Author Topic: DSView 1.3.0 - How to group channels into buss  (Read 3785 times)
Offline paults1956Topic starter
« on: March 09, 2024, 09:47:28 pm »
The manual doesn't mention this AT ALL. I've tried clicking/dragging/chanting spells but nothing. What am I missing?? All I want is an 8-bit data buss and a 16-bit address showing the HEX values as my 8031 board runs BASIC from an EPROM.
Offline abeyer
Re: DSView 1.3.0 - How to group channels into buss
« Reply #1 on: March 10, 2024, 12:04:23 am »
I think you want to add a parallel protocol decoder w/ your data and clock lines assigned in the config for the decoder. DSView is a custom build of the sigrok software, so you can always look at their docs for general reference, too, although there are minor differences.
« Reply #2 on: March 13, 2024, 02:27:49 pm »
Thanks! That was the method. Sure would HELP if it was mentioned in the manual.  |O
Offline asis
  • Country: ru
« Reply #3 on: March 14, 2024, 04:23:10 am »
If you are working with DSLogic 16, you will have to divide its resource in half.
That is, the first 8 bits are allocated to the address, using the zero bit for triggering, and the remaining 8 bits for data.
You should follow the connection sequence - address/data bit size so as not to mislead yourself.
Just practice in demo mode.
