If you are working with DSLogic 16, you will have to divide its resource in half.
That is, the first 8 bits are allocated to the address, using the zero bit for triggering, and the remaining 8 bits for data.
You should follow the connection sequence - address/data bit size so as not to mislead yourself.
Just practice in demo mode.
