Products => Test Equipment => Topic started by: LPaul on April 24, 2016, 07:33:02 pm
I am currently building my small semi-pro electronics lab.
Usages:
Short-term needs:
- dc power supply repair and design
- Noise on <=100khz SMPS
- <20MHz logic (serial, little to no parallel)
- analog troubleshooting (simple stuff on furnace control boards and engine control boards)
- No to precise voltage and current measurement, ...
Long run:
- <=100Mhz logic (FPGA, 32bit MCU)
Current equipment:
- soldering stuff (hakko)
- "lab" PSU
- el cheapo Handheld multimeter
Based on that I made a basic list of the equipment I consider buying.
Oscilloscope: DS1054Z (planning on unlocking software options). The most bang for bucks as far as I know. Though I am afraid it will soon be limiting and hard on the eyes. Not sure I need 4 channels and there is a lot of good options in the €500-2k 2ch range.
I’d really like to get a good brand (Keysight, Lecroy, R&S) if I can fit an appropriate model in my budget.
Signal generator: Rigol DG1022 (non-A) €300
Seems more than good enough for my needs (100s khz square). Maybe other brands have cheaper/better options for this price?
DMM:
Main use on digital circuit. Might get used on high power circuits (main, 3ph), not quite sure whether a €50 or €100 meter is good enough in terms of input protection.
I have budgeted about €200 in test leads and accessories.
From this base I have about €900 to improve whatever is worth it. (a bit more if necessary).
Obviously not paying VAT and considering an rebate.
Any ideas/advices ? Questions I should ask myself before buying the stuff?
Thanks !
If you can spend 500 to 2k euro on a scope look at the GW Instek GDS2000E series.
Feeltech makes some nice low-cost function generators (see the other threads) so for less than 100 euro you can have a nice function generator nowadays.
For use on mains I recommend to get an A-brand (Keysight, Fluke, etc) multimeter with the proper CAT ratings and at least 4.5 digits. This will set you back about 200 euro.
Good HP/Agilent/Keysight lab PSUs can be bought from Ebay and there are good deals for those with a bit of patience.
Definitely the most bang for the buck. I think you'll take a while to outgrow it.
If you're 100% sure you don't need four channels then you might want to look at the R&S 1002 (https://www.eevblog.com/forum/testgear/new-hmo-1002-economy-dso-from-rohde-schwarz-hameg/) as well:
https://www.youtube.com/watch?v=WvepxIvy45U (https://www.youtube.com/watch?v=WvepxIvy45U)
It's desirable scope, it's small, it's silent ... but it costs about 800 Euros and the 100MHz bandwidth (http://shop.rohde-schwarz.com/mea/hamegrhv512.html) and serial decoder (http://shop.rohde-schwarz.com/mea/hamegrhv110.html) options aren't free. It's well within your budget though.
DMM:
Choosing a multimeter for mains work is easy: Get a Fluke 101.
Only $42 (http://www.ebay.com/sch/i.html?_nkw=fluke+101) delivered to your door and as much input protection as you'll find on any handheld multimeter (it's currently the leader in the robustness testing (https://www.eevblog.com/forum/testgear/hear-kitty-kitty-kitty-nope-not-that-kind-of-cat/) thread)
Now that "mains work" is covered you have a much wider choice for a second meter for the digital work.
(You should probably get at least two multimeters anyway. :popcorn: )
