Author Topic: eBay clone Saleae Logic 16  (Read 16767 times)
Offline g0mgx
« on: January 15, 2018, 09:06:02 am »
Hi Gang
I've just bought myself an eBay sourced Saleae Logic 16. I use Win 7 and it appears listed in Device Manager as "Saleae Logic16 USB Logic Analyzer", but when I try to use the device in PulseView it is listed in the device dropdown menu, but selecting it results in "No Device" remaining as the selection.
I've read the Wiki for what may (or may not) be the device I have, but it's very Linux based and rather scary:
https://sigrok.org/wiki/Mcupro_Logic16_clone
I've attached an image of the device plus a shot of my device manager entries.
Can anyone here explain to me how to get this to work or perhaps if this is even possible? I'd rather hoped it would just "plug and play", but clearly there's more to it than that  :(
Thanks for any pointers!
Mark
G0MGX
Offline blueskull
  • Country: cn
  • Power Electronics Guy
Re: eBay clone Saleae Logic 16
« Reply #1 on: January 15, 2018, 09:13:52 am »
Saleae has made it very clear in their license agreement tha you are not supposed to use a clone with their proprietary software. Go get the Sigrok instead.
BTW, I forgot the user name, but one of Sigrok authors hangs out on this forum.
Offline 1anX
« Reply #2 on: January 15, 2018, 09:18:09 am »
I never had much joy with Sigrok and Pulseview so I went here and downloaded Saleae software. Works really well!
https://www.saleae.com/downloads
Offline blueskull
  • Country: cn
« Reply #3 on: January 15, 2018, 09:21:22 am »
I do have good prediction.
Offline glarsson
« Reply #4 on: January 15, 2018, 09:22:26 am »
The Saleae license is not relevant as Pulseview is part of Sigrok.
Offline blueskull
  • Country: cn
« Reply #5 on: January 15, 2018, 09:23:42 am »
Just a hint in advance.
Offline g0mgx
« Reply #6 on: January 15, 2018, 12:59:27 pm »
Does this have the same decode capability as the Sigrok PulseView software?
I'll check it out - but am concerned about licensing.
Mark
Offline cdev
« Reply #7 on: January 15, 2018, 02:01:20 pm »
Have you installed the fx2la "firmware blob"?  You dont have to build it, you can install it in other ways. The easiest is via a package manager.
That is the way to get pulseview working.
If you are using Windows I am not at all familiar with how it works but I can help you get that working on Linux.
This should be an FAQ. Sigrok is open source and works well.
Saelae is one of a multitude of companies that make similar hardware based on the original FX2 dev board.
When FX2 chips came out the manufacturer (Altera) had a demo logic analyzer implemented in software for it - the board uploads its firmware when its started.
Several companies implemented hardware based on that design, using pretty colors, nice grabbers,  etc, to increase value.
Their hardware in some cases was quite nice but - the Saellae Logic 8 even -  cost well over a hundred dollars!
Way too expensive for me, so I bought a cheap LA and used it with Sigrok. Which has always worked well for me.
IMHO people should look for FX2-LP ones using keywords like "FX2LP Development Board" , "CY7C68013A" "EZ-USB" etc.
Not the brand names of companies who in reality are not the manufacturers..
the Sigrok software is quite a bit the equal of the closed source brands. Plus its free. There really is no area where its not a good choice.
If you want to use a commercial logic analyzer with your generic hardware you should look into the USBee software which you can buy and they will give you support. You can use it with a generic hardware. So then you have bought the tool so you can get both an affordable price and they seem to sell it based on an argument that they offer a more polished user experience.
They have a good reputation. Since I have not found myself really needing that yet Ive held off to see how it works for them. But I may buy the USBee software in the future.
« Last Edit: January 15, 2018, 02:52:32 pm by cdev »
Offline abraxa
  • Sigrok associate
« Reply #8 on: January 15, 2018, 02:35:24 pm »
g0mgx, you can find a "debug build" on the sigrok download page: https://sigrok.org/wiki/Downloads
When you run this debug build, you will see the debug output in a console window (you may have to run it with parameter "-l 5" to enable the log output, not sure atm). That should help figuring out why the hardware won't initialize as it should.
There are a lot such clones out there and we don't support all of them yet, it unfortunately really depends.
Also, did you use Zadig to switch drivers? You may have to do that before running PulseView, it was installed with sigrok. (I'm not a Windows guy, so my memory is a little hazy regarding this detail.)
Offline g0mgx
« Reply #9 on: January 15, 2018, 03:58:22 pm »
I believe so as I also have the HobbyComponents logic analyser and that works fine.
http://hobbycomponents.com/testing/243-hobby-components-usb-8ch-24mhz-8-channel-logic-analyser
I've already watched that video and that was the inspiration for purchasing this clone of the Logic 16 as my Hobby Components device just doesnt sample fast enough for my needs and I understand this clone includes some buffering/memory on board and can sample much faster speeds.
Mark
Offline g0mgx
« Reply #10 on: January 15, 2018, 04:02:31 pm »
That sounds like a fine plan - I am a Linux noob - but have just done a fresh Debian 9 install on a spare PC I have here so am all ears....
I will start by trying to install SIgrok but that doesnt seem to work with apt-get which says it's been superseded by Sigrok-cli - so I guess I have fallen at the first hurdle  |O
I am very grateful for the help so far!
Mark
G0MGX
Offline plazma
    • Homepage
« Reply #11 on: January 15, 2018, 04:38:52 pm »
I bought one looking like this and it woked as specified. Works with an older version of Saleae and Sigrok. There is some wiki page etc. for Sigrok which shows compatible models.
https://guideimg.alibaba.com/images/shop/80/10/09/7/upgraded-version-logic-16-100m-logic-analyzer-support-software-version-1-1-20-all-versions-compatible-aluminum-luxury-features_2475057.jpg
Offline abraxa
  • Sigrok associate
« Reply #12 on: January 15, 2018, 06:51:15 pm »
Mark
G0MGX
If you want to run it on linux then there's a rather easy way. Let me write it down as a sequence of console commands:
wget https://sigrok.org/jenkins/job/sigrok-native-appimage/platform=native-x86_64-appimage/lastSuccessfulBuild/artifact/cross-compile/appimage/out/PulseView-NIGHTLY.glibc2.14-x86_64.AppImage
chmod u+x PulseView-NIGHTLY.glibc2.14-x86_64.AppImage
./PulseView-NIGHTLY.glibc2.14-x86_64.AppImage
It's essentially an all-in-one package that you can use without installing anything.
The only issue I can think of that you may face are the udev rules which you won't have installed. If you try the AppImage and it can't find your device, try running the AppImage with sudo. If that works, installing the udev rules is simple to do, but first things first.
« Last Edit: January 15, 2018, 06:53:11 pm by abraxa »
Offline plazma
    • Homepage
« Reply #13 on: January 15, 2018, 07:11:35 pm »
Also works fine with the latest version from Saleae.
Offline cdev
« Reply #14 on: January 15, 2018, 07:16:01 pm »
Here is the Debian tracker page for pulseview
 https://tracker.debian.org/pkg/pulseview
The current version of debian, stable is "stretch"
But for some reason there is no pulseview in stretch. This is likely explained in the build logs, change logs, etc.
Its probably possible to build a deb that will work or use an older one, if you do that correctly so as not to invoke "dependency hell".
There are a number of alternatives in this situation. You say this is your very first Linux installation?
« Last Edit: January 15, 2018, 07:26:23 pm by cdev »
Offline 1anX
« Reply #15 on: January 15, 2018, 09:00:40 pm »
X2
Latest version works perfectly!
Offline janoc
« Reply #16 on: January 15, 2018, 09:48:38 pm »
It is most likely nothing to do with the license of the Saleae software but the fact that the device needs firmware uploaded. And the firmware is different if you use Sigrok/Pulseview and the official Saleae software. So if you have powered the device up using one and then started the other it will not be detected - you need to unplug it and reconnect it.
Offline phil from seattle
« Reply #17 on: January 15, 2018, 10:59:37 pm »
Be wary of the Saleae Logic 16 clones. I haven't been able to get pulseview to work with my clone (exact same packaging but not so sure under the covers).  I went through the process of obtaining the firmware file and get the following message from pulseview:
sr: saleae-logic16: Invalid FPGA bitstream version: 0x41 != 0x10.
sr: saleae-logic16: Failed to init device.
sr: saleae-logic16: Device failed to renumerate.
The Saleae code runs fine with it.
Offline cdev
« Reply #18 on: January 16, 2018, 12:07:45 am »
Seems to me from looking at the Debian pulseview package logs that the testing versions of pulseview stuff should work. The way to use testing is not to turn it on all the time, just turn it on to load a single program and its dependencies, (or in the case of pulseview and sigrok, all the sigrok family of programs) update, upgrade, and then turn the testing repository off.
If you cant do that successfully, then use the jessie versions which were working great for me before I switched to the source version..
Either one should work fine but don't mix them.
« Last Edit: January 16, 2018, 12:09:57 am by cdev »
Offline g0mgx
« Reply #19 on: January 16, 2018, 06:22:53 am »
So here's the results:
sudo ./PulseView-NIGHTLY.glibc2.14-x86_64.AppImage
sr: resource: Failed to open resource 'saleae-logic16-fx2.fw' (use loglevel 5/spew for details).
sr: saleae-logic16: Firmware upload failed.
sr: saleae-logic16: Unable to open device.
Mark
G0MGX
Offline g0mgx
« Reply #20 on: January 16, 2018, 06:26:14 am »
Not entirely but I have no real experience of Linux at all.
Mark
G0MGX
Offline blueskull
  • Country: cn
« Reply #21 on: January 16, 2018, 06:52:17 am »
Mark
G0MGX
Try sudo?
« Reply #22 on: January 16, 2018, 05:40:31 pm »
I believe that error means you don't have the firmware file - saleae-logic16-fx2.fw   Have you gone through the extraction process? Look here https://sigrok.org/wiki/Saleae_Logic16#Firmware
Also check permissions on the files if you do have them.  You should not need to use su/sudo. especially if you've done all the work under the same user id.
I spent a lot of time trying to get pulseview working with my chinese clone Saleae Logic 16. The internals do not appear the sames as the ones shown in sigrok page you linked to in your first post. The PCB is fairly different.
« Last Edit: January 16, 2018, 05:54:11 pm by phil from seattle »
Offline g0mgx
« Reply #23 on: January 16, 2018, 05:49:44 pm »
When I try and run the python script sigrok-fwextract-saleae-logic16 I get the following:
Traceback (most recent call last):
  File "./sigrok-fwextract-saleae-logic16", line 23, in <module>
    import parseelf
ImportError: No module named 'parseelf'
Seems very complicated!
Thanks for the help so far.
Mark
G0MGX
Offline g0mgx
« Reply #24 on: January 16, 2018, 05:51:31 pm »
Try sudo?
The results listed were with sudo ./PulseView-NIGHTLY.glibc2.14-x86_64.AppImage
Mark
G0MGX
