1338 – Option: Show time zero at the triggerhttps://sigrok.org/bugzilla/show_bug.cgi?id=133804.03.2019 — when trigger "arrives" after running the capture, time marker "0" is not positioned at the trigger point 2. ... set_zero_position(triggers ...
Edit: Ah, I just saw that you have already found the DSView issue tracker...
