Author Topic: DSOX2000 and 3000 series - licence , have anyone tried to hack that scope ?  (Read 717212 times)
mlloyd1 and 2 Guests are viewing this topic.
Online Bud
Re: DSOX2000 and 3000 series - licence , have anyone tried to hack that scope ?
« Reply #2575 on: November 16, 2020, 03:36:05 pm »
I discovered how to change the boot logo, but unfortunately I wasn't able to save the old firmware boot screen. It isn't avaiable in any firmware update I found. I know of one scope that has the old firmware here, but it will be a lot of work for just one screen :\
Is that the one you want?
https://www.eevblog.com/forum/testgear/agilentkeysight-dsox-20003000-custome-boot-screens/msg909912/#msg909912
Offline tabajaralabs
  • Country: br
    • Tabajara Labs
« Reply #2576 on: November 16, 2020, 05:24:27 pm »
Nop...this one!
[attach=1]
Online Bud
« Reply #2577 on: November 16, 2020, 05:40:02 pm »
I see. Great image, let us know if you find it.
If you have Telnet access to the scope that has it, you could extract the compiled splashimage.bin file and implant it on the new scope directly. I believe the .bin file is stored in \secure\infiniivision folder.
Offline uski
« Reply #2578 on: November 16, 2020, 05:45:18 pm »
Hi! Any hack for the MSO4000A series? Thanks
Offline Dwaine
« Reply #2579 on: November 16, 2020, 10:31:54 pm »
The latest 2000X firmware is 2.60 in KeySight web site.
Also the 3000X firmware.
Does anyone know what changes are in version 2.60?
Release Date   Version   Version Description
2020-10-30   2.60   This is the firmware for the 2000 X-Series oscilloscopes.
  • Country: br
    • Tabajara Labs
« Reply #2580 on: November 16, 2020, 11:22:20 pm »
They are listed on ReadMe: Corrections on Help for foreign languages
The following users thanked this post: Dwaine
Offline wp_wp
  • Country: cn
« Reply #2581 on: November 17, 2020, 05:42:21 am »
I have helped my friend to hack MSOX4000A.
  • Country: br
    • Tabajara Labs
« Reply #2582 on: November 18, 2020, 03:12:15 pm »
Found it
  • Country: br
    • Tabajara Labs
« Reply #2583 on: November 19, 2020, 04:14:18 am »
How did I extracted the screen?
The file \secure\infiniivision\splashImage.bin is a planar BGR (not rgb, it is inverted) file with a 32 bytes header
Here it is, how I extracted the screen from a "virgin" scope:
https://tabajara-labs.blogspot.com/2020/11/salvando-tela-de-boot-do-osciloscopio.html
The following users thanked this post: Mr. Scram
Offline phatpaul
« Reply #2584 on: November 20, 2020, 10:05:06 pm »
I followed the USB-only guides in posts #2560 and #2562 on my DSOX3014T (with purchased 200MHz upgrade, no Eth jack).
The 3000XSeriesT.7.31.2020012842_patched.ksx installed OK, but the next step to install v241_link_install.cab doesn't seem to work.  I just get error message on the scope screen: "Error: The file did not load correctly."
I tried the process twice with the same result.  I also tried a couple different link strings from this forum.
Ideas?
Offline Dwaine
« Reply #2585 on: November 21, 2020, 03:13:33 am »
Ummm.. That's it..  I guess I'll stick to 2.50
Offline Kibabalu
« Reply #2586 on: November 21, 2020, 05:28:54 am »
somewhat more:
Enhancements for 3000A
- New SCPI command to start the probe degauss operation for the N7026A and N2893A probes.
Enhancements for both 2000A and 3000A
- Completed software and built-in online help localization.
- New SCPI commands for clearing persistence data from the display and querying the run state.
Bug Fixes for both 2000A and 3000A
- Fixed network print issue where a valid printer address format was not accepted.
Offline Hydrawerk
« Reply #2587 on: November 22, 2020, 12:02:22 am »
Well, both 2000A and 3000A scopes will be 10 years old in February 2021. Is there a successor coming?
Online Bud
« Reply #2588 on: November 25, 2020, 08:29:29 pm »
If I remember correctly the password attempt always fails the first time. You may have to try twice before it'll let you in using Telnet.
I've seen this more then once in this thread, so here is the explanation for all of you:  this is a quirk of the Putty software that people often use for telnet connectivity.  It spits some garbage from the buffer first time you use it, so password entry always fails the first time. Use built-in Telnet utility in Windows and your authentication will be fine from the first try.
Edit: alternatively, if you still want to use Putty, after connecting to the scope press Enter, then proceed with entering the credentials.
« Last Edit: November 25, 2020, 10:30:10 pm by Bud »
Offline Mr. Scram
  • Display aficionado
« Reply #2589 on: November 25, 2020, 08:34:10 pm »
I remember that question being asked many years back.
Offline tv84
  • Country: pt
« Reply #2590 on: November 25, 2020, 08:37:56 pm »
Did KS include a time bomb in the devices?
Online Bud
« Reply #2591 on: November 25, 2020, 10:31:12 pm »
To a certain extent, possibly. There are digital certificates there that have expiry.
Online MarkL
« Reply #2592 on: November 25, 2020, 10:40:59 pm »
I think it's pretty clear that the 3000T series is the replacement for the 3000A.  If I recall correctly, at one point the A and T even had the same price for the same combinations of channels, MSO option, and bandwidth.  Looking at it now, the T series is slightly cheaper and also has more decode and other licensable options.
The 3000A series can still be found by searching for it, but it does not appear on the main scope web page.  Amongst others, it now shows the 3000T along with the 2000A series
I'm not sure why they're continuing to sell the 3000A series.  It hasn't had any significant new features added to it for years and only a minor bug fix here and there.
I can only speak for the 3000A because I have one:  The purchased licenses do not expire.
Online Bud
« Reply #2593 on: November 25, 2020, 11:37:31 pm »
I do not mean licences, i mean digital x509 certificates. There are a few Root ones from the Public Certificate Authorities and a few issued to Keysight , at least one for code signing.
Offline dorofteius
« Reply #2594 on: December 02, 2020, 05:02:41 pm »
Thank you all for the knowledge.
Another successful hacked DSO-x-2012A  using USB only .
The trick is to have files in the main directory not in any sub folders. It fails every time when files are not in the main directory.
I followed these instructions from page 89  written by scribble - thank you man - much easier to have it all in one place.
Download Phillyflier's patched firmware from post #2167 on page 87
Download Luminax's license patch from post #1529 on page 62
Extract license patch, open cmd window (if using MS Windows), navigate to license patch folder and rename infiniivision.lnk to .txt
Edit infiniivision.txt and replace text in the file with Odessa's modification from post#2197 on page 88
80#infiniivisionLauncher.exe -l DIS -l MSO --perf -l BW20 -l SCPIPS -l CABLE -l VID
Save and rename file back to .lnk
Copy firmware file (rename from .ksx to .cab if current scope fireware is older than v2.41) to FAT32 formatted USB drive
Copy licence files (2x .cab files and .lnk file) to same USB drive
Now go to your scope, turn on and plug in USB drive to front USB port
Press [Utility] > File Explorer, select the firmware file (3000XSeries.02.50.2019022736_patched.cab); then, press Load File, wait for scope to load and reboot.
Check firmware has updated to v2.5, if successful continue
Press [Utility] > File Explorer, select v241_link_install.cab file; then, press Load File, wait for scope to load and reboot.
Today I received my 2002A from Ebay at 490 E.
I followed this instruction, and it worked perfectly. 5 minutes later I had a unlocked scope.
Thanks to all for the good work.
Offline Greybeard
« Reply #2595 on: December 04, 2020, 07:07:40 pm »
Electrolytic caps in the power supplies...?   >:D
« Last Edit: December 04, 2020, 07:12:44 pm by Greybeard »
Offline msuthar
  • Country: in
« Reply #2596 on: December 05, 2020, 05:12:33 pm »
  DSO-X 2004A  after updating  Version 2.60   port 23 for telnet is not possible. Port scanner do not find port 23 open for telnet.
  There is one port open which is 21 and if it is telnet then shows  below image:[attachimg=1]
Online PA0PBZ
« Reply #2597 on: December 05, 2020, 07:07:54 pm »
Port 21 is normally used for FTP, give it the ls command and see what happens
Offline mshaban
  • Country: eg
« Reply #2598 on: December 15, 2020, 01:47:47 pm »
thank you for your post, i need to try your steps to my DSOX2014a model withe the same proplem. the firmware available on Firmware for Keysight is ver 2.6, i am not sure it will be work or no, ver 2.35 no longer available, and dont know if it can be found in other site
Offline markus354
« Reply #2599 on: December 15, 2020, 06:39:47 pm »
There was someone before to downgrade the scope to 2.35
Try to find I'm sure there is a way.
If I find it I will send you a link.
