Author Topic: eLoad in transient mode  (Read 524 times)
Offline FaringdonTopic starter
« on: March 08, 2023, 01:34:57 pm »
Customer sent us a 37V single stage PFC'd Flyback of 230W (6.2Aout) Peak. 150W (4.1Aout) average.
37Vout.
We sent it no_load_to_full_load transients of time length 13.5ms. (using SDL1030X E-load in resistance mode, but pulsed)
The eload was 10k for 5.013 seconds, then 6.5R (5.6A) for 13.5ms, repeatedly.
Every 7th , or so, pulse, the Flyback dropped out and went below 8Vout for 8 seconds, then recovered.....for all the other load transients, the vout just dipped down to ~28V and back up to 37V (in 17ms).
Do you think the eload struggles to "get into regulation" at the start of the transient pulse?.....ie, it might have been a lot less than 6.5R when it was first applied, and would have drawn a much_higher_than 5.6A current?
SDL1030X ELOAD used...
https://siglent.co.uk/jg/wp-content/uploads/2021/08/Siglent-SDL1000X-Electronic-Load-Datasheet.pdf
P.S. (or did we just catch it at the mains zero crossing)
'Perfection' is the enemy of 'perfectly satisfactory'
Offline alm
Re: eLoad in transient mode
« Reply #1 on: March 08, 2023, 02:10:21 pm »
Connect a current probe or current shunt between PSU and load and measure with a scope. That will show you exactly how the load is behaving in your system. Cable length (lead inductance and capacitance) may matter.
The following users thanked this post: Faringdon
