Author Topic: Elektro-Automatik EA-3048B Power Supply Teardown  (Read 10824 times)
Offline armandasTopic starter
  • Country: jp
    • My projects
« on: July 07, 2011, 09:28:45 am »
As the title says, this is a teardown of the EA-3048B power supply. There is not much info on the internet about these, so I thought I'd share some pictures and comments.
This is a so-called "universal" power supply. It has two outputs: DC and AC. The DC is not regulated, so you either get rectified or smoothed (using a 4700uF cap) output.
Not much else to say, I guess, so let's look at what's inside.
Front view.
Overview of the insides.
The voltage is controlled using a variable transformer (variac).
Display board.
Binding posts.
Made in China..
There are some more pictures in the album.
These PSUs are sold by Farnell.
Offline saturation
  • Doveryai, no proveryai
    • NIST
Re: Elektro-Automatik EA-3048B Power Supply Teardown
« Reply #1 on: July 07, 2011, 12:53:02 pm »
Thanks,  nice tear down and clear photos.  What does one use variable VAC at these voltages for?  The DC output appears to be just full wave bridge rectification with a smoothing capacitor?
Best Wishes,
 Saturation
  • Country: jp
    • My projects
« Reply #2 on: July 07, 2011, 02:30:24 pm »
In the description, it says that these supplies are good for school labs and such, so I assume this supply can be used to safely reduce mains voltage (instead of using a transformer).
You are right about the DC output. The smoothing capacitor can be switched on and off.
Offline Frangible
  • Contraptioneer
« Reply #3 on: July 07, 2011, 10:49:09 pm »
A nice old school unregulated DC power supply.  Good for testing regulators and for electro-chemical experiments!
Offline Ronnie
  • Country: ph
  • Stimulating your Ears
« Reply #4 on: July 08, 2011, 04:00:52 am »
Made in China..
Looks like the build quality is very good.   8)
  • Country: jp
    • My projects
« Reply #5 on: July 08, 2011, 08:17:19 am »
Made in China..
Can't argue about that. :)
Offline saturation
    • NIST
« Reply #6 on: July 08, 2011, 11:29:50 am »
Its clear China can do very good work if they put their mind to it; I think the brand is German, and they have some very high end PSUs.  My guess is those engineers really enforce their QC!
Made in China..
Best Wishes,
 Saturation
