Author Topic: Tek 2467B Options  (Read 860 times)
Offline Ground_LoopTopic starter
Tek 2467B Options
« on: March 29, 2021, 07:18:22 pm »
Do any of you know how options are implemented on the 2467B?  Specifically, is the counter option in the ROM firmware, or is there circuitry associated with it?  I have a parts mule with counter option that I would like to implement in another.
There's no point getting old if you don't have stories.
Offline ps
Re: Tek 2467B Options
« Reply #1 on: March 29, 2021, 09:30:19 pm »
Counter and/or TV trigger is an extra PCB sitting between power supply and CPU board. There might be a Lemo socket at the back for an optional word recognizer trigger probe
GPIB is a smaller PCB left to the PSU. Both GPIB and CTT options are connected to the CPU board with a 40 pin flat cable on the top.
« Reply #2 on: March 29, 2021, 09:45:13 pm »
I see it now.  Thanks.  So, If I pull this board out and put it in another scope do you know if there are any enabling jumpers or settings to make it active?
Offline Testtech
« Reply #3 on: April 01, 2021, 12:13:11 am »
The CPU will recognize the options, but note that the boards are s/n range specific.
