I know there are curious types around here, so I wanted to do this minor tear-down, actually, more a description of the interior of the Spectracom SecureSync unit. There is not really much to disassemble.
I also wanted to test it right away for 100% functionality, and no error conditions. So it has been powered on for a little more than a week now,
and has begun to settle down a bit. It does seem quite sensitive to room temperature change. I live in a canyon, so reception is poor here.
Removing no less than 20 screws just to pop the cover while powered up to try to prevent any fluctuations in performance,
but taking the cover off lowered the temperature severely. I started wondering about the thermal environment it had been designed for.
I think in a very warm rack space. The unit has 6 option slots on the rear panel, but each are perforated with plenty of holes.
So if all 6 option slots are filled with modules, the holes go away, and now added heat from the modules, all keeping it quite toasty inside.
It does have a fan, but according to the instructions you may never hear it cycle on, except briefly at power on. I decided covering the option
blanks with tape to isolate it from the outside air was a good idea. Fan still does not cycle on. Temp slightly higher now, and less fluctuation.
The GPS radio is a Trimble resolution T. The standard 10 mHz OCXO is a Russian made Morion MV-197. It has a Western Digital SSD of 1 GB.
A small computer on board, an SOM-4455 by Advantek, featuring an AMD Geode LX 800 CPU, AMD CS5536 chipset, and 1GB of DDR-400 RAM.
The backup battery is a huge coin cell BR3032. You can see the area of the board for the optional DC power, no fuse installed, and J33 not connected,
2 rather large inductors sitting there as well.
The Rubidium option jacks are there, no info about what that is. Even if you could ID it, Firmware for it would need to be installed.
According to Spectracom there are no upgrades after production. It appears to be a late 2012 production unit. The SSD is dated 9/5/12,
the Morion MV-197 dated 12/28, which is the 28th week of 2012. All in all a pretty interesting, and quite sophisticated unit.
Here's a few photos of the interior, front, and rear. and some screen shots of interest.
