I bought a Tenma dual supply from one of the kind folks on this forum, and to save space on my desk I put the power supply on top of my CRT (but digital storage) oscilloscope.
Turning it on I noticed the display jump and rotate towards the upper right, as the supply made a kind of metallic 'pop' noise when I turned it on.
Doing it again seemed to move the display back closer to the center, and again further still, but it still sits kind of wonky.
I've moved the power supply away, at least 20cm or so, and no longer in the same orientation, but the problem still persists. Not every time I turn it on, but I can see the display jump on occasion.
Clearly it must be the H-field from the supply transformer but I never really gave it a thought, since I didn't expect test gear to have that much of a problem sitting near other test gear (magnetic shielding etc where necessary). But now, I'm starting to worry about damaging my poor 9400A from doing this too often.
Is there something strange going on here? Or has this pitfall of CRTs just escaped me all this time?
Also, is there any easy way to degauss this thing? What kind of field strength would be required?
