Author Topic: DSOX2000 and 3000 series - licence , have anyone tried to hack that scope ?  (Read 1118123 times)
charliex and 2 Guests are viewing this topic.
Offline uski
Re: DSOX2000 and 3000 series - licence , have anyone tried to hack that scope ?
« Reply #2550 on: November 16, 2020, 05:45:18 pm »
Hi! Any hack for the MSO4000A series? Thanks
Offline Dwaine
« Reply #2551 on: November 16, 2020, 10:31:54 pm »
The latest 2000X firmware is 2.60 in KeySight web site.
Also the 3000X firmware.
Does anyone know what changes are in version 2.60?
Release Date   Version   Version Description
2020-10-30   2.60   This is the firmware for the 2000 X-Series oscilloscopes.
Offline tabajaralabs
  • Country: br
    • Tabajara Labs
« Reply #2552 on: November 16, 2020, 11:22:20 pm »
They are listed on ReadMe: Corrections on Help for foreign languages
The following users thanked this post: Dwaine
Offline wp_wp
  • Country: cn
« Reply #2553 on: November 17, 2020, 05:42:21 am »
I have helped my friend to hack MSOX4000A.
  • Country: br
    • Tabajara Labs
« Reply #2554 on: November 18, 2020, 03:12:15 pm »
Found it
  • Country: br
    • Tabajara Labs
« Reply #2555 on: November 19, 2020, 04:14:18 am »
How did I extracted the screen?
The file \secure\infiniivision\splashImage.bin is a planar BGR (not rgb, it is inverted) file with a 32 bytes header
Here it is, how I extracted the screen from a "virgin" scope:
https://tabajara-labs.blogspot.com/2020/11/salvando-tela-de-boot-do-osciloscopio.html
The following users thanked this post: Mr. Scram
Offline phatpaul
« Reply #2556 on: November 20, 2020, 10:05:06 pm »
I followed the USB-only guides in posts #2560 and #2562 on my DSOX3014T (with purchased 200MHz upgrade, no Eth jack).
The 3000XSeriesT.7.31.2020012842_patched.ksx installed OK, but the next step to install v241_link_install.cab doesn't seem to work.  I just get error message on the scope screen: "Error: The file did not load correctly."
I tried the process twice with the same result.  I also tried a couple different link strings from this forum.
Ideas?
Offline Dwaine
« Reply #2557 on: November 21, 2020, 03:13:33 am »
Ummm.. That's it..  I guess I'll stick to 2.50
Offline Kibabalu
« Reply #2558 on: November 21, 2020, 05:28:54 am »
somewhat more:
Enhancements for 3000A
- New SCPI command to start the probe degauss operation for the N7026A and N2893A probes.
Enhancements for both 2000A and 3000A
- Completed software and built-in online help localization.
- New SCPI commands for clearing persistence data from the display and querying the run state.
Bug Fixes for both 2000A and 3000A
- Fixed network print issue where a valid printer address format was not accepted.
Offline Hydrawerk
« Reply #2559 on: November 22, 2020, 12:02:22 am »
Well, both 2000A and 3000A scopes will be 10 years old in February 2021. Is there a successor coming?
Online Bud
« Reply #2560 on: November 25, 2020, 08:29:29 pm »
If I remember correctly the password attempt always fails the first time. You may have to try twice before it'll let you in using Telnet.
I've seen this more then once in this thread, so here is the explanation for all of you:  this is a quirk of the Putty software that people often use for telnet connectivity.  It spits some garbage from the buffer first time you use it, so password entry always fails the first time. Use built-in Telnet utility in Windows and your authentication will be fine from the first try.
Edit: alternatively, if you still want to use Putty, after connecting to the scope press Enter, then proceed with entering the credentials.
« Last Edit: November 25, 2020, 10:30:10 pm by Bud »
Offline Mr. Scram
  • Display aficionado
« Reply #2561 on: November 25, 2020, 08:34:10 pm »
I remember that question being asked many years back.
Online tv84
  • Country: pt
« Reply #2562 on: November 25, 2020, 08:37:56 pm »
Did KS include a time bomb in the devices?
Online Bud
« Reply #2563 on: November 25, 2020, 10:31:12 pm »
To a certain extent, possibly. There are digital certificates there that have expiry.
Offline MarkL
« Reply #2564 on: November 25, 2020, 10:40:59 pm »
I think it's pretty clear that the 3000T series is the replacement for the 3000A.  If I recall correctly, at one point the A and T even had the same price for the same combinations of channels, MSO option, and bandwidth.  Looking at it now, the T series is slightly cheaper and also has more decode and other licensable options.
The 3000A series can still be found by searching for it, but it does not appear on the main scope web page.  Amongst others, it now shows the 3000T along with the 2000A series
I'm not sure why they're continuing to sell the 3000A series.  It hasn't had any significant new features added to it for years and only a minor bug fix here and there.
I can only speak for the 3000A because I have one:  The purchased licenses do not expire.
Online Bud
« Reply #2565 on: November 25, 2020, 11:37:31 pm »
I do not mean licences, i mean digital x509 certificates. There are a few Root ones from the Public Certificate Authorities and a few issued to Keysight , at least one for code signing.
Offline dorofteius
« Reply #2566 on: December 02, 2020, 05:02:41 pm »
Thank you all for the knowledge.
Another successful hacked DSO-x-2012A  using USB only .
The trick is to have files in the main directory not in any sub folders. It fails every time when files are not in the main directory.
I followed these instructions from page 89  written by scribble - thank you man - much easier to have it all in one place.
Download Phillyflier's patched firmware from post #2167 on page 87
Download Luminax's license patch from post #1529 on page 62
Extract license patch, open cmd window (if using MS Windows), navigate to license patch folder and rename infiniivision.lnk to .txt
Edit infiniivision.txt and replace text in the file with Odessa's modification from post#2197 on page 88
80#infiniivisionLauncher.exe -l DIS -l MSO --perf -l BW20 -l SCPIPS -l CABLE -l VID
Save and rename file back to .lnk
Copy firmware file (rename from .ksx to .cab if current scope fireware is older than v2.41) to FAT32 formatted USB drive
Copy licence files (2x .cab files and .lnk file) to same USB drive
Now go to your scope, turn on and plug in USB drive to front USB port
Press [Utility] > File Explorer, select the firmware file (3000XSeries.02.50.2019022736_patched.cab); then, press Load File, wait for scope to load and reboot.
Check firmware has updated to v2.5, if successful continue
Press [Utility] > File Explorer, select v241_link_install.cab file; then, press Load File, wait for scope to load and reboot.
Today I received my 2002A from Ebay at 490 E.
I followed this instruction, and it worked perfectly. 5 minutes later I had a unlocked scope.
Thanks to all for the good work.
Offline Greybeard
« Reply #2567 on: December 04, 2020, 07:07:40 pm »
Electrolytic caps in the power supplies...?   >:D
« Last Edit: December 04, 2020, 07:12:44 pm by Greybeard »
Offline msuthar
  • Country: in
« Reply #2568 on: December 05, 2020, 05:12:33 pm »
  DSO-X 2004A  after updating  Version 2.60   port 23 for telnet is not possible. Port scanner do not find port 23 open for telnet.
  There is one port open which is 21 and if it is telnet then shows  below image:
Online PA0PBZ
« Reply #2569 on: December 05, 2020, 07:07:54 pm »
Port 21 is normally used for FTP, give it the ls command and see what happens
Offline mshaban
  • Country: eg
« Reply #2570 on: December 15, 2020, 01:47:47 pm »
thank you for your post, i need to try your steps to my DSOX2014a model withe the same proplem. the firmware available on Firmware for Keysight is ver 2.6, i am not sure it will be work or no, ver 2.35 no longer available, and dont know if it can be found in other site
Offline markus354
« Reply #2571 on: December 15, 2020, 06:39:47 pm »
There was someone before to downgrade the scope to 2.35
Try to find I'm sure there is a way.
If I find it I will send you a link.
Offline markus354
« Reply #2572 on: December 15, 2020, 06:46:40 pm »
Hello guys.
I try to unlock my scope MSOX3034A  and after update to 2.50 patched i don know why I can't login to telnet. infiniivision / skywalker1977
Wrong login/ pass
I have Keysight LAN module.
Any help please.
I have try on another scope on DSOX3034T and I've get to this same point.
What I doing wrong
Offline markus354
« Reply #2573 on: December 15, 2020, 07:13:52 pm »
It is not that straight forward
There is whole procedure to downgrade.
Offline markus354
« Reply #2574 on: December 15, 2020, 07:57:53 pm »
Ok.
False alarm.
It's be me stupid and sticky keyboard  :horse:
full unlock and 500MHz
Thank you for all work you have done here.
and Thank you for help me to go trough even those who want to charge me 650 for someone else work. :-+
I try to contribute more to this forum to pay back
