Author Topic: DSOX2000 and 3000 series - licence , have anyone tried to hack that scope ?  (Read 731465 times)
Zander and 4 Guests are viewing this topic.
Offline dianzimi
Wooo well done Mr Kilobyte!!
From the Agilent 2.35 upgrade CAB I extracted the files you said:
infiniiVisionLauncher.exe
infiniiVisionCore.dll
Put them on a USB stick, booted the 2.37 scope and got telnet access (infiniivision, skywalker1977)
Killed the running version (a step you didn't mention, probably because it was obvious to you!):
processmgr kill infiniiVisionLauncher.exe
Change to application directory
cd \secure\infiniivision
Copy those two old files:
copy \usb\infiniiVisionLauncher.exe
copy \usb\infiniiVisionCore.dll
Reboot and get firmware concerns message, scope still thinks it has 2.37, no problem.
Put Agilent 2.35 upgrade CAB onto USB stick and up(down)grade as normal. Lots of waiting, scope then reboots with 2.35 up and running.
Then reboot with USB stick with modified 2.37 files to get all options including MSO and full bandwidth.
Can you send me the 2.15 cab file ?my email address is dian.zi.mi@163.com
« Last Edit: January 06, 2015, 06:36:09 am by dianzimi »
The following users thanked this post: Andrew
Offline EEVblog
It is always said that Agilent/Keysight will swap boards if you want to upgrade from 100/200 to 350/500 Mhz. I am wondering if there is really a significant difference or if they just inject some software instead of swapping boards.
Yes, they have to actually swap boards, the 300/500MHz was a different front end. Although wait a few days and that could be changing...  ;)
Offline Rigby
  • Learning, very new at this. Righteous Asshole, too
Oh I hate it when you do this.
Offline kilobyte
    • My Website
I'm curious too.
Maybe it has something to do with the two scopes that i can see on the dropcam livestream?
The looks very very similar.  :)
I'll let it be a surprise.
Offline Pinkus
I'm curious too.
Mmmmh; Dave says "the 300/500MHz was a different front end." I am wondering what that means, especially to my already existing 200 Mhz version...
Offline TopLoser
Offline EEVblog
I was given wrong information on that unfortunately.
The new 3000T still has different front end hardware between the 100/200 and 350/500 versions.
Offline WVL_KsZeN
Bingo!
https://translate.google.com/translate?sl=auto&tl=en&js=y&prev=_t&hl=en&ie=UTF-8&u=http%3A%2F%2Fwww.hw.cz%2Fprodukty%2Fosciloskopy-keysight-dsox3000t-graficky-trigger-pro-kazdeho-inzenyra.html&edit-text=
-comes with a touchscreen
-4Mpts memory
-greatly extended match functions
-correlated signal analysis (time and frequency domain)
and the datasheet aswell : Datasheet
« Last Edit: January 08, 2015, 11:10:01 am by WVL_KsZeN »
Offline Neganur
woah, a proper full bandwidth 1mV front end. What took them so long :P
Offline WVL_KsZeN
No, it's still magnified : "2. Specifications are valid after a 30-minute warm-up period and ± 10 °C from firmware calibration temperature. 1 mV/div and 2 mV/div are a magnification of 4 mV/div setting. For vertical accuracy calculations, use full scale of 32 mV for 1 mV div and 2 mV/div sensitivity setting."
Offline Neganur
hmm you're right - further down in the characteristics it states the all familiar sentence that you quote. But I don't know what to make of this table then (page 7):
vertical setting steps of 1, 2, 5 mV and the noise stays basically the same in those three settings. Is the noise not amplified?
I guess they had to come up with something to compare it to the Tek scope? Poor move Agilent : /
Offline WVL_KsZeN
It's just a digital amplification (only scaling on the display), so of course the noise in Vpp stays the same.
Offline Neganur
Yeah I guess I still hoped it had real amplification. Magnified pixels again, boo!
Offline fons
Hi!
Does anybody know where can I find the 2.35 firmware? The keystone website only lets you download the latest one (2.38)
Thanks!
Thanks to those who sent me the firmware in PM. I had version 2.36 in the scope, after downgrading to 2.35 I can use the usb hack without problems. Thanks!
Offline Isamun
  • Country: no
Last year I was lucky enough to pick up a demo version of a 3034a. All the options where there when I got the unit and are listed with an astrix (*). I haven't updated the firmware yet, due to the fear of loosing my beloved/free options. Anyone know if an update will remove them?
Offline iRad
  • Are you sure it's safe?
The astrix (*) means that the options are either in DEMO MODE or the scope is a STORE DEMO, and thus in demo mode. There has been posts indicating that the store demo units have a runtime of 120 days, but I cannot say for sure. In either case, updating the firmware should not remove the demo, but again, I cannot say for sure...
« Last Edit: January 18, 2015, 05:01:51 pm by iRad »
Offline ToBeFrank
Not necessarily. It could be in distributor mode. If the first item in the list is "All", it's a good bet. My scope has been this way for well over a year. The really cool part is if they put new features in future firmware that require licenses, a distributor scope will automatically turn them on when you upgrade the firmware.
Offline Isamun
  • Country: no
Thank you both.
Is there a way I can check the runtime? I would presume this would have been reset at their factory when it was "refurbished".
I also have the "All" (no astrix).
If I read you correctly, you have performed an update and still kept the options. In your opinion, the case would be the same for me?
« Last Edit: January 18, 2015, 07:01:46 pm by Isamun »
Offline ToBeFrank
You should be fine. Whether they are time limited or not, I don't know. It may be the case that you got lucky and they forgot to clear the licenses out of your scope before sending it to you.
Offline iRad
You got a nice catch then with ALL functions enabled. Upgrading firmware should not disable any legitimate features, demo, distributor, or purchased. I see from the screenshot that your firmware is quite old. You'll have a great incentive to upgrade to the latest firmware, with many new capabilities, improved measurements, and bug fixes... Great Score!
One other nice thing to know about your scope, is that it has the 500MHz front end.  :-+
Offline Isamun
  • Country: no
Im happy to report the update went as expected.
Thank you for the confidence boost.
Offline iRad
Excellent!  :-+
Now you can check out your new and free ARB you didn't have yesterday...
Offline oedipe78
Hello everyone,
Explanations are mixed between different versions. I'm afraid to get a stupidity.   :-BROKE
Someone could explain step by step how to change the latest version (2.38)?
And how to load the modified version?
Does anyone want to change the firmware new scope DSOX/MSOX 3000T ?
Thank you in advance.
Offline kilobyte
    • My Website
For the data that have to be modified see here
https://www.eevblog.com/forum/testgear/dsox2000-and-3000-series-licence-have-anyone-tried-to-hack-that-scope/msg569677/#msg569677
And for Firmware Downgrade see TopLosers summary here
https://www.eevblog.com/forum/testgear/dsox2000-and-3000-series-licence-have-anyone-tried-to-hack-that-scope/msg537981/#msg537981
Maybe if you like to buy me one of these...  ;D
I already have a dsox3024a at home so i didn't buy a new one in the next time.
I hope they release a firmware package to have a look into.
Offline oedipe78
I still have many questions.  :scared:
is the infiniiVisionCore.dll (v2.35) file needs to be changed ?
you change address : 0x0x27AF78 , data : 0x00 00 A0 E3 ?
Where you find the version 2.35? (it is not available on the official website)
this is the original file?
I understood.
you downgrade to version 2.35. This is Original firmware 2.35?
After I upgrade to Version 2.38. This is not the original firmware 2.38, what do I need to change?
