Author Topic: Rigol DG1022Z Function Generator Hack  (Read 14992 times)
Offline dublindevilTopic starter
  • Country: qa
« on: April 11, 2018, 01:36:59 pm »
I recently purchased the Rigol DG1022Z function generator. It has a bandwith of 25MHz and so far, it has worked perfectly for my needs. Mostly out of curiosity, is there a hack to upgrade the bandwidth on the generator up to the 60MHz of the 1000$ 1062Z?
Here is the listing on the rigol site:
https://www.rigolna.com/products/waveform-generators/dg1000z/
-Dub
Offline Holes Flow
Re: Rigol DG1022Z Function Generator Hack
« Reply #1 on: April 22, 2018, 12:42:41 am »
Count me in to this question as "Me, too!"
Offline Gandalf_Sr
« Reply #2 on: April 22, 2018, 09:05:49 am »
I wondered the same thing.  I have a DG4062 and a DG1022Z, apart from a few button differences and the fact that the DG1022Z screen is about 1/4 the size of the DG4062, the functionality is almost identical between them.
That makes me wonder if Bandgap's work here https://www.eevblog.com/forum/testgear/dg4000-a-firmware-investigation/100/ is relevant? Perhaps someone could try to insert the DG1022Z model and serial number and see if the compile works?  When I tried this for my 4062, I could not make the online compiler work.
Perhaps we could ask Bandgap to get involved?
Having said that, as far as I can tell, all you would gain is higher frequency sine waves and a deeper AWG memory, I haven't needed either yet.
If at first you don't succeed, get a bigger hammer
The following users thanked this post: Holes Flow, toboxo
Offline BLF Lexel
« Reply #3 on: May 25, 2019, 02:54:58 pm »
You can hack the DG1022Z to 1062Z the same way a DP832 can be upgraded to DP832A
You need to enter telnet command and have a USB flash driver with a file on it
I used the Rigol Bildschirmkopie Tool to do so, but CMD works as well with telnet
http://peter.dreisiebner.at/rigol-bildschirmkopie/index.htm
I tried Bildschirmkopie only via Network, maybe someone makes it work with USB, but this needs correct IVI drivers to send commands
Step 1
Activate Telnet in your windows features and restart PC
Step 2
connect the function generator to the network
check if connection is good with ping
also a firewall may cause problems even with ping working, the DG1022Z I could only get sent SCPI commands on a very old standalone PC in my basement shop
step 3
get a FAT formatted USB stick and write the keyfile.bin in the main directory
https://www.eevblog.com/forum/testgear/need-help-hacking-dp832-for-multicolour-option/?action=dlattach;attach=696567
Step 4 with Bildschirmkopie
- start it
- ctrl+E to do a search on the network and connect the Rigol device
- search for devices and choose the one you want to unlock
- open SCPI commands
- check device signature
- send SCPI command with new Model name
- reboot device and check again device signature
step 4 with cmd
- start telnet
telnet [IP_Address] 5555
- same commands as with Bildschirmkopie to write new device number
« Last Edit: May 25, 2019, 03:02:24 pm by BLF Lexel »
The following users thanked this post: twdotnet, theirishscion
Offline Gandalf_Sr
« Reply #4 on: June 08, 2019, 09:49:11 pm »
I got this to work using telnet commands, it's explained here for the DP832 and DG1022Z
https://www.eevblog.com/forum/testgear/need-help-hacking-dp832-for-multicolour-option/msg2470974/#msg2470974
The following users thanked this post: theirishscion
« Reply #5 on: June 08, 2019, 09:56:36 pm »
Well that's the next hour of my life sorted  :-DD ... will see if it works on my DG1022Z now.
« Reply #6 on: June 08, 2019, 10:55:48 pm »
It worked! Will post reply on other thread.
Offline nichrist
  • Country: gr
« Reply #7 on: February 06, 2021, 08:37:37 am »
Hi to all
I use the above info to "upgrade" a DG1030Z to 1062 successfully. I am wondering now if it is a good idea to upgrade the firmware from 00.01.11 to the latest v03.01.12.00.00 downloaded from Rigol site. Is the 1062 will be still running? Have anyone try it ?
Regards Nick
Offline jcoello
  • Country: pe
« Reply #8 on: August 27, 2021, 04:42:22 pm »
Hi everyone,
I was trying to update my DG1032Z to DG1062Z but I couldn't because always the "error generated by remote interface command" message appeared. Finally I had success! The problem has that I was using incorrect USB pen drive format, I've tried with FAT, FAT32 but nothing worked until use FAT format specifying  Allocation unit size to 512 bytes I did on windows 10 [ CRLT + R, CMD, format x: /fs:FAT /v:rigol /A:512 ]  reemplace x with your volumen label (I used a 2gb pen drive). Thank you very much to everyone!.
The following users thanked this post: twdotnet, bd139
Offline kosmos
« Reply #9 on: November 26, 2023, 07:57:16 pm »
Should you enter your own serial number again after ":PROJ:STAT MODEL,DG1062Z " or rather at ":PROJ:STAT SN,DG1ZA000000000" ?
