Author Topic: Enabling options for R&S test equipment  (Read 224435 times)
Offline oe6mhe
  • Country: at
Re: Enabling options for R&S test equipment
« Reply #450 on: April 05, 2026, 03:34:43 pm »
I added a list of all available options. The calculations of the CMU200 have
been used. You can see what is missing - the matching K-codes are working!
Offline ve7xen
    • VE7XEN Blog
« Reply #451 on: April 07, 2026, 05:45:21 pm »
Can you provide a list of all the k-codes for CRTU-RU?
73 de VE7XEN
He/Him
Offline oe6mhe
  • Country: at
« Reply #452 on: April 07, 2026, 05:49:54 pm »
Please see above the screenshots. In the "System Identity" it does only export the active K-codes,
so the only chance was to take photos.
I basically used the CMU200 calculations (SWOPT.DAT) in my CRTU-RU. The ones given by your
generator that were matching with the CRTU are shown working. The missing ones not, of course.
So, if you could create a separate button for "CRTU", based on the same calculation as the CMU200,
I am happy to test it with my unit to verify it works.
Thanks
Michael
« Last Edit: April 07, 2026, 05:56:59 pm by oe6mhe »
Offline ve7xen
    • VE7XEN Blog
« Reply #453 on: April 08, 2026, 06:58:34 am »
I was hoping you had the numeric values for the named options.
I've added a selector for model which should auto populate the options listed in your screenshots (except the named ones, which I do not have the numeric value for).
73 de VE7XEN
He/Him
Offline oe6mhe
  • Country: at
« Reply #454 on: April 08, 2026, 11:44:38 am »
The named values depend on the hardware of the unit (meaning MAC SPEECH, USU, LINKHANDLER etc)
Some K-options that depend on hardware are activated too, but not available. AMPS hardware is not yet
completetly installed, I am still waiting for a B41 board. With that, I am sure AMPS will also work in the unit.
But all the listed K-options are enabled now, your generator works :)
Thanks
Michael
Offline meckarmulle
« Reply #455 on: April 12, 2026, 06:15:06 pm »
Hello,
Has anyone managed to create keys to unlock the options in FSH4?
I have one with number /004 with no options installed
Offline oe6mhe
  • Country: at
« Reply #456 on: April 12, 2026, 07:26:33 pm »
Hello,
have you tried to generate FSP keys and checked if they work?
Otherwise I would use the "general" generator and test it
Regards,
Michael
Offline carver
  • Country: nr
« Reply #457 on: April 12, 2026, 08:49:30 pm »
If the online generator doesn't help,
can always contact the owner of the
FSH4,ETL,FSL,FSV,SMA100A,SMF100A,
TSME,TSMW,ZV(A/B/T),ZVH4.
« Last Edit: April 13, 2026, 01:30:41 am by carver »
/carv
Offline matthieu.e
« Reply #458 on: April 15, 2026, 09:36:43 am »
Is this keygen working with the R&S Spectrum Rider FPH ? Thanks
Offline carver
  • Country: nr
« Reply #459 on: April 16, 2026, 01:31:44 pm »
no.
/carv
Offline karen9820
  • Country: am
« Reply #460 on: Yesterday at 04:58:17 pm »
Hi All, i have rheavendors sagoma h5-h7, i need controller hex code, can you help me please ?
Online tv84
  • Country: pt
« Reply #461 on: Yesterday at 05:52:27 pm »
I may have a dump from a Magic Wand. Is it any good?
