Author Topic: rohde&schwarz FSH spectrum analyser pin code  (Read 3516 times)
Offline JelbertTopic starter
« on: February 16, 2024, 01:08:56 am »
I might be able to get my hands on a FSH18 spectrum analyser. However I now read on R&S website about a Master PIN code. Before I go and invest in a device I can not test in advance. Is there a way to circumvent this PIN once I have the device?
Offline drhex
Re: rohde&schwarz FSH spectrum analyser pin code
« Reply #1 on: February 18, 2024, 11:23:41 am »
Original master code is on the calibration certificate. If the PIN has been set and you don't get that along with the device only R&S can reset it. Ask the seller if he can switch on and operate the device, if that works no PIN is set and you will be fine.
