Author Topic: DSOX2000 and 3000 series - licence , have anyone tried to hack that scope ?  (Read 1683008 times)
Offline Alanme
  • i am not perfect but i know that
Re: DSOX2000 and 3000 series - licence , have anyone tried to hack that scope ?
« Reply #2025 on: September 05, 2018, 12:11:52 pm »
TK, thanks i have seen that somwhere in this thread, but i prefer stay like that and attempt to modify the firmware.
« Last Edit: September 05, 2018, 03:22:30 pm by Alanme »
Offline Alanme
« Reply #2026 on: September 05, 2018, 06:03:09 pm »
Hello
I need help, please
When i attempt to load the "modification" all work like Plesa method, but the soft isnt load in the memory scope, the scope read the "modification" only with the usb stick.
If i pull the usb stick, the scope hang and reboot without "modification"
Offline Pinkus
« Reply #2027 on: September 05, 2018, 06:29:01 pm »
This is why you need the LAN card.
Apart from that, where is the problem? There is another USB port in the back of the unit where you can place your boot stick and use the one in the front for screen shots etc.
The following users thanked this post: Alanme
Offline Alanme
« Reply #2028 on: September 05, 2018, 07:07:34 pm »
Because It is more convenient to have all in the scope memory, no?
Offline TK
Offline Alanme
« Reply #2030 on: September 05, 2018, 10:48:14 pm »
Thanks TK, but it's 2.43 version and i don't want to update to 2, 43 because if i have a corruption software with this version, without the usb boot, i recognize that i do not have the technical level for recover it, and do that.
But if you can make this for me to 2.35 version, that would really make me happy.
Have you seen my avatar?
Offline TK
« Reply #2031 on: September 05, 2018, 10:55:15 pm »
Do you mean flash corruption?  I think it was fixed in 2.43
Anyway, I think flash corruption is covered by Keysight service note even when the scope is out of warranty... they are fixed for free by Keysight (at least in the US)
Offline Alanme
« Reply #2032 on: September 05, 2018, 11:06:35 pm »
Yes, a nand corruption  :scared: :scared: :scared:
In France i have contact keysight, when i brick my scope, and they say me that i must send my scope for repair, and, after diagnostic, they will say me how much for repair.
Honestly i'm scared
Offline TK
« Reply #2033 on: September 05, 2018, 11:18:24 pm »
No, there is a service note and the NAND flash corruption is repaired for free.  I had used this service once on a bricked scope.
You need to ask for: Factory Warranty per Service Note: MSOX3024A-05A (or something similar depending on the model)
« Last Edit: September 05, 2018, 11:51:20 pm by TK »
Offline Alanme
« Reply #2034 on: September 05, 2018, 11:31:02 pm »
Thanks TK, but when i call them they said me that the diagnose and after they say me how much, i tell them of the warranty of nand corruption, but they say the same thing.
Offline TopLoser
« Reply #2035 on: September 05, 2018, 11:47:58 pm »
When they diagnose and confirm it is NAND corruption then the cost of repair is ZERO.
If (worst case) they say it is some other problem (maybe corrupted because of an attempt to get free options) then you will have the option to have it returned to you without being repaired, at no cost.
Upgrade to 2.43 and the risk of corruption becomes almost zero.
Offline Alanme
« Reply #2036 on: September 06, 2018, 12:06:53 am »
But not zero.
I have find the nk. Bin.comp patched for 2.43
I have try to integrate in in the original firmware 2.43 with IZArc.
But i can't update the scope with this solution.
I don't know how to force the scope to copy the "modification" from the usb stick to his memory
« Last Edit: September 06, 2018, 01:18:51 am by Alanme »
Offline TheSteve
  • Living the Dream
« Reply #2037 on: September 06, 2018, 01:14:29 am »
When NAND corruption occurs there is no guarantee that you can fix it with a USB drive. You are far better off running version 2.43.
VE7FM
Offline Alanme
« Reply #2038 on: September 06, 2018, 02:55:40 am »
Thats what's happened to me, a nand corruption, and i recover the scope with TheSteeve method and Pinkus provide me an old firmware
« Last Edit: September 06, 2018, 02:59:02 am by Alanme »
Offline Alanme
« Reply #2039 on: September 06, 2018, 10:43:31 am »
Someone have an idea to force the scope to copy the"modification" to his memory With usb only?
« Last Edit: September 06, 2018, 10:45:37 am by Alanme »
Offline Safar
  • Country: ru
« Reply #2040 on: September 08, 2018, 09:30:27 pm »
Perhaps you can make cab with modified bin.comp but you should to modify also recipe XML script for correct checksum of bin.comp. I wrote it some times ago. Bin.comp flashed twice so you should correct XML in two places
Offline Alanme
« Reply #2041 on: September 09, 2018, 09:15:48 am »
Ok thanks, i will try later
Offline Gribo
« Reply #2042 on: September 10, 2018, 07:26:13 pm »
Does anyone has the complete pin out of the internal expansion slot?
I am available for freelance work.
Offline B0B45
« Reply #2043 on: September 14, 2018, 04:47:35 pm »
Hey everybody,
I just wanna say Thank you to all the supporter of this topic. Yesterday I did the upgrade to 2.43 and everythings works fine  :-+
Kindly regards
B0B
Offline Gribo
« Reply #2044 on: September 19, 2018, 10:07:25 pm »
Here is my version of the DSOXLAN board. Improvements from previous boards - 4 layer stack up for better impedance matching, clearance around the Ethernet connector, no vias on the differential pairs. https://github.com/GriboNexGen/DSOXLAN
I plan to produce ~40 boards of this design. If you are interested in a bare board, send me a PM.
Offline JJalling
« Reply #2045 on: September 20, 2018, 08:46:27 pm »
Anybody tried to flash the scope to fw version 1.10 and use the leaked key?
Offline TK
« Reply #2046 on: September 21, 2018, 11:56:06 am »
Are you asking about 1000X series scopes or 2000X/3000X?
Offline JJalling
« Reply #2047 on: September 21, 2018, 12:31:36 pm »
Well I'm mostly interested from a technical point, as I don't have any of the three. But the private keys for the 2000x and 3000x licenses was leaked with the 1.10 firmware for the scopes, so I thought it was a possibility.
BR Jonas
Edit: misspellings
« Last Edit: September 21, 2018, 12:38:41 pm by JJalling »
Offline HighVoltage
« Reply #2048 on: September 27, 2018, 11:02:54 am »
I can confirm this!
My DSOX3034A suddenly was in a boot loop and did not want to turn on.
Warranty had expired 1/2017 and Keysight inspected it first and then decided to repair it at no cost to me.
Thank you Keysight!
I just upgraded the FW on my other 2000 and 3000 series scopes and hope this error will not happen again.
« Last Edit: September 27, 2018, 11:04:30 am by HighVoltage »
Offline armmcu
« Reply #2049 on: September 28, 2018, 12:49:03 pm »
Hello everyone , is it possible to remove  "unsealed instrument" warning away from a hacked MSOX3104T ? just want to reset to  manufactory settings, disable all of the hacked license.
Thank you in advance for any help
