Yes, I have tried it. It doesn't work.
Doesn't work how exactly? Is the time remaining not affected by RTC setting?
Are the trials individually enableable or all at once?
Agilent is hack-proof.
Nothing is hack proof - just a matter of effort required
Internal trial enabling without licenses has to provide some additional opportunities.
But I hope that in say 5 years the 3V button cell will get discharged and the clock will stop.
Bear in mind it's possible the battery also maintains RAM for cal and possibly license data. It would be easy enough to establish this - see what devices on the board have battery power, and if the RTC is a seperate identifiable I2C device , look up how much RAM it has, and scope what gets read at startup.
However disabling the RTC crystal might be worth a try. If the software somehow detects this, an enhancement could be to only disable the RTC when power is off, so it lasts 30 power-on days.
Bear in mind that the PSU has soft on/off and there may be a standby supply running things when power is apparently off.
