Author Topic: ET5410 Electronic Load mod: add external sense  (Read 24636 times)
Offline cybermausTopic starter
Re: ET5410 Electronic Load mod: add external sense
« Reply #50 on: September 16, 2021, 05:38:08 am »
I have made a small mod for the (too loud) fan.
I use a lot 40°C Thermal Switch (Normally Open) for many devices which have too loud fan (I don't know the real name of this component).
Hmm, that is not a bad idea. Simple enough.
It's just called a thermostat. Probably this model uses a simple bi-metal switch.
Next time I order some stuff I should have some come along.
Can I suggest to you that you put some sort of isolation on the scews for the heat-sinc stands?
They are connected to the Red (+) terminal. One small dent in the side, and you are shorting the latter to ground.
I just put some felt pads between the screws and the sides. It not only isolates, but also helps prevent dents and reduce vibrations.
Offline ceut
« Reply #51 on: September 19, 2021, 12:35:35 pm »
Hello,
Thank you for your great advice !
I have teardowned again my ET5410 because I have received an Arctic F8 fan (airflow=31CFM), to try it inside.
And you are totally right ! :-+ The (+) is on the heatsink  :-\
In fact, it is because there are no thermal isolation pad between the mosfet tabs and the heatsink (maybe the heatsink is a part of the current sinking :-? )
So I have put 2 pieces of ductape on each of the 2 opposites screws.
For the F8 Fan: it is a failure  :-[ the airflow is too low  :-\
I have checked all good PC fan brands (Noctua, Arctic, Coolermaster, Antec, bequiet and other brand) and I can't find any that matches the one inside (I have looked for a 0.35A / 4.2W fan at 4000rpm).
I have ordered a little UT363 to check the airflow, but I'm stuck.
Mine has an horrible metallic noise when it's rotating: I think there is a bad ballbearing inside.
Fortunately the "thermostat" saves me  :-+  (it is a simple bi-metal switch as you say=>there is a very little "clic" like a relay when it is activating)
If someone has an idea to replace the 80mm fan inside ?
Edit: I have ordered a Arctic "P8" version: it is the high static pressure version, to try it...
« Last Edit: September 19, 2021, 12:52:35 pm by ceut »
Offline vav
  • Country: sk
« Reply #52 on: March 15, 2022, 01:08:24 am »
Hi, I'm the new owner and I made some adjustments. I placed the
1.USB port on the front panel
2. I added terminals for 4W measurement
3. I added a 2W / 4W switch
English is not my native language, I use a translator.
The following users thanked this post: DaneLaw
« Reply #53 on: March 17, 2022, 09:50:36 pm »
looks nice.
The following users thanked this post: vav, Curious
Offline T3TRIS
    • T3TRIS
« Reply #54 on: March 13, 2023, 04:24:49 pm »
Well, I'm reviving this one, hopefully!
I bought an East Tester ET5410A+ DC load and have been using it for testing LiFePO4 battery builds. It has worked fine so far and has been useful for capacity tests. However, one of these capacity tests is pointing to an issue with battery I made, and I now want to test individual cells. The issue that brings me here is the voltage sense wires. They aren't critical for an assembled battery with BMS but for single cell tests, it's a pain. I had started a 40A load test on one cell, telling the load to stop at 2.5V. However I quickly noticed the 0.5V voltage drop between the cell terminal and the load (using 6AWG cables and crimped lugs).
Anyhow, I now want to do this voltage sense wire mod, but apparently the A+ version of the ET5410 doesn't look friendly to that!
I can solder some wires to banana plugs, but to be honest, finding where to solder on this board seems to be above my pay grade.
Has anyone ever figured this one out?
I also sent an email to East Tester directly to see if they can assist.
Thanks
« Last Edit: March 13, 2023, 05:06:18 pm by T3TRIS »
Offline Hotcooler
  • Country: ru
« Reply #55 on: April 02, 2023, 01:59:59 am »
Did you get any reply? In theory there is a compenstation function that seem to work on videos, have you tried it?
Offline T3TRIS
    • T3TRIS
« Reply #56 on: April 02, 2023, 07:34:22 am »
Oh I have not!! I didn’t know this was a thing (didn’t see a video). What I’ve done so far is use oversized wires and decrease the amperage toward the end of the test, which reduces the voltage drop. I’ll have to find that video, thanks!
Offline Hotcooler
  • Country: ru
« Reply #57 on: April 02, 2023, 10:57:56 am »
Here you go : https://youtu.be/pT5kuc2fNRQ?t=1778
I have one on order, since it was.. very attractively priced compared to the older version or even the DL24E in a resonable setup, so yet to test that myself.
Offline T3TRIS
    • T3TRIS
« Reply #58 on: April 03, 2023, 12:24:08 am »
So simple! Thank you for sharing. I’ll test it when I get back home.
Offline kawal
« Reply #59 on: April 11, 2023, 11:55:02 am »
Post some more pictures of the board with focus on the area close to the metal bars.  Shine a light behind the board to  see the traces. Most likely the voltage measurement is in the area of the op amps close to the metal bars.  There are probably some tiny traces going away from the bars area to measure voltage.
Offline kawal
« Reply #60 on: April 28, 2023, 06:33:50 pm »
Anyone want to do the remote on ET5410+ this is how:
Cut traces going to the terminal
Solder wires to resistor pads as shown . Other side will be your sense connections.
The following users thanked this post: edavid, andobovsayvkub
Offline mawyatt
« Reply #61 on: April 28, 2023, 06:50:11 pm »
If these are cut/opened don't you run the risk of having unknown voltage sensing without the sense cables connected?
Would think a safer approach would be to add some series R of equal value, maybe 1K, in each leg where you would have the opens, then wire the sense terminals as you've shown. If the sense cables aren't attached or fall off you still have voltage feedback, and if the sense cables are utilized they short out the 1K added resistors to compensate for the load current carrying cables.
Anyway, just some thoughts.
Best,
~Wyatt Labs by Mike~
Offline andyB2022
« Reply #62 on: April 28, 2023, 07:24:36 pm »
How I would do it, First cut the traces mentioned by kawal, now we have an open middle point (the place we cut) from the lef of the cut run 2 wires to the middle conection of a DPDT switch, then from one of the switch positons run wires back to the side going to the resistors (right of the cut) and another pair of wires (using the last contacts on the switch) towards an external connector. I would do it with a BNC.
Cost-effective and reliable.
Here is how my ET5410 looks:
« Last Edit: April 28, 2023, 07:29:48 pm by andyB2022 »
« Reply #63 on: May 01, 2023, 01:10:03 pm »
Those new A+ versions of the EastTester. What firmware version is it, and did anyone manage to get to the FLASH and download it?
Offline andyB2022
« Reply #64 on: May 28, 2023, 07:14:11 am »
Did you manage to get the flash?
« Reply #65 on: May 29, 2023, 05:29:24 am »
No, and also looking at the buttons a bit better, it's clearly different hardware, so the firmware would not work.
Still, what is, and who has, the latest firmware for the old model.
The latest mentioned here is  v1.02.2030 (year 20, week 30), but I do not even have that, I have V1.0.1942 (year 19, week 42)
Offline DaneLaw
« Reply #66 on: May 29, 2023, 04:31:12 pm »
Got one of the old ones' just in the final weeks before the new (A) was the norm, but it was from Banggood from their EU store, when they cleared EU stock at attractive prices, so the unit I got' could have been in storage for some time.. - it arrived with this FW&SW.  (8 pictures down)  https://tinyurl.com/4ujvpybv
But its usually bag'ed for mobility, in lack of a dedicated lab bench.. https://tinyurl.com/yc64xbmp
Offline andyB2022
« Reply #67 on: May 29, 2023, 04:43:57 pm »
Is there any way you could try to dump the firmware off the STM32? I need it for my unit...
Offline DaneLaw
« Reply #68 on: May 29, 2023, 06:30:32 pm »
Hi Andy, I saw your comment about your issue, but extracting the fw of the STM32 is sadly not something I can help you with.
Have you tried to contact East Tester?
This seems to be their sales email.
sales1@east-tester.com
Phone
+86-13396517215
+86-571-56770221
Offline andyB2022
« Reply #69 on: May 29, 2023, 06:55:34 pm »
Yeah, no response so far.
Offline DaneLaw
« Reply #70 on: May 29, 2023, 07:32:26 pm »
If you do not hear back through email, then try the telephone (it's quite cheap these phonecalls to CN nowadays) and have your details ready, like serial number  etc, and emphasize that the phone support starts a case on your behalf, and ask for that case/journal-number, so you have something tangible to build on, if you have to call back, as otherwise, you can risk they just sing you a tune, on how they "love you long time, & will get back to you" and never do, and you have to start over and explain it all again to the next phone support worker.
Offline andobovsayvkub
  • Country: ru
« Reply #71 on: March 16, 2024, 11:35:24 pm »
Hello. I just made a connection for 4 wires on 5410A+. I cut the traces and simply added a 22 ohm resistor between +V and +SENSE. Setting more then 20 Ohm will lead to an measurement error with 2-wires, and low values will cause voltage drop with 4-wires.
This made it possible to use both a 2-wire connection and a 4-wire connection without adding a switch. The standard behavior of the device has not changed.
Yes, it is possible that a voltage error may occur with a 2-wire connection but no more than 1 in the last digit on the screen. Tested in the range of 5-60V, 0-25A. And it still measures absolutely accurately with 4-wires connection. Also thinking of diode protection, but later.
part of original
2076389-0
new one
2076383-1
appearance
2076371-22076377-3
And one more moment. The motherboards have been replaced due to a transistor that burned out on the first day. And I can't remember if the "software sense" function worked correctly when measuring the resistance of the wires connected to the battery or to other weak source.
The line resistance measurements are correct with a laboratory power supply. But when I try to measure the line resistance with the battery connected, I get incorrect data as the source voltage has a drawdown. Is it like this for everyone or is the new board also defective?
That was my the main reason to transfer it to 4-wires schema.
« Last Edit: March 16, 2024, 11:38:23 pm by andobovsayvkub »
The following users thanked this post: edavid, MF-jockey
Offline ceut
« Reply #72 on: May 21, 2024, 09:58:06 pm »
Hello,
So your mod does not need any switch to choose between 2-wires or 4-wires ?
I see this is a newer model than mine.
I have modded mine today, after so many years :-DD (fan mod previously)
Thanks to @cybermaus mod  ;)
The mod was not really hard, and the 3 holes positions were already spotted on the back.
I don't know why I have not made this before  |O
Here are some photos I have made, for my original ET5410  :-+
The following users thanked this post: Curious
Offline klausES
  • Restore Sony ES/Esprit era
« Reply #73 on: June 19, 2024, 02:47:37 pm »
Hello,
just found yours here in search of a load in this price range and last but not least, i would like (also in optical) the ET5410A+ better than a KP184
I have already read a lot about him but did not find a menu function for calibrating, e.g. with the KP184.
Have I just haven't read it or is there a calibrating not possibility of the ET5410A+ ?
« Last Edit: June 19, 2024, 02:49:16 pm by klausES »
regards klaus. "Art is when you can't do it ... because if you can, it's not art"
« Reply #74 on: June 21, 2024, 09:54:51 am »
I'll have a look later, busy now. But honestly, I suspect not, the menu is not all that good. Though, mine is old now, there has bound to be some newer version.
All in all, the device works, and I use it quite often, but I am only expecting 2 digits of precision.
The external sense however is still very important. You really need to either have HUGE cables and clamps, or correct for the cables voltage drop.
