Author Topic: Hacking Rigol DS6000 series oscilloscopes  (Read 2317 times)
Offline gearedbybyTopic starter
  • Country: cn
« on: January 03, 2019, 02:30:00 pm »
hello,i get a rigol DS6000,i want to hack the decode option .i saw the keygen only support the ds1000z ds2000 ds4000 ,maybe nobody link to disassemble this series?let us make a keygen?
« Last Edit: March 21, 2019, 08:44:45 am by gearedbyby »
  • Country: cn
Re: Hacking Rigol DS6000 series oscilloscopes
« Reply #1 on: January 04, 2019, 02:39:38 pm »
No one is interested in this? |O |O
Offline DaJMasta
    • medpants.com
« Reply #2 on: January 04, 2019, 06:33:42 pm »
I don't think a ton of people have one, so the interest is probably limited because of that.  It's only been a day though, you may get a few users who show up...
That said, it's usually a small minority of owners of the hardware that both want to hack it and have the skills to make it happen, so unless you want to do it yourself, I don't think the chances are that high.
  • Country: cn
« Reply #3 on: January 05, 2019, 02:51:16 am »
ok,thks,I will try it first. :-//
Offline tv84
  • Country: pt
« Reply #4 on: March 02, 2019, 05:40:53 pm »
As we can easily see in the riglol thread, the DS6000 has a similar licensing scheme to the DS2000.
The private_key is the same as the DS2000. That is visible in the riglol main.c code and in the .GEL.
So you can use riglol to generate the key and I think the best Option combination is the same as the DS4000 - RS39
