Author Topic: DSOX2000 and 3000 series - licence , have anyone tried to hack that scope ?  (Read 1674641 times)
0 Members and 23 Guests are viewing this topic.
Offline ShQ
  • nonplussed
Glad at least spearload works!
That's odd, U-Boot should drop into a prompt automatically if invoked through spearload. What firmware version did you take the U-Boot and DDR image from?
I verified the setup to at least work on files from version 2.65 for me.
The following users thanked this post: onesystem
Offline onesystem
I used them from 2.66 and also 2.20 (tried both). spearload loaded them in less then a second - that's normal speed, correct?
Offline derZockerMP
Hello, has anyone the hacked firmware and workflow for installation to an DSO-X 3024A with firmware 2.36 on it. Is it possible to upgrade it too?
A link to a post where it is already described would be also nice. But didn´t found it yet.
Thanks in advants.
Offline derZockerMP
I think i found somthing. But I need the original version 2.41 to update it first. Did anyone has this firmware and could send me please?
Offline PioB
The following users thanked this post: derZockerMP
Offline onesystem
This is a step-by-step of everything that I did with oscilloscope to revive it. I am in need of some smart people here. Please help!
Oscilloscope model: DSOX2024A
Bought it on eBay with a note that its power supply was blown. It sure was blown, I replaced it with meanwell PSU - so that was handled.
While connecting to TTL header I noticed that whoever owned it before did solder work on it - one of the front end metal covers is missing (signs of resoldering are visible on each of the metal covers of all channels, with one missing). I tried to get more data from seller - they are liquidator aquisition place - have no data on where it came from or who worked on it.
Current SW version - unknown, but based on teraterm log, it is probably 2.66 or some other version that was bloated with additional files - I do not rule out that someone played with sofware since they knew what to do with hardware.
Here is what terraterm shows me if I turn on oscilloscope as is, without trying to do anything:
U-Boot 2010.03 (May 18 2017 - 11:28:22)Agilent P500
CPU:   SPEAr600
DRAM:  128 MiB
Flash: 512 KiB
NAND:  internal ecc 128 MiB
Debug serial initialized ........OK
RTC: 2022-2-8   1:40:11.70 UTC
Microsoft Windows CE Bootloader Common Library Version 1.4 Built Oct 29 2015 01:
39:04
Microsoft Windows CE 6.0 Ethernet Bootloader for the Agilent P500 board
Adaptation performed by Agilent Technologies (c) 2008
System ready!
Preparing for download...
RTC: 2022-2-8   1:40:11.73 UTC
 Loading image 1 from memory at 0xD0600000
O
BL_IMAGE_TYPE_BIN
X
XXXXOOOOXXOOOOOOOOXOXOOOOOOOOXOOOXOOOOXXXOOOOOOOOOXOOOOXOXXOXOXXOXOXOXOXXXXOOXXX
OOOOOOXXOXXOXXXXXXOOOXXXOXXOOOXXXOOOXOOXOOXXOOXOXOOOOXOXOOOOOXOOOXOOXOXOXOXXXXXO
XXXXOOOXOOOXOXOOOOXOOOOXOXOXOOOOOOXOOOXOOX
OOOOXXXOOOOXOOXOOXOOOOOOOOOXOXOOOXOOOOOOXOXOOOOOXXOOOOOOOXOXOXXOOXOXOOOXOOOXOOXO
XXXOXOOOXOXXXXOXOXXOXXXXXOXOXXOOOXXXOXXXXXXOXXXXXXOXXXXOXOXOXOOOXXXXOXXXXXOOOXXO
XXOOXXOX
XXOOXOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
OOOOOOOOOOOXXOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOXXXXOXOOO
XOXOOXOOXXXXXXXXXXXXOXrom_offset=0x0.
XXImageStart = 0x80361000, ImageLength = 0x1ACA724, LaunchAddr = 0x80362000
Completed file(s):
[0]: Address=0x80361000  Length=0x1ACA724  Name="" Target=RAM
 Loading image 1 succeeded.
ROMHDR at Address 80361044h
Preparing launch...
RTC: 2022-2-8   1:40:15.19 UTC
Launching windows CE image by jumping at address 0x  362000
Windows CE Kernel for ARM (Thumb Enabled) Built on Mar  8 2013 at 17:05:33
Setting up for a Cold Reboot
Done Setting up for a Cold Reboot
Windows CE Firmware Init
BSP 1.0.0 for the SPEARHEAD600AB board (built Feb 27 2019)
Adaptation performed by ADENEO (c) 2005
+OALIntrInit
-OALIntrInit(rc = 1)
Initialize driver globals Zeros area...
pDrvGlobalArea 0xa0060000  size 0x800 (0xa0060800 -0xa0060000)
Initialize driver globals Zeros area...done
 OALKitlStart
Firmware Init Done.
OALIoctlHalEnterI2cCriticalSection init i2c cs
++SER_Init: context Drivers\Active\14
SER_Init, dwIndex:2
SER2 got sysintr:0x00000017
SER2 Serial Port, new baud rate:0x1c200  (UARTCLK:48000000 IBRD:0x1a FBRD:0x2)
OHCI\system.c, GCFG_USBH1_SW_RST
OHCI\system.c, GCFG_USBH2_SW_RST
-EDeviceLoadEeprom 00:30:D3:21:F2:AD
Phy found addr 31 (ticks=3377)
WaitForLink Start (ticks=3379)
No Link (ticks=4381)
<--EDeviceInitialize
GMAC DMA status register = 0x0
LIN: Data Valid
BALDWIN_DDI: cBaldwinHwIf::Init: Initializing...
BALDWIN_DDI: cBaldwinHwIf::Init: Scope successfully identified.
BALDWIN_DDI: cBaldwinHwIf::Init: Success!
Running infiniiVisionInstallHelper
Failed to start/configure network.
Device load time:
   NANDFLASH: 0 ms
   SNANDFLASH: 0 ms
SHIM DLL, LoadRealDll [PalIO.dll] for [AgilentPalIO.dll]
SHIM [AgilentPalIO.dll] Get Process Addresses
Our command line is
Performing Startup
SHIM DLL, LoadRealDll [PalSStorage.dll] for [AgilentPalSStorage.dll]
SHIM [AgilentPalSStorage.dll] Get Process Addresses
Released build, Feb 27 2019, 20:34:05
Initializing FPGA...
FPGA Type: Idaho
Ver: 2.027 Released
Build Time: Tue Oct 13 16:48:05 2015
Build Machine: TS2404M
No option module detected
Keyboard firmware version 32... ok
Keyboard Info: Board id 7, Board rev 2
Startup sequence is complete.
Saved configuration invalid
SHIM DLL, LoadRealDll [PalSysManagement.dll] for [AgilentPalSysManagement.dll]
SHIM [AgilentPalSysManagement.dll] Get Process Addresses
SHIM DLL, LoadRealDll [PalCaps.dll] for [AgilentPalCaps.dll]
SHIM [AgilentPalCaps.dll] Get Process Addresses
System has been running 24.210651 seconds
Start Up Sequence 13.471923
Memory Load 55%
   System Physical Memory 39.805 / 73.277 MB
   Process Virtual Memory 46.125 / 1024.000 MB
-----> InfiniiVision is running <-----
failed open \Secure\InfiniiVision\LudicrousSpeed.usb
                                                    no workaround for USB phy
Exception 'Data Abort' (4): Thread-Id=04b000a6(pth=87f8a140), Proc-Id=04ae00a6(p
prc=87f8a5f0) 'websockify.exe', VM-active=04ae00a6(pprc=87f8a5f0) 'websockify.ex
e'
PC=40255064(ws2.dll+0x00005064) RA=00013410(websockify.exe+0x00003410) SP=0002fb
7c, BVA=0003fffc
e'
7c, BVA=0003fffc
As far as I can see - there is no corruption signs during the boot, until the very end, referencing websockify.exe and ws2.dll. Those two could be a problem or they could be trying to access something that is a problem.
Next - my reasoning was to get the oscilloscope to boot from usb, and then upload the 2.66 firmware. I bought the Sandisk flash drive referenced on this forum, formatted it FAT, places files in sequence recommended, and here is the output I get on teraterm while oscilloscope is booting with flash drive incerted:
CPU:   SPEAr600
DRAM:  128 MiB
Flash: 512 KiB
RTC: 2022-2-21   6:44:13.1 UTC
Microsoft Windows CE Bootloader Common Library Version 1.4 Built Oct 29 2015 01:39:04
System ready!
RTC: 2022-2-21   6:44:13.4 UTC
O
BL_IMAGE_TYPE_BIN
X
XXXXOOOOXXOOOOOOOOXOXOOOOOOOOXOOOXOOOOXXXOOOOOOOOOXOOOOXOXXOXOXXOXOXOXOXXXXOOXXXOOOOOOXXOXXOXXXXXXOOOXXXOXXOOOXXXOOOXOOXOOXXOOXOXOOOOXOXOOOOOXOOOXOOXOXOXOXXXXXOXXXXOOOXOOOXOXOOOOXOOOOXOXOXOOOOOOXOOOXOOX
OOOOXXXOOOOXOOXOOXOOOOOOOOOXOXOOOXOOOOOOXOXOOOOOXXOOOOOOOXOXOXXOOXOXOOOXOOOXOOXOXXXOXOOOXOXXXXOXOXXOXXXXXOXOXXOOOXXXOXXXXXXOXXXXXXOXXXXOXOXOXOOOXXXXOXXXXXOOOXXOXXOOXXOX
XXOOXOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOXXOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOXXXXOXOOOXOXOOXOOXXXXXXXXXXXXOXrom_offset=0x0.
Completed file(s):
Preparing launch...
RTC: 2022-2-21   6:44:16.51 UTC
+OALIntrInit
 OALKitlStart
Firmware Init Done.
SER_Init, dwIndex:2
Phy found addr 31 (ticks=3415)
WaitForLink Start (ticks=3417)
No Link (ticks=4419)
LIN: Data Valid
Device load time:
   NANDFLASH: 171 ms
   SNANDFLASH: 171 ms
   USB Hard Disk Drive: 171 ms
CPU:   SPEAr600
DRAM:  128 MiB
Flash: 512 KiB
RTC: 2022-2-21   6:45:25.22 UTC
Detects USB Hard Disk Drive, hangs on this point for about 1.5 min, then reboots and repeats the cycle. I tried with and without Secure Folder, formatting different ways, doing it with various versions of the firmware, no go so far.
I also tried to access the U-Boot. With oscilloscope turned off, I held space bar, turned on oscilloscope and got the following:
CPU:   SPEAr600
DRAM:  128 MiB
Flash: 512 KiB
RTC: 2022-2-21   6:45:31.83 UTC
P500 Boot Loader Configuration :
Mac address .......... (00:30:D3:21:F2:AD)
Ip address ........... (192.168.1.145)
Subnet Mask address .. (255.255.255.0)
DHCP ................. (Enabled)
Boot delay (seconds).. (0)
Load image 1 at startup
Image addresses. (0xdxxxxxxx for NAND, 0x8xxxxxxx for RAM)
        1 (0xd0600000)
        2 (0xd1600000)
l) Load memory resident image Load image 1 now
1) Load memory resident image 1 now
2) Load memory resident image 2 now
3) Load memory resident image 3 now
d) Download from platform builder now
u) Start u-boot by resetting
v) Verify Images
And no matter what USB to TTL I use (FDTI, Prolific, or Silabs CP2102), it only goes to P-Boot as above.
Then I tried loading p500_ddrdriver.bin and u-boot_image.bin using spearload. It seems to work - goes through all of the prompts well, and I also used packet sniffer to see what went on between pc and scope while spearload was running (please see attached log) it seems that everything went well. BUT no matter what - with space bar pressed I only get to P-Boot still.
This covers everything I tried doing with this device. I would like to find out if there is anything else that I can do to revive this scope.
Offline Bud
Check if it writes anything back to the USB drive. Compare the drive content and size before and after. If it writes some sort of configuration data dump, then likely the firmware version on the scope does not have USB boot feature. Check this to rule out possibility of USB boot.
Offline onesystem
Ok - I freshly formatted the USB, loaded files, recorded quantity of files and their size before placing it into scope and after boot - it is identical. So nothing is being written to USB.
Will I gain any additional ways of resurrecting the scope if I get the network card purchased and installed? Or should I not worry about it for now?
« Last Edit: February 05, 2025, 12:13:18 am by onesystem »
Offline tv84
  • Country: pt
Re: DSOX2000 and 3000 series - licence , have anyone tried to hack that scope ?
« Reply #3458 on: February 01, 2025, 10:39:31 am »
Don't worry for now.
Offline onesystem
« Reply #3459 on: February 02, 2025, 07:08:04 pm »
Scope is running latest firmware now, not cycling.
EDIT: 25-02-04: Scope is in perfect working order, every channel works well, no deviations or errors, all digital channels work well, wavegen works great. Compared against another working scope.
At the beginning, I followed the instructions on this blog:
https://ripitapart.com/2018/10/15/gaining-access-to-the-windows-ce-desktop-and-doom-on-the-keysight-dsox1102g-oscilloscope/
Gained access to Windows of the scope. Then in using command prompt navigated to Windows directory, found program called infiniiVisionUpdateService.exe, in command prompt typed infiniiVisionUpdateService.exe \usb\2000XSeries.02.66.20240123001.ksx, and scope updated to the 2.66 firmware and is runnig well now - no errors - serial output shows normal running.
I am not sure how useful this trick will be for anyone else, since my case scenario was quite unique - scope was crashing all the way at the end, already after the final loading of the scope program.
So in summary:
1. FAT formatted USB
2. placed infiniivisionStartupOverride.txt in the root of usb (knowing it will stump scope from booting but looking at usb for some time before rebooting)
3. placed extracted content of ScopeLiberator-Release-2.0.zip into the usb flash drive root (without any folder structure)
4. placed 2000XSeries.02.66.20240123001.ksx file into usb root
5. connected keyboard to the back of the scope, plugged usb in front.
6. Turned on the scope and waited until lights started circling on buttons, then pressed Windows button + R, then typed \usb\a.bat and pressed Enter
7. Windows 98-like desktop showed up. Navigated to usb drive, started command prompt, in there switched to Windows directory, typed infiniiVisionUpdateService.exe \usb\2000XSeries.02.66.20240123001.ksx and update went through.
8. When scope was rebooting, I unplugged the flash drive and got a working scope.
Thank you everyone for assistance and guidance.
« Last Edit: September 04, 2025, 10:38:05 pm by onesystem »
The following users thanked this post: analogRF, gilomeno
Offline Campus
« Reply #3460 on: February 12, 2025, 11:02:12 am »
I reactivated my 2004A after years in storage and after reading hours in this thread I am wondering what to do. Currently the scope boots up with the boot screen which then goes dark and the button just keep blinking. Is that the NAND problem?
But I have a usb boot stick with a patched 2.39 that still works fine and the scope starts working.
Is there any way to get a patched (PhillyFlyer?) 2.66 booting from usb or is a full install required these days?
Offline PioB
« Reply #3461 on: February 12, 2025, 11:58:44 am »
Hi Campus
If I understand correctly, there's no way to boot the new firmwares from usb anymore. You need to install it. (rename .ksx to .cab as the filename changed sometime after 2.4?? and earlier versions didn't recognize ksx yet)
https://www.eevblog.com/forum/testgear/dsox2000-and-3000-series-licence-have-anyone-tried-to-hack-that-scope/msg5783849/#msg5783849 has the recipe to patch 2.66. (only works with the windows version of (bs)patch, linux versions fail. So cygwin is needed.
Offline analogRF
« Reply #3462 on: February 16, 2025, 01:15:14 am »
/cygdrive/c/Windows/System32/expand 2000XSeries.02.66.20240123001.ksx -F:* .
patch recipe.xml 2k_266_recipe_patch.txt
mv nk_bin_comp_2k_266diff.bz2.7z  nk_bin_comp_2k_266diff.bz2
bspatch nk.bin.comp  nk.bin.compnew nk_bin_comp_2k_266diff.bz2
rm nk.bin.comp
mv nk.bin.compnew nk.bin.comp
the bz2 patch didnt work. bspatch gives error "corrupt patch" and quits
but the instruction given by msuthar in https://www.eevblog.com/forum/testgear/dsox2000-and-3000-series-licence-have-anyone-tried-to-hack-that-scope/msg5783103/#msg5783103
works perfectly.
Offline PioB
« Reply #3463 on: February 16, 2025, 02:59:40 am »
rm nk.bin.comp
works perfectly.
Hi analogRF
It has been brought to my attention before that it wasn't working under linux, so here's my patching it and the version of bsdiff/patch I am using in cygwin, if that helps someone else. (win11/64, cygwin/64 here).
Congrats on getting it to work tho!
Offline analogRF
« Reply #3464 on: February 16, 2025, 03:58:56 am »
Hi analogRF
yes I am also using Cygwin64 on Win10 and my bsdiff package is 4.3-5
in any case I manually patched the nk.bin and compressed it back again
The following users thanked this post: PioB
Offline PioB
« Reply #3465 on: February 16, 2025, 06:03:25 am »
Just out of curiosity: do the md5sums match mine?
Offline analogRF
« Reply #3466 on: February 16, 2025, 11:37:18 am »
didnt check
Offline dimmog
    • Hubequip
« Reply #3467 on: February 18, 2025, 05:27:01 am »
Has anyone managed to fix NAND corruption on the DSOX3000 with "FPGA programming FAILED!" error in U-Boot?
U-Boot 2010.03 (Oct 18 2011 - 14:28:06)Agilent P500
CPU:   SPEAr600
DRAM:  128 MiB
Flash: 512 KiB
NAND:  fsmc-ecc1 128 MiB
In:    serial
Out:   serial
Err:   serial
SerNum:serial number not programmed
Chip:  BD Board Rev: 4
Net:   smsc
failed: 1 0
Could not copy from NAND offset 0x60000. Error -74 With ECC
failed: 2 1
Could not copy from NAND offset 0x60000. Error -74 NO ECC
Press space to stop autoboot:  0
## Booting kernel from Legacy Image at f8050000 ...
   Image Name:   PBOOT
   Created:      2011-08-24  22:35:34 UTC
   Image Type:   ARM Linux Kernel Image (gzip compressed)
   Data Size:    36045 Bytes = 35.2 KiB
   Load Address: 00000000
   Entry Point:  00000000
   Uncompressing Kernel Image ... OK
Starting kernel ...
Hubequip.net :: test equipment parts and more
www.hubequip.net
Offline analogRF
« Reply #3468 on: February 18, 2025, 11:59:02 am »
is that the whole boot log? it doesnt go any further?
Offline analogRF
« Reply #3469 on: February 18, 2025, 02:16:09 pm »
The FPGA bin file is located at 0xd0060000 in NAND which seems to be corrupted now. The WinCE nk.nb0 is also definitely corrupted and needs to be loaded as well (like the usual/common nand corruption case)
in any case here is what you need to do
1- you load the FPGA binary file from the firmware (FPGA3000A.bin) into memory. I have loaded it at 0x4000000 and it has worked.
2- use fpga command in uboot (p500> ) to write the fpga bin file from memory 0x4000000 into the fpga
3-load the nk.nb0 file of your current firmware (you need to know what fw is in the unit. that's why I asked where is the rest of boot log)
into memory at 0x361000
4- issue the go command (p500> go 0x362000)
there has to be the prepared USB flash in the USB drive before doing all these so the scope reads he startup config from the usb not from nand
having that usb stick in is very important otherwise you will need to restart again. even today after so many times that I have done this
still sometimes I forget to put in the usb with the expanded fw on it and the recovery procedure fails.
steps 3 and 4 are exactly the usual steps for nand recovery and they have been fully reported many times in this thread and another thread
for loading the bin files you can use loady in serial console but I always use a LAN card and load the bin files from a tftp server on my laptop
(I have always used dhcp command for loading files from tftp server into memory but I think there are other commands doing the same as well)
this is much faster than 'loady' and more reliable.
generally if you get any error correction during the loading you better ignore that round and do it again because it will fail.
it only works if all the blocks are transferred with no fail (i mean you should only see ###### during the loading)
The following users thanked this post: dimmog
Offline dimmog
    • Hubequip
« Reply #3470 on: February 18, 2025, 03:48:31 pm »
Thank you for your response. It does go further and sometimes even attempts to boot, about once in every ten attempts. I've attached the full log.
CPU:   SPEAr600
DRAM:  128 MiB
Flash: 512 KiB
In:    serial
Out:   serial
Err:   serial
Net:   smsc
failed: 1 0
failed: 2 1
   Image Name:   PBOOT
Starting kernel ...
Microsoft Windows CE Bootloader Common Library Version 1.4 Built Aug 24 2011 15:15:48
System ready!
O
BL_IMAGE_TYPE_BIN
X
XXXXXOOOOXXOOOOOOOOXOXOOOOOOOOXOOXOXOOOOXXOOOOOOOOOXOOOOXOXXOXOXXOOOXOXXXXXOOXXXOOOOOOXOOXXXOXXOOOXOXXOOXXOXOOOXOOXOOXXOOOXOOOOXOXOOOOOXOOOXOOXOXXXXXOXOXOXOXXXXXXOXXXXOOOXOOOXOXOOOOXOOOOXOXOXOOOOOOXOOOXOOX
OOOOOXXOOOOOXOOXOOXXOOOOOOOOOXOOOOXOOOOOOOXXOOOOOXXOOOOOOOXOOOOXOXOOOOXOOOXOOXOOXOOXOXOXOOXOXOXXOXOOOXXXOOXXOXXOOOXXXXOXOOXOXOOOOXOOOOXOOOXOOXOOXOOOXOOXXXXXXXXXXXXXXXOXrom_offset=0x0.
XXImageStart = 0x80361000, ImageLength = 0x13064E8, LaunchAddr = 0x80362000
Completed file(s):
[0]: Address=0x80361000  Length=0x13064E8  Name="" Target=RAM
Preparing launch...
Windows CE Kernel for ARM (Thumb Enabled) Built on Jan 24 2013 at 14:52:37
BSP 1.0.0 for the SPEARHEAD600AB board (built Sep 13 2013)
+OALIntrInit
 OALKitlStart
Firmware Init Done.
ERROR: C:\WINCE600\PLATFORM\COMMON\SRC\SOC\STM\SPEARHEAD600\DRIVERS\GPIO\.\sh600_gpio_hw.cpp line 170: GPB driver, RegQueryDword('ISTPriority') failed, status:2
SER_Init, dwIndex:2
-EDeviceLoadEeprom 00:30:D3:21:D0:46
Phy found addr 31 (ticks=2695)
WaitForLink Start (ticks=2696)
No Link (ticks=3699)
www.hubequip.net
Offline dimmog
    • Hubequip
« Reply #3471 on: February 18, 2025, 05:05:36 pm »
Success! I used TFTP along with files from the 2.35 firmware - much faster than serial loady for sure!  ;D
Thank you so much for your help!
Here’s a summary of the U-Boot commands:
My TFTP server is 192.168.2.75, running Tftpd64 on a Windows laptop.
dhcp 0x4000000 192.168.2.75:FPGA3000A.bin
fpga 0x4000000 75394
dhcp 0x00361000 192.168.2.75:nk.nb0
go 0x362000
www.hubequip.net
Offline analogRF
« Reply #3472 on: February 18, 2025, 06:01:57 pm »
go 0x362000
fantastic !  :) :) :) :-+ :-+
Offline analogRF
« Reply #3473 on: February 18, 2025, 06:16:38 pm »
yes this is the log I was expecting to see.
it is interesting that the FW image does not exactly match 2.35 although it seems very close (like a few bytes off)
Offline dimmog
    • Hubequip
« Reply #3474 on: February 18, 2025, 06:27:51 pm »
The original firmware version was likely 2.36, based on the production date on the back sticker.
www.hubequip.net
