Author Topic: EDU33212A generator stuck importing data file  (Read 407 times)
Offline AnthocyaninaTopic starter
  • The Sara
« on: November 16, 2022, 04:42:28 pm »
I've previously imported csv files to this generator and after a few seconds, or a couple of minutes of the "importing data file..." message, I'm prompted to either load the newly produced arb file, or do something else. The generator supports up to 1Mpt per user arb file. Today I'm trying to import a file with 380k points to play a short sound clip, and it's been importing for over two hours now, but it still is somewhat responsive, at least bringing the display's brightness back to 100% after a button press. The longest it was stuck in that message before was about 10 minutes with 22k points file. I'm going to leave it on for now while i do some other things i need to do, but in the meantime I would like to know if anyone else has experienced such slow data imports on their waveform generators. Thank you!
  • The Sara
Re: EDU33212A generator stuck importing data file
« Reply #1 on: November 16, 2022, 07:36:38 pm »
almost 6 hours later! it definitely wasn't frozen but wow!  :scared: what other waveform generators take so long to import data from a csv file with 300k points?
