Author Topic: EEVBlog 121GW Multimeter Firmware Details  (Read 201620 times)
Offline gnif
« on: January 12, 2018, 12:42:41 pm »
Figured this would be of interest to some, I was expecting to see the firmware that this meter came with to be encrypted with at the very least some very basic xor, but turns out the 'EEVBlog.bin' firmware on the SD card is just the plain firmware, with what looks like a calibration file appended to the end of it (cal.dat)
geoff@sarah-xen:~/Projects/121GW$ arm-none-eabi-objdump -D -b binary -marm -Mforce-thumb EEVBlog.bin | head -n 21
EEVBlog.bin:     file format binary
Disassembly of section .data:
00000000 <.data>:
       0:       4b78            ldr     r3, [pc, #480]  ; (0x1e4)
       2:       2000            movs    r0, #0
       4:       2879            cmp     r0, #121        ; 0x79
       6:       0802            lsrs    r2, r0, #32
       8:       0e35            lsrs    r5, r6, #24
       a:       0802            lsrs    r2, r0, #32
       c:       0e37            lsrs    r7, r6, #24
       e:       0802            lsrs    r2, r0, #32
      10:       0e39            lsrs    r1, r7, #24
      12:       0802            lsrs    r2, r0, #32
      14:       0e3b            lsrs    r3, r7, #24
      16:       0802            lsrs    r2, r0, #32
      18:       0e3d            lsrs    r5, r7, #24
      1a:       0802            lsrs    r2, r0, #32
To explain:
0x20004b78 - The main stack pointer
0x08022879 - The reset vector (this is thumb, so the address is actually -1)
... etc
I am yet to look more into this, but it's good news from the point of view of writing custom firmware for the meter.
« Last Edit: January 12, 2018, 01:52:53 pm by gnif »
HostFission - Full Server Monitoring and Management Solutions.
https://hostfission.com/
https://twitter.com/HostFission
Note: I am NOT a moderator or arbiter of disputes, my Admin level of access is so that I can perform management of the server on behalf of Dave. Do not contact me over such issues
The following users thanked this post: SeanB, carpin, dr.diesel, Kean, ChunkyPastaSauce, Iagash
Offline dr.diesel
Re: EEVBlog 121GW Multimeter Firmware Details
« Reply #1 on: January 12, 2018, 12:48:02 pm »
That is good news!
Since we now have a FW thread, my 121 came with v1.01 and I've seen references to 1.02?  Considering the FW resides on the SDcard I guess someone with a 1.02 could post it for us on 1.01 to upgrade.
Offline gnif
« Reply #2 on: January 12, 2018, 12:50:24 pm »
That is good news!
Indeed, mine has 1.01 on it, it would be interesting to compare the two.
Offline Iagash
« Reply #3 on: January 12, 2018, 02:15:08 pm »
I attached version U-1.02 as zip file (at least I hope, since it is from my sd-card).
I suggest not to upgrade from this file. It might contain cal-data only suitable for my meter.
Just use it to compare against your files.
« Last Edit: January 12, 2018, 02:18:17 pm by Iagash »
The following users thanked this post: gnif, dr.diesel, ANTALIFE, ChunkyPastaSauce
Offline amspire
« Reply #4 on: January 22, 2018, 04:21:16 am »
Gnif, from what you currently know, does it look like we can add our own firmware using the existing bootloader and binary update mechanism? In other words, can we load new experimental firmware and easily return to the official firmware?
Offline EEVblog
« Reply #5 on: January 22, 2018, 06:03:07 am »
FYI, as mentioned in another thread, v1.02 has a small bug fix for the calibration SD card import/export feature.
Offline gnif
« Reply #6 on: January 22, 2018, 11:25:33 am »
It seems so, I have been on break though and have not had an opportunity to play more with this yet. If the base address can be figured out there should be nothing stopping custom firmware being flashed into the device, it seems it has a boot loader that then hands over control to the program in ROM, but at this time I can not confirm if this bootloader contains the flash utility.
When I find some more time I will attach to the JTAG port on the STM32 and see what I can do with it, if we get lucky they may have not set the read protection bit and we can dump the entire firmware out. If that doesn't work it shouldn't be hard to compile some code to dump it all out to the SD card or UART, etc...
Note: I am very familiar with the STM32F1xx series chips, they remain my favorite micros, I am excited to see what I can make this meter do.
PS: Thanks for the sticky Dave :)
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #7 on: January 22, 2018, 12:17:40 pm »
It would be very useful for someone to extract the bootloader, as during software development, for speed you'd want to flash the application code directly with a programmer rather than via SD card, but you'd want the ability to put the bootloader back agaon afterwards.
Day Job: Mostly LEDs
Offline amspire
« Reply #8 on: January 22, 2018, 12:27:54 pm »
I am just hoping that the IAP Binary update mode (Turn on with HOLD and MEM pressed) is completely in the bootloader. It would make sense for this to be so.
If it is, we should be able to switch between the official firmware and experimental with the need of JTAG.
Offline EEVblog
« Reply #9 on: January 22, 2018, 01:07:48 pm »
Yes, I believe that's how it works. Stock standard ST Micro IAP bootloader (with code to drive the LCD and buttons). I've taken out the SD card during firmware update and it recovers just fine.
« Last Edit: January 22, 2018, 01:23:08 pm by EEVblog »
Offline tpw_rules
« Reply #10 on: January 23, 2018, 03:13:13 am »
I've set up a GitHub repository for future development and information, located here. The wiki on it is free to edit for anyone with a GitHub account. I plan to upload my IDA database tomorrow or so and work on documenting what I've found on the wiki. If you would like to help, please check out the Questions page. I haven't got my meter yet so I can't answer them.
I've got pretty much the entire thing documented in terms of variables and functions. Some algorithms I don't know yet and would like help with. But there's a hell of a lot of information we can use to start our own firmware, which I also hope to do on perhaps a bit of a longer timescale.
And as I mentioned previously, I have some firmwares edited with bugfixes, if anyone would like to test them out?
The following users thanked this post: EEVblog, gnif, Macbeth, Kean, dcac, newbrain, genghisnico13, bicycleguy, Iagash, hwti, ac1806, joerg_rw
« Reply #11 on: January 23, 2018, 07:09:31 am »
Is it possible to put this information into the very first posting of this thread?
Could be helpful finding it more easily imho.
Thanks.
Offline Mr.B
« Reply #12 on: January 23, 2018, 08:23:54 am »
I don't have my meter yet.
I will be in wave 2 of the shipping (March?).
However, I am very interested in following the firmware thread - bookmarked, so to speak.
Time is the overseer of all things.
Offline Iagash
« Reply #13 on: January 23, 2018, 04:20:14 pm »
Dave, could you provide us with the pinout of the jtag connector, so I could try to read out the bootloader and the option byte values with my ST-Link dongle?
Offline tpw_rules
« Reply #14 on: January 23, 2018, 09:17:45 pm »
I've uploaded the database now. There's a lot more documentation to come too. I will really need y'all's help figuring out the reasoning behind the measurements. If we need to reimplement logging, whatever, but I'd really like to learn how and why the meter e.g. does frequency dependent offset for AC mode. Glance at the Questions page and see if you can figure something out.
By the way, thank you to GitHub users htro for determining the chip and c-MM for finding the clock crystals (though I have a hunch there's still an oscillator somewhere).
The following users thanked this post: Macbeth, Kean
Offline tpw_rules
« Reply #15 on: January 23, 2018, 09:19:41 pm »
I'd bet money it's ARM SWD. I don't think these smaller parts use JTAG. The pin list is in the datasheet somewhere; the meter uses the LQFP144 package. You're looking for SWCLK, SWDIO, NRST, VCC, and GND.
Edit: I know you meant the pin header on the accessible side of the board, but if you have some time this would give the answer without waiting for Dave. Be sure to add it to the wiki!
Offline ez24
  • L.D.A.
« Reply #16 on: January 23, 2018, 09:36:26 pm »
Reading
(Interesting to see what happens with this meter and what members can do with it.  My guess it is going to become a great meter because of the firmware updates  :-+)
Offline Scottjd
    • YouTube Gadget Reveiws
« Reply #17 on: January 23, 2018, 10:08:03 pm »
So what does Dave say, “For those who want to play along at home”....
Well if the picturemin the other thread is correct the this is the data sheet.
It’s the LQFP144 package, page 35 has the pinouts.
http://www.st.com/content/ccc/resource/technical/document/datasheet/58/e3/b5/60/88/c8/4b/1b/DM00034689.pdf/files/DM00034689.pdf/jcr:content/translations/en.DM00034689.pdf
Update: I guess I shouldn’t have kept my post in draft so long, lol. I was busy reading the data sheet myself and forgot to click post.
« Last Edit: January 23, 2018, 10:10:39 pm by Scottjd »
Please be sure to check out my YouTube channel and subscribe if you like the videos. https://www.youtube.com/c/GadgetReviewVideos
By people subscribing and giving thumbs up I know what I am doing is still wanted and adding value, then will continue to release new videos. Thank you for your support.
Offline EEVblog
« Reply #18 on: January 23, 2018, 10:59:21 pm »
Here is the schematic which may help
David2 is working on seeing what we can provide in terms of documentation to help people who want to write their own firmware.
http://www.eevblog.com/files/121GW%20EEVBlog%20Circuit%20diagram.pdf
Offline hwti
« Reply #19 on: January 24, 2018, 01:53:57 am »
The CN2 connector seems to be a debug interface for the BLE module.
Can the STM32 update the bluetooth firmware with the serial port ?
The following users thanked this post: tcottle
Offline Iagash
« Reply #20 on: January 25, 2018, 06:23:34 pm »
I hooked up the 121gw to my st-link and seem to be able to dump the flash.
I also tried to read out the option bytes from the cpu.
The following users thanked this post: benst, tpw_rules
Offline chefkoch84
« Reply #21 on: January 25, 2018, 07:13:21 pm »
I am a backer for the 2nd batch ... and looking forward to the new toy.
I did have some look at the firmware and had it decompiled here:
https://retdec.com/decompilation/
I was surprised how easy and straightforward that was.  - Of course, the code is not very readable... but in combination with know-how on the hardware, it should be possible to have some improvements.
e.g. finding the function for the buzzer should be quite doable.
I myself could not have a very detailed look yet.
p.s. - perhaps somebody finds the source for this firmware on a USB-stick in the dumpster  (next to a 500k$  scope or something ;-)
If so... it would be a very nice move to upload it here...
Edit: if you wanna use the attachments: remove the ".zip" extension from the filenames and process with 7zip. (The forum does not allow bigger files... nor files ending with .7z.001 )
« Last Edit: January 25, 2018, 07:15:23 pm by chefkoch84 »
The following users thanked this post: 3db
Offline Iagash
« Reply #22 on: January 25, 2018, 07:25:05 pm »
Here is the openocd config file I used to dump the data:
# 121gw.cfg openocd config
source [find interface/stlink-v2.cfg]
set WORKAREASIZE 0x4000
source [find target/stm32lx_dual_bank.cfg]
# use software reset
reset_config none
init
reset halt
flash probe 0
Here is how I connected the meter. I didn't use the reset line.
         / 1 Vcc -------- 8 3.3V  \
        |  2 Reset ------ NC       |
121gw - +  3 TMS/SWDIO -- 4 SWDIO  + ST-Link-v2 mini
 CN3    |  4 TCK/SWCLK -- 2 SWCLK  |
         \ 5 VSS -------- 6 GND   /
This way the meter is powered by the ST-Link and you need to make sure to switch it on or the CPU will be kept in reset mode.
I used the LowZ range, but other ranges will probably work too.
Start openocd with:
sudo openocd -f 121gw.cfg
And the connect to it in another terminal with:
telnet localhost 4444
The following users thanked this post: tpw_rules, exe, 3db
Offline tpw_rules
« Reply #23 on: January 25, 2018, 10:24:51 pm »
If I may toot my own horn a little bit, I'm already ahead of you. If you're interested, check it out here and feel free to contribute to the wiki.
Thank you so much for both of those (along with the cal data from earlier) and the detailed instructions you provided on doing it yourself. I've added all three things to the GitHub. By the way, your meter has version 1.02, correct? That's what the dump seemed to indicate.
Offline Iagash
« Reply #24 on: January 25, 2018, 10:59:03 pm »
I'm not sure about these if I did it right. I'll look into them tomorrow with the datasheet to see if they make sense.
This is my first encounter with STM32, I just used AVRs up to now. I'll have to do a lot of reading.
Yes this is correct.
Thank you a lot for your work investigating the firmware! This is very interesting.
I get you are also one of the early backers and you meter is stuck at UEi in the US. If you don't mind a wobbly switch, Dave might be able to poke them a bit to send your meter out early.
Edit:
And also a lot of thanks to Dave and UEi for not setting the readout protection on the STM32! I sincerely hope they don't regret it.
« Last Edit: January 25, 2018, 11:05:52 pm by Iagash »
