Author Topic: DSOX2000 and 3000 series - licence , have anyone tried to hack that scope ?  (Read 1120341 times)
Offline TK
I did it, I did it !!! :phew:
Many thanks to everyone, especially PhillyFlyers and his team! :-+
The most recent firmware they patched works as it should! 8)
which .lnk configuration did you end up using?  You can add BW35 to enable 350MHz option
EDIT: 350MHz option requires the HW mod in addition to the SW hack
« Last Edit: August 10, 2021, 02:57:03 pm by TK »
Offline TheSteve
  • Living the Dream
He was adding it before but it will never work as his scope is limited to 200 MHz without a hardware mod.
VE7FM
Offline TK
Yes, you are right...  350MHz needs the hw mod
Offline Volchenok82
  • Country: ru
  • Cats are everywhere ...
I used this set of parameters:
90#infiniiVisionLauncher.exe -l D3000BDLB -l BW35 -l SCPIPS -l SEC -l MSO -l MEMUP -l WAVEGEN
But as you correctly noted, it did not work, because there is a hardware limitation in the bandwidth of this model!  If someone wrote here that he managed to programmatically increase the bandwidth from 200 to 350 or even up to 500 MHz - do not believe ...
 :popcorn:
« Last Edit: August 10, 2021, 06:00:18 pm by Volchenok82 »
Offline wp_wp
  • Country: cn
With HW mod,you can hack MSOX3024T to 500MHz。
Offline TheSteve
  • Living the Dream
Or 1 GHz, or even 1.5 GHz :)
https://www.eevblog.com/forum/testgear/keysight-3000t-scope-1-ghz-hardware-upgrade-mod/
500 MHz is much less work though.
VE7FM
The following users thanked this post: wp_wp
Offline Volchenok82
  • Country: ru
Thanks for the offer!   :P
I saw post  #1013 how this can be done, I will think about it in the future - I am not yet mature enough to open it and re-solder something there!   :-/O
Offline Volchenok82
  • Country: ru
« Last Edit: August 12, 2021, 06:27:56 pm by Volchenok82 »
Offline lzqing
  • Country: cn
I am try to write serial number to my DSOX2022A, when i fix it from corrupted NAND flash ,but now the serial number is Unset status;
I plan to try leaked SecureDataTool , get error below , anybody has old files backup and could you share me 'Agilent.Cdf.Core.Kernel.dll'. I think FW2.0 or 1.10 include this file.
\usb> \usb\AgilentConfidential_SecureDataTool_Client.exe Get-SerialNumber -ResultFile "\usb\GetSerialNumberResult.txt" -ErrorFile "\usb\GetSerialNumberErrorFile.txt"
Caption: AgilentConfidential_SecureDataTool_Client.exe
Title  : Error
Text   : An unexpected error has occurred in AgilentConfidential_SecureDataTool_Client.exe.
Select Quit and then restart this program, or select Details for more information.
Can't find PInvoke DLL 'Agilent.Cdf.Core.Kernel.dll'.
Details: AgilentConfidential_SecureDataTool_Client.exe
MissingMethodException
   at Agilent.Cdf.Api.Security.P500SecureStream.get_Length()
   at eh.aa(SecureStreamId A_0, ci A_1)
   at eh.p()
   at Agilent.Cdf.Api.Security.SecureStorage.ReadCommonArea()
   at Agilent.Cdf.Tools.SecureDataTool.GetSerialNumberCommand.BeginProcessing()
   at b2.a.p(b2 A_0)
   at b2.a.n(IEnumerable`1 A_0, b A_1)
   at b2.b.e(a A_0, IEnumerable`1 A_1)
   at b2.h(IEnumerable`1 A_0)
   at g2.a(String[] A_0)
Offline lzqing
  • Country: cn
No,should be Agilent.Cdf.Core.Kernel.dll 。
Offline wp_wp
  • Country: cn
Have you tested?
I tested.
With Agilent.Cdf.Api.dll,you can not modify serial number and model number.
You must have Agilent.Cdf.Core.Kernel.dll also.
Offline dagolard
Hi all.
I´m not the big hacker, so I hope you forgive me my dumb question.
I have a MSO-X 2014A with blackscreen and want to find out, it´s the NAND Error or something else. If NAND, I want to send it in for free repair.
- installed TERA TERM
- Connected serial PC port to the PCB with settings 115200/8/0/1
- switched on the scope.
Result - see picture
What I´m doing wrong?
Offline PlainName
  • Country: va
Should that be 115200/8/N/1 ?
Offline dagolard
You are right. It is 8/N/1. Sorry.
Offline PlainName
  • Country: va
No problem. That kind of thing is easy (for others) to spot since we've all done it enough to recognise it quickly :)
Offline dagolard
So - except of the wrong term any ideas?
Offline Bud
Try a different terminal software.
Offline Hexley
Did you use a logic-level serial adapter? The scope has 3V3 signals, so a standard serial port is not compatible.
Offline dagolard
No, I didn´t. :(
So I have to get one...
Offline dagolard
Offline Hexley
Or this https://www.amazon.com/DSD-TECH-SH-U09C5-Converter-Support/dp/B07WX2DSVB/ if you set the jumper to 3.3V you should be OK.
Offline TheSteve
  • Living the Dream
If you also connected the TX line from the PC to the scope then you tortured the processor UART a little - but it likely survived just fine.
VE7FM
Offline dagolard
I hope I didn't destroy anything...
Offline dagolard
Ready for weekend...
Offline dagolard
Okay, that´s the result I get....
U-Boot 2010.03 (Oct 18 2011 - 14:28:06)Agilent P500
CPU:   SPEAr600
DRAM:  128 MiB
Flash: 512 KiB
NAND:  fsmc-ecc1 128 MiB
In:    serial
Out:   serial
Err:   serial
SerNum:serial number not programmed
Chip:  BD Board Rev: 4
Net:   smsc
Press space to stop autoboot:  0
## Booting kernel from Legacy Image at f8050000 ...
   Image Name:   PBOOT
   Created:      2011-08-24  22:35:34 UTC
   Image Type:   ARM Linux Kernel Image (gzip compressed)
   Data Size:    36045 Bytes = 35.2 KiB
   Load Address: 00000000
   Entry Point:  00000000
   Uncompressing Kernel Image ... OK
Starting kernel ...
Debug serial initialized ........OK
Microsoft Windows CE Bootloader Common Library Version 1.4 Built Aug 24 2011 15:15:48
Microsoft Windows CE 6.0 Ethernet Bootloader for the Agilent P500 board
Adaptation performed by Agilent Technologies (c) 2008
System ready!
Preparing for download...
 Loading image 1 from memory at 0xD0600000
O
BL_IMAGE_TYPE_BIN
X
XXXXXOOOOXXOOOOOOOOXOXOOOOOOOOXOOXOXOOOOERROR: Checksum failure (expected=0x167CF58  computed=0x167D64E)
****** Checksum failure on record 13, ABORT!!! ******
Completed file(s):
  • : Address=0x80361000  Length=0x13064E8  Name="" Target=RAM
 Loading image 1 failed, trying next one
 Loading image 2 from memory at 0xD1600000
BL_IMAGE_TYPE_UNKNOWN
 Loading image 2 failed, trying next one
 All images failed
Press r to reset
NAND or no NAND Failure?
