This is what mine looks like, Extron ADA 6 300 MX HV, bit excessive but hey. I was originally going to get it for a Frequency Electronics Inc FE-5680A Rubidium standard, happy with my LUCENT/SYMMETRICOM Z3810AS, KS24361 RFTG/GPSDO instead.
Very nice - you're going to need a lot of equipment to connect to all those ports. btw, have you checked to see how clean the signal coming out is versus what is going in?
I have 5/10/15Mhz references and about half a dozen devices with 10Mhz external reference inputs, haven't done anything yet with it, but I believe the op amps are fairly high bandwidth and should give good results. This model is the more expensive version, though I only paid about $10 for the unit.
Here is a great video by Gerry Sweeney showing the unit. My source signals are very clean, incomparable to what he is using, also I don't have to gut the power supply in my situation. I was thinking of other ideas like on some of the outputs increasing the gain or making some attenuated.
I don't have a SA suitable just FFT on the 100MHz oscilloscope and a low frequency SA. I can't seeing it being too much of a problem though but I'll guess I will find out eventually.
