If you need, I could also provide a dump of the whole nand, but this might be the last solution as using other's nand dump will cause a serial number change and wrong cal data.
However, I believe your condition is due to wrong usb file structure.
Bill, are you talking about the entire program memory area or just the uboot? Unfortunately, my knowledge about this scope is VERY limited. It would be nice if I could get an entire dump from a good osciloscope and install on mine. I tried 6 different firmware versions (all old versions and the 2.50 cracked one) and wasn't able to make it boot. It tries to boot, load the (ugly) keysight boot screen and returns a segfault in many appls.
Tried to run MTEST but it locks up. Got a good, working (2 channel) dso-x2002A and it locks up on the MTEST too. So I don't believe the problem is RAM bound.
I confess I am completely lost, and I cannot find a line of logic. Begging for help, I cannot let this scope let go. It looks like to be SO near!
BTW, I have the LAN interface, so I can load and boot way faster than serial.
Maybe if someone created a correct USB boot drive image + NK.NB0 file for me to try to load...If you can do that feel free to send me a private message
Thanks and sorry for being so noob
