Author Topic: MK-328 LCR Tester dead?  (Read 1815 times)
Offline vinloveTopic starter
« on: March 29, 2020, 12:55:44 am »
Tonight I was trying to test a new electrolyc capacitor, but it must have had some charge still left in the cap.
When connected it to the MK-328, and pressed the test button, but the MK-328 is not powering on.
I checked the DCV from the cap, and it was about 4V, and slowly discharging. But it could have been far higher DCV in there.
I forgot to discharge it before connecting it to the MK-328.
Is the MK-328 totally dead?  Have I just killed it with a DC charged capacitor?
Is there any parts that can be replaced and repaired?
Or is it for the bin?
 I opened it up, and there is no fuse, and just 9V DC from battery to straight to the PCB, and some tiny dots of SD components and a tiny chip connected to LCD, and that is all there is to it.
Shame because it has been working well for about 5 years without fail.
Buying it again would be pain for the waiting time of delivery from China.
« Last Edit: March 29, 2020, 01:02:06 am by vinlove »
Re: MK-328 LCR Tester dead?
« Reply #1 on: March 29, 2020, 01:42:57 pm »
This is exactly what what happened to my MK-328.
Only difference was mine never came back on even to flicker something on the screen.
Had to order a new one to replace the dead MK-328 :(
Online indman
  • Country: by
« Reply #2 on: March 29, 2020, 06:58:11 pm »
Everything can be repaired if you have sufficient skill and skills to repair such simple devices! :)
I drew an example circuit diagram of the MK-328 clone. Look at it carefully.
If you connected a capacitor with a charge, then first of all it is necessary to check the serviceability of the protective elements, the diode assembly U3 (SRV-05) and the suppressor D1. Remove them from the board and try poweron on the tester again.
The following users thanked this post: vinlove
« Reply #3 on: March 30, 2020, 09:02:08 am »
Thanks for the info and schematic.
Another things that happened with the MK-328 is that when I kept pressing the test button down for a few seconds to see if it will reboot, then it started smoking from the PCB.  I turned it over to see where the smoke was coming from, but it then stopped smoking.  I couldn't tell where it was, but could smell burns.
To be able to repair anything is always great feeling in Electronics. But not sure, if still there is a chance with this kit. Will give a try with the schematic and your info.
« Last Edit: March 30, 2020, 09:04:31 am by vinlove »
Offline Gyro
« Reply #4 on: March 30, 2020, 10:16:58 am »
It's probably the Atmel micro that has fried in that case. A lot of these testers, including the original design, do not have protection diodes. Replacing it and programming  should restore operation.
Best Regards, Chris
