Author Topic: Enabling options for R&S test equipment  (Read 61085 times)
Offline tv84
  • Country: pt
Re: Enabling options for R&S test equipment
« Reply #175 on: February 17, 2019, 09:15:27 pm »
K4 I don't know. The device I had was too old and didn't support that option. Just try them one after another and you'll probably find it.
Let me try clarify some things  (although I don't know much about this).
The list of options extracted from FSP firmware v4.50 API.DLL is the following:
K5     GSM/EDGE Application                 GSM K5 ANALYZER               FSPSpectrumAnalyzerLI
K7     FM Demodulator                       FM DEMODULATOR                FSPSpectrumAnalyzerLI
       #1
       #2
K84    1xEV-DO BTS                          1X EV DATA ONLY BTS           FSPSpectrumAnalyzerLI
K85    1xEV-DO MS                           1X EV DATA ONLY MS            FSPSpectrumAnalyzerLI
K90      FSQ WLAN 802.11a                   WLAN                          FSQ-Wlan(LI)
K72      WCDMA 3GPP FDD BTS                 WCDMA BTS ANALYZER            FSPSpectrumAnalyzerLI
K74      WCDMA HSDPA BTS                    WCDMA HSDPA BTS               FSPSpectrumAnalyzerLI
K75      WCDMA HSDPA MS                     WCDMA HSDPA MS                FSPSpectrumAnalyzerLI
K9     Power Meter                          POWER METER                   FSPSpectrumAnalyzerLI
K73      WCDMA 3GPP FDD MS                  WCDMA MS ANALYZER             FSPSpectrumAnalyzerLI
K90      FSP WLAN 802.11a                   FSP WLAN                      FSP_Wlan(LI)
K90UP    FSQ WLAN 802.11a,b,g               WLAN UPGRADE
K76    TD-SCDMA BTS                         TD-SCDMA BTS ANALYZER         FSPSpectrumAnalyzerLI
K77    TD-SCDMA MS                          TD-SCDMA     MS ANALYZER      FSPSpectrumAnalyzerLI
K30    Noise Figure                         NOISE MEASURE                 FSx-Noise(LI)
K82    CDMA2000 BTS                         CDMA2000 BTS                  FSPSpectrumAnalyzerLI
K83    CDMA2000 MS                          CDMA2000 MS                   FSPSpectrumAnalyzerLI
K8     Bluetooth                            BLUETOOTH                     FSPSpectrumAnalyzerLI
K40    Phase Noise Measurement              PHASE NOISE MEASURE           FSx-PNoise(LI)
K70    Vector Signal Analysis               VECTOR SIGNAL ANALYSIS        FSPSpectrumAnalyzerLI
       #3
K50    Triggered Coverage Meas              TRIGGERED COVERAGE MEAS
K51    Synchronized Stepped Sweep           SYNCHRONIZED FREQ LISTS
       %d days remaining trial period       TRIAL PERIOD 180 HRS
K0     %d days remaining trial period       TRIAL PERIOD 2000 HRS
K91      FSQ WLAN 802.11a,b,g               WLAN ABG                      FSQ-WlanExtension(LI)
       #5                                   FREQ LIMIT 31 GHZ
B%s    Frequency Extension                  FREQ NO LIMIT
K92      FSQ 802.16                         FSQ 802_16                    FSQ-Wman(LI)
K52    Transducer Set                       REG_TP
K53    FFT Scan                             FFT SCAN
K901   %d days remaining trial period       TRIAL PERIOD 2500 HRS
K902   %d days remaining trial period       TRIAL PERIOD 3000 HRS
K92UP    FSQ 802.16e                        FSQ 802_16 UPGRADE
K93      FSQ 802.16e                        FSQ 802_16E                   FSQ-WmanExtension(LI)
K903   %d days remaining trial period       TRIAL PERIOD 3500 HRS
K904   %d days remaining trial period       TRIAL PERIOD 4000 HRS
K100     LTE FDD Downlink                   LTE FDD DOWNLINK              FSx-LTE FSx-LTE(LI)
K101     LTE FDD Uplink                     LTE FDD UPLINK                FSx-LTE FSx-LTE(LI)
B29    Frequency Extension 20Hz             FREQ EXT 20HZ
K15    Avionics Demodulator                 AVIONICS DEMODULATOR          FSPSpectrumAnalyzerLI
K91N   FSQ WLAN 802.11n                     WLAN 802 11N UPGRADE          FSQ-Wlan80211n(LI)
K94    FSQ 802.16e MIMO                     FSQ 802_16 Mimo UPGRADE       FSQ-WmanMimo(LI)
K102     LTE Downlink MIMO                  LTE DOWNLINK MIMO             FSx-LTE FSx-LTE(LI)
K103     LTE Uplink MIMO                    LTE UPLINK MIMO               FSx-LTE FSx-LTE(LI)
K96    OFDM-VSA                             OFDM-VSA
K74+     WCDMA HSPA+ BTS                    WCDMA HSPA+ BTS
       #4
K400   RFEX-F Launcher                      RFEX-F
K17    EX IQ Box                            EX IQBOX                      FSx-ExIqBox(LI)
K110   TETRA 2                              TETRA2                        FSQ-Tetra2(LI)
K10      GSM/EDGE/EDGE Evolution            GSM/EDGE ANALYZER             FSx-Gsm(LI)
K73+     WCDMA HSPA+ MS                     WCDMA HSPA+ MS
K104     LTE TDD Downlink                   LTE TDD DOWNLINK              FSx-LTE(LI)
K105     LTE TDD Uplink                     LTE TDD UPLINK                FSx-LTE(LI)
K106   LTE TDD/FDD Upgrade                  LTE TDD/FDD UPGRADE
K5UP     GSM K5 Upgrade to K10              GSM K5 ANALYZER UPGRADE       FSx-Gsm(LI)
K150   Support for User Calibration         USER CAL SUPPORT
They are ordered according to the seeds table (used in the prog to generate licenses).
Also, in that .DLL we can extract a more complete seed (uint32) table than the one used in the original prog (post #7). I attach it below.
Those that are using the program should add the new seeds because they may be needed to enable other Options.
The FSH Option names can be extracted from the FSH firmware's API.DLL. If anyone sends me a current FSH API.DLL I might extract the complete list of Options.
When adding the Option seeds you should also make them TRUE so that all possibilities are calculated.
Offline goaty
« Reply #176 on: March 14, 2019, 03:55:14 pm »
For FSH3, I looked into the update file which contains GALAXY.ldf, GALAXY2M.ldf and GALAXY3G.ldf.
Seems there is an easteregg there:
Mines left: %d
Time: %3d
Best time: %3d
Lives: %d
Score: %d
HighScore: %d
Waiting for opponent...
Congratulations, you won!!
Ouch, you lost!!
Your fleet
Opponents fleet
Drop bomb...
Watch out for incoming...
Expose a part of one of your ships...
Offline fisafisa
« Reply #177 on: April 27, 2019, 08:31:15 pm »
HI
I have got an AMIQ waveform generator.
I tried with the options generator but no luck.
Looking at the manual it would seem that the options here are only 8 characters long.
Anybody has an example of option code (together with the serial number)
Maybe it is possible to figure out the algorithm.
Thanks
Offline sky2city
  • Country: cn
« Reply #178 on: June 12, 2019, 05:56:32 am »
Hey Guys,
I have a ZVR, SN is 835068/005. and I found the SW sn  \R_S\INSTR\INI\OPTOIN.INI
Is't anyone know how to decode it?
4056071223; EMBED DEEMBED
0436723430; TIME DOMAIN
1234299954; CONVERTER 4 CHAN
Offline sky2city
  • Country: cn
« Reply #179 on: June 12, 2019, 06:44:17 am »
       #1
       #2
       #3
       #4
Hi tv84,
I attached a API.DLL form a ZVR.  could you decode the option from it?
Offline carver
  • Country: nr
« Reply #180 on: June 12, 2019, 12:06:33 pm »
Hey Guys,
maybe
feat_0 = 'HARMONIC MEAS', 'B3', 'Harmonic Measurements'
feat_1 = 'MIXER MEAS', 'B4', 'Mixer Measurements'
feat_2 = 'NONLINEAR MEAS', 'B5', 'Nonlinear Measurements'
feat_3 = 'REF MIXER PORTS', 'B6', 'Reference Mixer Ports'
feat_4 = 'POWER CALIBRATION', 'B7', 'Power Calibration'
feat_5 = '4 PORT MEAS', 'B99', '4-Port Measurements'
feat_6 = 'QUARTZ MEAS', 'BXX', 'Quartz Measurements'
This is an old public algorithm.
test Feat_2+, if all OK - test b3-b4 too,
in newer devices - these numbers(0 or 1) used for demo.
now r&s used new long key.
many know how to create new too,
but no one wants to share it to public ))
sn: 835068.005  id: 00 option key: 1542267991  desc: feat_0
sn: 835068.005  id: 01 option key: 2797899109  desc: feat_1
sn: 835068.005  id: 02 option key: 2277388772  desc: feat_2
sn: 835068.005  id: 03 option key: 2328386865  desc: feat_3
sn: 835068.005  id: 04 option key: 0302356071  desc: feat_4
sn: 835068.005  id: 05 option key: 3024766616  desc: feat_5
sn: 835068.005  id: 06 option key: 4252011699  desc: feat_6
sn: 835068.005  id: 07 option key: 4056071223  desc: TIME DOMAIN, B2, Time Domain Measurements
sn: 835068.005  id: 08 option key: 0436723430  desc: CONVERTER 4 CHAN, C4C, 4 Channel Converter
sn: 835068.005  id: 09 option key: 1234299954  desc: EMBED DEEMBED, K9, Virtual Embedding Networks
sn: 835068.005  id: 10 option key: 0493488890  desc: feat_A
« Last Edit: June 12, 2019, 12:21:04 pm by carver »
/carv
Offline tv84
  • Country: pt
« Reply #181 on: June 12, 2019, 09:29:24 pm »
Hi tv84,
I don't think so. Do you have examples of options for that equipment?
Offline sky2city
  • Country: cn
« Reply #182 on: June 13, 2019, 04:25:03 am »
Hi tv84,
I double checked with ZVR manual, the only K option for ZVR is K9 only, there is nothing to do with this unit.
So I am looking in another one, FSEA30. the datasheet say the K option for FSEA is:
FSE-K4  Phase Noise Measurement Software,
FSE-K3  Noise Measurement Software
FSE-K10 GSM Test Software, Mobile
FSE-K11 GSM Test Software, Base Station
FSE-K20 GSM Test Software, Edge Mobile
FSE-K21 GSM Test Software, EDGE Base Station
FSE-K30 GSM Test Software, 850 GHz band Mobile
FSE-K31 GSM Test Software, 850 GHz band Base Station
Just decoded the SN using "Rohde & Schwarz FSP option generator".
Notice: that I decode all  seeds, the comment "Kx  xxxx Application Firmware" is not correct, it's for FSP
3780795724 - K5  - GSM/EDGE Application Firmware
0284552823 - K7  - AM/FM/PM Measurement Demodulator
4196994763 - B17 - IQ Online
0684125256 - None
1514211661 - K84 - 1xEV-DO BTS Application Firmware
0579586646 - K84 - 1xEV-DO MS  Application Firmware
3285910640 - None
1332515167 - FSP-B15 FSP-B70 FS-K7
1746004935 - K72 prior K74
0425836556 - None
3914572062 - K9  - Power Meter
0367944746 - FSP-B15 FS-K7
0178533596 - None
0084427020 - None
0973137605 - K76 - 3GPP TD-SCDMA BTS Application Firmware
4058089560 - K77 - 3GPP TD-SCDMA MS  Application Firmware
2816669065 - K30 - Noise Figure Measurament
0774785927 - K82 - CDMA2000 BTS Application Firmware
1251526595 - K83 - CDMA2000 MS  Application Firmware
0364322959 - K8  - Bluetooth Application Firmware
3912188941 - K40 - Phase Noise Measurament
2043795852 - None
2216559242 - None
3509799288 - None
0667766505 - None
2179962388 - 31 days trial period
4232888520 - 78 days trial period
1998016984 - None
1665344687 - None
0081926458 - Frequency Extension
1876889287 - None
2554963261 - Trasducer Set
0989643314 - None
1367083121 - None
2589261327 - None
3754352886 - None
2349723378 - None
2713318677 - None
0242151735 - None
3807482493 - None
2651669256 - None
0586577237 - None
3525044770 - None
0034228987 - None
1143727560 - None
2616543767 - None
1636617207 - None
0959025083 - None
1318982380 - None
2600577035 - None
compare with the options.ini in my FSEA. the fisrt line is the "FSE-K10 GSM Test Software, Mobile".
Options file in my FSEA:
3780795724; GSM MTS ANALYZER
My question is which line of the SN is for other option?
FSE-K4  Phase Noise Measurement Software,            ??????
FSE-K3  Noise Measurement Software                     ????????
FSE-K10 GSM Test Software, Mobile                       3780795724
another thing I found is that there is no API.dll in my FSEA30. I search all *.ll in hard disk, it seems that "FSEFPNL.DLL" is the suspect one.
« Last Edit: June 13, 2019, 04:31:10 am by sky2city »
Offline sky2city
  • Country: cn
« Reply #183 on: June 13, 2019, 04:28:09 am »
Hey Guys,
maybe
Got it. thanks for your reply. :)
Offline sky2city
  • Country: cn
« Reply #184 on: June 13, 2019, 04:40:25 am »
I have a R&S ZVB8 2 port Vector Network Analyzer, but I can't see any options file (SWOPT.DAT or similar). Under 'Info', no files are loaded that indicate which file it could be.
I could really use the ZVAB-K2 Time Domain option - does anyone have any good suggestions? The serial-number is 6-digits.
To be honest, I can't even see where I would load a valid software option key.
Hi Jacod,
I don't have the ZVB yet. I download the firmware  form RS and than extract all files.
there is a DLL file "OptionKeyServices.dll", I guess this Dll is work for the option key.
for the SW option key, you should search *option*.* or *opt*.* in D disk. in my ZVR, it's "Option.ini".
and check the serial-number on "info" hard key manu.
Offline sky2city
  • Country: cn
« Reply #185 on: June 13, 2019, 02:58:25 pm »
Hi Jacod,
I went through the "OptionKeyServices.dll", it seems that some fuction is base on OpenSSL 0.95 lib.
But I can't find the where the key hidden.
Stuck here ....
« Last Edit: June 13, 2019, 03:53:53 pm by sky2city »
Offline sky2city
  • Country: cn
« Reply #186 on: June 16, 2019, 07:08:57 pm »
 I did some Reverse Engineering of OptionKeyServices.dll. it show that the OptionKeyServices.dll always access the Register table of windows.
Maybe the Option key is store in register table.
Pls. check reg table on:
HKEY_LOCAL_MACHINE\SOFTWEARE\Rohde&Schwarz\......
Offline vk3st
« Reply #187 on: June 29, 2019, 06:49:02 am »
Hi all,
Still frustrated trying to get several option running on our radio club ZVH.
Really wanting to activate K1, K9 and K39.
I did have a contact with a guy in Russia but the expected cost was way way beyond the budget by many orders of magnitude and was probably more based on a commercial proposition.
Have tried all the options with variations mentioned in these pages to no avail.
If someone does have a key gen stored away and can provide me with activation codes for Ser No 102660/24 I would be prepared to pay a fee or donate a suitable sum not being a kings ransom for the service.
If there is such a person, pm me at vk3st@ian-foster.com please.
Offline carver
  • Country: nr
« Reply #188 on: June 30, 2019, 09:57:36 am »
as I wrote above,
many have access to R&S tools, me too.
but no one wants to share this tool to public, as R&S too.
/carv
Offline mbirth
« Reply #189 on: June 30, 2019, 11:35:41 am »
Quote from: vk3st on Yesterday at 08:49:02
Did you also try the tool from comment #7 but with only the first part of your serial number? (Have to edit the serial number in the source code, then compile and run. Make sure to also set all the options in the source code to TRUE first.)
Offline vk3st
« Reply #190 on: July 07, 2019, 10:00:26 am »
Hi, can you pm me with RS tool info please?
Info@ian-foster.com
Offline vk3st
« Reply #191 on: July 07, 2019, 10:06:50 am »
I looked. At it and could not seem to get it to compile without error.
What is recommended compiler please and sorry but has been many years since compiling scripts etc so am a bit slow in this area.
Offline larry42
« Reply #192 on: July 27, 2019, 06:27:38 am »
I've been reading through this thread - anyone know the situation with the more modern series of R&S equipment (e.g. RTE / RTO series of scopes).
R&S seem to base their designs on a couple of platforms, with occasional "mid-life" upgrades of the underlying HW (and OS - usually embedded Windows of some kind). The RTE / RTO platform is common and Win7 / Win10 embedded. with license key support for temporary and time limited licenses as well as portable licenses and license de-activation.
Anyone confirm whether these can be played with?
If you have an animated GIF in your avatar or signature then I reserve the right to think you're a dolt.
Offline carvalhoatx
« Reply #193 on: August 01, 2019, 09:10:02 am »
Hello Folks, anyone who has working with RTO scope oscilloscope (model 10 24 ) ? If so, could you help me. I tried to save the x-y axis waveform in .csv.
When I tried it, only the y-axis (voltage was salved). I need also, the Time axis. How to set to both ? I tried to find that "basic" info with manual, but there is no it....
Or it doesnt work to that Oscilloscope? kind regards  for comments,
Offline little.tesla
« Reply #194 on: August 06, 2019, 05:44:18 pm »
Hello,
did anybody try to enable options for signal generators like SMIQ, SME?
I did try different combinations on a SME which expects a 6-digit activation key without luck. The serial number is same as the others xxxxxx/xxx.
Any hints are highly appreciated.
BR,
 Dimce
Offline darkstar49
« Reply #195 on: August 09, 2019, 12:04:48 pm »
to my knowledge, no one has succeeded so far hacking any recent R&S scope (incl. RTO's, which have their crypto stuff on a smart card inside the scope, btw), although I'd like to be wrong ! RTB & RTA firmware files/updates are encrypted, and I've never seen anything able to decrypt those either... (which would be a starting point for further 'research'...)
Offline tv84
  • Country: pt
« Reply #196 on: August 09, 2019, 01:27:07 pm »
I would guess they can once the owners want to... No one seems interested in opening his precious.
Offline KaneTW
« Reply #197 on: August 09, 2019, 01:39:44 pm »
Yeah, I have a RTB2004 but it's a fully optioned 5k instrument. Not touching that unless someone has a spare with a busted frontend or something and I can experiment with it.
Offline analogRF
« Reply #198 on: August 09, 2019, 03:38:29 pm »
Hello,
BR,
 Dimce
may I ask what options on SMIQ/SME you want to enable? I don't know how it can be done but if there is any useful option that can be hacked
I would be very interested to do it. As I remember most of the 'good' options are hardware options for which you need a HW module. Software options were not many and they didn't seem very interesting to me at least
« Reply #199 on: August 10, 2019, 06:40:19 pm »
I have here at the moment only a SME where I would like to play a bit with the POCSAG Protocol (pagers) option SME-B42. The required hardware options are available. There are as well B41 and B43 software options which are at the moment not of interest for me.
As far as I can tell for the SMIQ the options >B42 (Digital Standard IS-95 CDMA) and >K11 (Digital Standard IS-95 CDMA) are software options. I think they just require the modulation coder/data generator and memory.
How good is your i960 assembly? :)
