Author Topic: DSView time reference not at trigger position  (Read 316 times)
Online eTobeyTopic starter
  • Virtual Features for the SDS800XHD -> My website
    • Virtual feature script
« on: November 06, 2024, 09:12:02 am »
there has to be a way, to have the trigger beeing the reference. But i cant find a way, and i couldnt find anything about it in the manual.
"Sometimes, after talking with a person, you want to pet a dog, wave at a monkey, and take off your hat to an elephant." (Maxim Gorki)
My current top list of issues on the SDS800X HD:
https://www.eevblog.com/forum/testgear/sds800x-hd-bug-reports-firmware/msg5766323/#msg5766323
Online ebastler
Re: DSView time reference not at trigger position
« Reply #1 on: November 06, 2024, 03:30:24 pm »
This was submitted as a Sigrok feature request in 2019. (See the Google hit below -- Sigrok's actual bug tracker seems to be offline at the moment.) It might still be unresolved in Sigrok and DSView?
1338 – Option: Show time zero at the trigger
https://sigrok.org/bugzilla/show_bug.cgi?id=1338
04.03.2019 — when trigger "arrives" after running the capture, time marker "0" is not positioned at the trigger point 2. ... set_zero_position(triggers ...
Edit: Ah, I just saw that you have already found the DSView issue tracker at https://github.com/DreamSourceLab/DSView/issues and have submitted this item. That's probably the best place. And looking at the slightly earlier entries there, DSLogic seem to follow up actively on submissions.
« Last Edit: November 06, 2024, 04:51:58 pm by ebastler »
« Reply #2 on: November 06, 2024, 09:46:35 pm »
Edit: Ah, I just saw that you have already found the DSView issue tracker...
Yeah, i am quite active ;-). I even made a workaround script, that even adds some automated measurement. Its done via a decoder it shows the time for the right edge. The trigger time has to be set everytime, though.
The script has to go into "C:\Program Files\DSView\decoders".
UPDATE:
I updated the script: now the reference can be any edge of another channel. Also i interval measurement.
« Last Edit: November 07, 2024, 03:52:07 pm by eTobey »
