Pics or it didn't happen
Was in one piece of ceramic?
TonyG
No problem
The contact problems clearly came from the "rubber" contact pads which were not elastic anymore and did not apply enough pressure to give reliable contact.
The good thing was, that underneath the ceramic pcb, they used the same pads for contacting the gnd-plane.
So I simply swapped the yellow marked ones with the red marked, did some contact cleaning with IPA and now the contacts are perfect again for the next 25 years.
(pictures shows state after exchange)
