Author Topic: Solved  (Read 1815 times)
Offline 001Topic starter
  • Country: aq
Solved
« on: October 18, 2019, 06:46:11 pm »
Solved
Thanx a lot!
« Last Edit: October 19, 2019, 10:54:24 am by 001 »
Online coromonadalix
Re: Ebay counters. Do You recomed one?
« Reply #1 on: October 18, 2019, 08:19:14 pm »
should do nicely if you dont input more than a 5khz or 5000 counts pulses per second  = cps
The following users thanked this post: 001
Offline DaJMasta
    • medpants.com
« Reply #2 on: October 18, 2019, 09:33:17 pm »
I would have thought you could get them much cheaper than that - I know there are RPM counters (tachometers) that are less expensive, but which probably don't have a trigger-on-count functionality.
Why not a basic TTL circuit or a micro?  A dollar or two in parts and you should be able to fully configure it, a 12 bit counter, a comparator on the input set to your signal level, and some and/not gates to select where to stop if you want it hardwired.  Also any old micro can do this in half a dozen lines of code, you just need a relay driver and whatever signal conditioning to get your input signal readable by a micro.
Offline StillTrying
  • Country: Broken Britain
Re: Solved
« Reply #3 on: October 19, 2019, 11:59:24 am »
I knew it was going to be a bad idea to click on a subject that just says "Solved". :-BROKE
The whole thread should be deleted to prevent the time wasted playing "This is the answer, what was the question."
« Last Edit: October 19, 2019, 12:24:11 pm by StillTrying »
Offline TheHolyHorse
  • You don't need to be confused, just understand it.
Re: Solved
« Reply #4 on: October 19, 2019, 12:13:21 pm »
Yeah editing the question and removing the actual question isn't the best idea. It pretty much ruins the point of a forum. :palm:
Offline Gandalf_Sr
Re: Solved
« Reply #5 on: October 19, 2019, 12:27:23 pm »
I dunno, it's kind of like Jeopardy, we get the answer and have to guess the question.  ;D
If at first you don't succeed, get a bigger hammer
The following users thanked this post: BillB
Re: Solved
« Reply #6 on: October 19, 2019, 12:28:32 pm »
 :-DD :-DD
But I'd still prefer to see the actual question, it might help someone in the future with a similar issue! :box:
  • Country: aq
Re: Solved
« Reply #7 on: October 19, 2019, 12:32:51 pm »
Dont drink for fridays  :palm:
Re: Solved
« Reply #8 on: October 19, 2019, 12:41:39 pm »
It's better than drinking on working days. ;)
Offline StillTrying
Re: Solved
« Reply #9 on: October 19, 2019, 01:41:18 pm »
The original title "Ebay counters. Do You recommend one?" looked almost interesting, I should have clicked on it yesterday when it might have made sense. I still think the whole thread should be deleted, not just locked, because "testgear" has enough junk threads as it is.
Online Simon
  • Global Moderator
    • Simon's Electronics
Re: Solved
« Reply #10 on: October 19, 2019, 03:25:32 pm »
Yes, please don't! or just stay off the forum fridays. Drink or forum, choose or I'll choose for you!
The following users thanked this post: tggzzz, blueskull, Gyro
Offline tv84
  • Country: pt
Re: Solved
« Reply #11 on: October 19, 2019, 03:32:29 pm »
Just "Solved"?? ?? ?? ??   |O |O
I think it's too much cold on Antarctica...
Offline Gyro
Re: Solved
« Reply #12 on: October 19, 2019, 04:16:09 pm »
It would certainly keep the random crap noise level down.
Best Regards, Chris
