i didn't set anything in the meter. the bt was literally the 2nd thing i did after updating the firmware. i'm still going through the manual and i haven't even gotten into the setup module yet. i need to do that now to get the time set--the date was ok.
just went through setup and changed a couple of things. the interval was at '0' which the manual says is 200ms/maximum. i changed this to 6 seconds for now to make calculations easier when i test it.
i connected to the meteor app and set the sample size to 100 but the app didn't seem to honor this cut off and kept counting up. when i set it back to zero it said it had logged 104 items, but by that time the counter had gone up to 170+ or so. very confusing. it was obvious the app didn't honor my 1 every 6 seconds setting, but it didn't seem to be at 200ms either. maybe 400-800ms
perhaps you can tell from the timestamps:
# Source: 121GW 0
# Mode: Voltage Low Z
# Start time: 03/07/2023, 21:06:44.586 CST
Timestamp, Elapsed time (s), Value, Units
21:07:37.536, 52.950, 0, V
21:07:38.048, 53.462, 0, V
21:07:39.036, 54.450, 0, V
21:07:39.547, 54.960, 0, V
21:07:40.056, 55.470, 0, V
21:07:40.535, 55.949, 0, V
/guy
