I have taken the time to get all my instrument connected to my network but have yet to make any practical use of the possibilities. The first automation task I really need is fairly straightforward voltage logging for a battery discharge tests. Ideally, I would be able to control the DC load, log current, temp, and whatever else - but for now just the voltage from the DMM is a great step forward.
I have LabView, but have not learned how to use it in any effective way. I also have been able to connect and confirm the instruments - scope, Keithley 2700 DMM, Agilent PSU's, and Chroma 8 channel electronic load. The part that I am trying to do quickly is simple polling of the DMM about 1hz and logging the data into an excel sheet (or CSV, whatever)
There was nothing obvious in my searches, but maybe I am searching for the wrong thing. Is this something that can be done directly in Excel? Is there a cheap and cheerful utility that can do a simple GPIB read command at 1hz (or so)? It would be a bonus if it can terminate the test by sending a command to the DC Load at a specified voltage so the battery is not damaged - but I can live without that.
LabView seems awesome but only if I take a lot of time to dig in and figure it out.
