Author Topic: feeding uCurrent output to an ADC  (Read 894 times)
Offline riforifo
  • Country: tr
« on: September 24, 2018, 01:49:42 pm »
Hello,
I use a Ref200 to generate a 100uA current source and read 99.5 mV with a multimeter.
For a quick test, I also connected the uCurrent output voltage directly with an arduino ADC.
I get varying results between 60mV and 110 mV.
I'll add an moving average algorithm but aside from software,
What are your recommendations for connecting uCurrent output to an ADC
I can try adding an amplifier in  voltage follower mode. Your recommandations are highly appreciated.
thanks
Offline ogden
  • Country: lv
Re: feeding uCurrent output to an ADC
« Reply #1 on: September 24, 2018, 01:56:21 pm »
Hello,
thanks
Number one recommandation: match sensor output voltage range to ADC input voltage range. Only then you will have highest resolution of sensor data measurements.
Offline bson
« Reply #2 on: September 24, 2018, 08:14:42 pm »
Look for sources of noise.  The DMM will have an anti-image filter, while a naked ADC pin doesn't.
