughly 53Mbps when using the pyvisa library. My scope needs two bytes/point (12 bits resolution). That equates to 53M/16=331k points/second.
« Last Edit: December 29, 2024, 04:26:59 pm by TheoB »
« Reply #8 on: December 29, 2024, 12:53:15 pm »
I calculated roughly 53Mbps ....
You calculated? In another script?
I would have just measured the time it takes in your script. No calculations needed, and no errors would be introduced.
Online TheoB
« Reply #9 on: December 29, 2024, 04:27:54 pm »
That should indeed be measured :-). Just a dump of a large dataset, me counting the seconds.
« Reply #10 on: December 29, 2024, 06:06:41 pm »
Were you counting the seconds, or measuring the seconds with a tool?  ;D
If you made multiple measurements: did you use median or mean average?  ;D :-DD
Online TheoB
« Reply #11 on: December 29, 2024, 06:49:49 pm »
O dear. Even that was not correct. My computer was counting the seconds and I was just observing the start and end time. Subtracting them from each-other. Both observations have an uncorrelated random error of 1 second so it was 15 seconds +/-1 I guess.
Nerd level is rather high here  ^-^
« Reply #12 on: December 29, 2024, 07:26:17 pm »
Terms and measurements... meaningless without a minimum level of precision.  ;)
Online ebastler
« Reply #13 on: December 30, 2024, 12:50:07 pm »
The same goes for bug reports, by the way. :P
The following users thanked this post: Grandchuck, mawyatt
« Reply #14 on: December 30, 2024, 04:13:48 pm »
I used some precise terms in the past. It didnt work in quite a few cases, so naturally you would do less things, if they dont lead to any results...
