Author Topic: First impressions on Rigol MSO1074Z and Rigol MSO2072A  (Read 45782 times)
Offline marmad
  • Country: aq
    • DaysAlive
Re: First impressions on Rigol MSO1074Z and Rigol MSO2072A
« Reply #75 on: November 25, 2014, 10:26:42 am »
Started testing the MSO1074Z today. First thing I tried was seeing if Frame recording captured the Digital channels (it does) - and whether it could decode the Frames while playing them back (it can't). It appears you can't turn on Decode while in Frame playback - and you can't turn on Record if you have Decode turned on.
One neat feature I did discover (which I don't believe is available on the MSO2000 series) is Plot. When selected, the "change trend of the bus data will be displayed in vector mode" (as the Manual puts it):
Offline msraya
  • EA7EE
« Reply #76 on: November 25, 2014, 05:44:35 pm »
Wow, I not tried Parallel decoding yet.  :clap:
It seems to me that this way I can plot the output of an ADC very easily..
Interesting.
Thank You!
Manuel
Offline Teneyes
« Reply #77 on: November 30, 2014, 11:45:30 pm »
Just a Note to show Displaying of 2 frequencies with delayed triggering
Note , Select SourceA or SourceB in order to adjust Trigger level for each Chan
IiIiIiIiIi  --  curiosity killed the cat but, satisfaction brought it back
