Author Topic: Agilent Keysight 34465A or Fluke 8846A / Tek DMM4050 ?  (Read 2630 times)
Offline djnzTopic starter
« on: November 17, 2016, 04:15:35 am »
For the same price, would you buy a Keysight 34465A or a Fluke 8846A (also sold as Tektronix DMM4050). Could someone help me understand the areas where one is better than the other? For which applications would these differences matter?
Edit: I guess both manufacturers have authorized distributors in my city, who say they will help with any warranty / service matters should the need arise.
« Last Edit: November 17, 2016, 04:49:17 pm by djnz »
Offline TheSteve
  • Living the Dream
Re: Agilent Keysight 34465A or Fluke 8846A / Tek DMM4050 ?
« Reply #1 on: November 17, 2016, 07:28:29 am »
Which is easier to get serviced in your country should the need arise?
I'd rather have the 34465A, mainly because I have lots of other Keysight equipment and it is easier to just use gear from the same company. I also prefer the LCD screen to the VFD.
VE7FM
The following users thanked this post: tangram, djnz
Online nctnico
« Reply #2 on: November 17, 2016, 12:21:34 pm »
I looked into both when I needed a accurate DMM and I went for Keysight. Even though they are equally accurate the Keysight offers more features and has a TFT screen which makes the DMM much more usefull (think about screendumps which can be copied into a report directly).
Offline tangram
« Reply #3 on: January 09, 2018, 09:14:01 am »
had exactly the same question, djnz.  Thanks TheSteve and nctnico for helping make up my mind too. :-)
"All specifications are subject to change!"
Online HighVoltage
« Reply #4 on: January 09, 2018, 09:30:59 am »
I used to have a Fluke 8846A and it was a very good meter.
But the display (VFD) is totally outdated, when you compare it with a 34465A
The 8846A can also do a trend chart on the screen, but when you compare
the two DMM on this aspect alone, you will never use the 8846A again.
I would definitely go with the Keysight DMM.
