Author Topic: DSOX2000 and 3000 series - licence , have anyone tried to hack that scope ?  (Read 675144 times)
Offline tv84
  • Country: pt
@arlvaljr
Please show a printscreen of your license list in the boot screen, with just D3000BDLA and WAVEGEN enabled.
Offline arlvaljr
  • Country: br
@arlvaljr
If I change my .lnk, I will just add -l SCPIPS like bellow:
90#"\Program Files\infiniiVision\infiniivisionLauncher.exe" -l D3000BDLA -l SCPIPS -l WAVEGEN
The other licences that apears on the screen are native from my scope, it’s not necessary  to add on my .lnk, they come anyway.
Follows the printscreen
The following users thanked this post: tv84
Offline Cretone
Hi all,
Been following this thread for years and I am about to embark on hacking my 4022a.  It currently has FW version 4.08.2016071800.  I have so far verified that I can telnet into the scope no problem.  As I see it, the following steps should get me where I want to be:
  • Download PhillyFlyers's FW 7.31.2020012900_patched to FAT32 USB(done)
  • Create infiniivision.txt file on FAT32 USB (done)
  • Edit infiniivision.txt file to: 80#"\Program Files\infiniiVision\infiniivisionLauncher.exe" -l D4000BDLA -l WAVEGEN (done)
  • Install 7.31.2020012900_patched to scope via FW update procedure
  • Telnet back into scope
  • Kill infiniivisionLauncher.exe
  • Copy infiniivision.txt to Secure\Startup folder (this is where I'm stuck
  • Rename infiniivision.txt to infiniivision.lnk
  • Reboot scope and verify installed options
So, a few questions:
How are you guys copying files without a protocol to transfer such as ftp?
Do I really need to kill infiniivisionLauncher.exe before copying?
Does my .lnk file look correct?  The D4000BDLA is the current 4000 series bundle, so I figured I would go with that.
Many thanks to all contributing to this thread!  Amazing.
Offline adranp
:Cretone
You don't need ftp. You are copying from /usb (on the scope) within telnet console. The usb stick is connected to the scope when you need to copy.
Offline Cretone
:adranp
Thank you for that.  Did not realize that I had access to the usb drive from telnet.  Feeling a little stupid, of course!
However, I am very happy to report that I have successfully "enabled" my 4022a and have all applications operating, although waveform gen was the one I was really interested in.
Note, I followed the steps above in my previous post except that I did not bother to kill infiniivision.exe.
I will post below the steps I followed for posterity and for anyone else that comes along looking to enable a 4000 series scope:
  • Connect scope to LAN and navigate to Utilities/IO Menu.  Note the scope's Hostname.  You will need it later.
  • Download PhillyFlyers's 4000 series patched firmware:  7.31.2020012900_patched to a FAT32 USB (see post #2448 on page 98).
  • On a PC: Create infiniivision.txt file on FAT32 USB drive.
  • Edit infiniivision.txt file to have the following line and no extra spaces etc:
  • Plug your USB into one of the front USB ports on the scope.
  • Install 7.31.2020012900_patched to scope via std firmware update procedure.  Scope should provide progress updates and reboot on its own.
  • With both scope and PC connected to same LAN, telnet into scope from your PC.  I use Putty.  Create a telnet session using Hostname from above.  Port 23 must be used.  After opening a session, you should get a login window.  Use login:infiniivision and  P/W: skywalker1977.  Note, the telnet session has to be opened in timely fashion after scope bootup.  Basically, before the scopes gets to the main screen.
  • Now that you have a telnet session you can use standard CMD commands to complete the remaining tasks. First, copy infiniivision.txt from USB to Secure\Startup folder on scope.
  • Rename original infiniivision.lnk in the Secure\Startup folder to infiniivision.bak for safe keeping in case of trouble.
  • Rename your freshly copied Secure\Startup\infiniivision.txt to Secure\Startup\infiniivision.lnk
  • Reboot scope and enjoy your new applications.  The above procedure enabled ALL apps on my scope.
Much gratitiude to PhillyFlyers, arlvaljr and the community!
« Last Edit: June 01, 2020, 12:58:14 pm by Cretone »
Offline yingziwin
  • Country: cn
Hi!
Does anybody know where can I find the DSOX2K 2.35  firmware? The keystone website only lets you download the latest one (2.50).And I can't download from this thread.My e-mail address is 522384387@qq.com.
Thanks!
Offline tv84
  • Country: pt
Hi!
Thanks!
http://s000.tinyupload.com/?file_id=80577850131121425419
Offline Pilatus
That work  :-- :-+, Thank you a lot  :clap: :clap: :clap: i go to sleep 2 jours before go to my job.
I have only this message, i dont Know why, but all seem work
If you or anyone had the following message:
"System concerns detected:
OS version is not correct. Please reload system firmware"
... then you should try another set of infiniivision.lnk file parameters. The scope likely had issue with a parameter mis-match
What worked for me (2000 series), and cleared the warning was:
80#infiniivisionLauncher.exe -l DIS -l MSO --perf -l BW20 -l SCPIPS -l CABLE -l VID
I also tried the following one successfully:
108#infiniivisionLauncher.exe -l DIS -l MSO --perf -l MEMUP -l BW20 -l ADVMATH -l SCPIPS -l CABLE -l VID -l EMBD
This one, for instance, created the OS mismatch nag/warning (I believe it was meant for the 3000A series):
160#\Secure\infiniiVision\infiniivisionLauncher.exe -l DIS -l MSO --perf -l MEMUP -l SCPIPS -l CABLE -l SGMC -l FLEXC -l TOM -l BW20 -l ADVMATH -l EMBD -l EDK -l VID
I used the USB memory stick option. Worked a treat.
« Last Edit: June 06, 2020, 01:51:48 pm by Pilatus »
Offline Pilatus
After upgrading my 2000A scope and plugging in a USB keyboard ... it works! Now I can select drop-downs and enter characters for labels and such.
Wish there was mouse support as well, or at least "real" Left/Right keyboard cursor support. Still.... happy camper :clap:
The following users thanked this post: Mr. Scram
Offline albertr
Hey, thanks! I ended up getting a network card and following the steps your described. Basically just get the password from the password generator, telnet, and change the .lnk.
Thanks!
stafil: So your MSOX3104T is running firmware 7.31 and you still can telnet into it???
I had very old 4.xx firmware on my 3000T series scope originally (hasn't been updated since 2015) and telnet was working fine. However, after upgrading to firmware 7.31 (from keysight, not patched one from PhillyFlyers user) I cannot telnet into it anymore. Telnet port becomes available for just a few seconds before the main GUI app starts, but even this is not long enough for me to telnet into it. I've tried to use telnet_dso.py python script posted on this thread and even wrote my own python script, but still cannot get into it. Does anyone have the same issue with newer firmware and telnet? I'm hesitant with trying any mods if I cannot telnet into the scope to revert or fix it.
Any suggestions are much appreciated!
-albertr
« Last Edit: June 20, 2020, 07:09:11 pm by albertr »
Offline pepperoni7
@stafil: So your MSOX3104T is running firmware 7.31 and you still telnet into it?
I had very old 4.xx firmware on my 3000T series scope and telnet was working fine. However, after upgrading to firmware 7.31 I cannot telnet into it anymore. Telnet port becomes available for a few seconds before the main GUI app starts, but even this is not long enough for me to telnet into it. I've tried to use telnet_dso.py python script posted on this thread and even wrote my own python script, but still cannot get it. Does anyone have the same issue with newer firmware? I'm hesitant on trying to modify options if I cannot telnet into the scope to revert it.
-albertr
You should use "optimized" FW, then Telnet is no problem:
https://www.eevblog.com/forum/testgear/dsox2000-and-3000-series-licence-have-anyone-tried-to-hack-that-scope/msg2945740/#msg2945740
Offline albertr
So, are you saying that PhillyFlyers made some hacks in this firmware to specifically "fix" telnet server? I think I read all posts on this thread (took a few days), but don't recall anyone mentioning that...
PhillyFlyers, can you confirm whether your 7.31 firmware includes "fix" for the telnet availability issue? I'm eager to try it, but I need to make sure that telnet would work when I need it. Right now, on a stock 7.31 firmware for 3000T from Keysight website (ver. 07.31.2020012842) telnet gets enabled for just a few seconds which is not long enough for me to get in. I'm using a stock LAN/VGA card on MSOX3034T if it matters. Never had problems with telnet on the old 4.xx firmware running on this scope before I upgraded to 7.31.
BTW, big thanks to everybody for sharing the information!
-albertr
« Last Edit: June 20, 2020, 06:05:34 pm by albertr »
Offline pepperoni7
I'm talking about my own experience with both the FW versions.
With PhillyFlyers' one you can Telnet in with no problem and (I suppose alsmost) no timeout restrictions.
At least I  could not experience a timeout for Telnet session.
Offline tv84
  • Country: pt
The only thing the hack does is to fool the SEALED_STATE flag. If it happens to activate the telnet it's simply a byproduct from that setting.
Offline albertr
Yes, I'm happy to confirm that PhillyFlyers's modified firmware fixed the telnet issue on my scope!
Now it's time to liberate some options...
Thank you PhillyFlyers and other helpful members of this forum!
-albertr
« Last Edit: June 20, 2020, 05:31:24 pm by albertr »
Offline albertr
The scope was liberated. Big thanks to everybody who made it happen!
-albertr
