Author Topic: FeelTech FY3224S 24MHz 2-Channel DDS AW Function Signal Generator  (Read 372312 times)
Offline Aldo22
Re: FeelTech FY3224S 24MHz 2-Channel DDS AW Function Signal Generator
« Reply #600 on: October 16, 2024, 07:48:37 pm »
I did some further testing and have come to the conclusion that the problem is not due to the signal generator. With one of my oscilloscopes (Owon VDS1022i) I did a scope and probe calibration and now the Vpp I measure stays at 5Vpp through the entire frequency range up to 21MHz.  |O
However, you should not expect the amplitude to be held until the end.
The specified limit is usually -3dB. This means that if you have 0.707V from 1V at 24MHz, this still meets the specifications (or 3.6V from 5V)
I have run my script on the DSO2000 to show how this looks for the FY3224s.
That should be roughly correct (Right scale is irrelevant).
« Last Edit: October 16, 2024, 07:51:06 pm by Aldo22 »
The following users thanked this post: nikbry
Offline nikbry
« Reply #601 on: October 16, 2024, 08:06:03 pm »
Thanks Aldo,
I'm aware of the -3dB spec and was expecting the signal attenuation at the end of the bandwidth spectrum as you nicely show in the graph.
From what I could observe today, the attenuation for the sine wave became obvious at around 20-21 MHz, which roughly matches your data.
It's been an unfortunate sequence of events, that have led me to wrong conlusions all along. The very first checks of the generator I did the very first day with the Owon scope were fine, and I did not see the strange attenuation effect. A few days later I tried with the Zotek and saw strange things happening even in the KHz range. Checked again with the Owon and the signal looked attenuated too, so I started suspecting the generator. I believe the Owon must have lost calibration and the Zotek's probe is probably not reliable.
I'm glad the generator is working as it should, and the Owon when calibrated can be relied upon.
I have a work trip coming up and wont be able to "play" some more with the Feeltech for the next days, also need to look into the Zotek probe issue when I get back.
Cheers!
« Last Edit: October 16, 2024, 08:12:24 pm by nikbry »
Offline BrokeEngineering
  • Country: bg
« Reply #602 on: December 14, 2024, 07:18:51 am »
Can someone give me the spacing for the PCB mounting holes on the OEM power supply? I am going to be making a PSU module for it and mine has not arrived yet :)
Offline Aldo22
« Reply #603 on: December 14, 2024, 01:34:46 pm »
As this is probably a general-purpose housing, there is some kind of hole pattern (Attached is a picture of the top, it is the same with the bottom).
I measure 6cm x 3.8cm (or 3.75cm) without guarantee.
« Last Edit: December 14, 2024, 01:38:27 pm by Aldo22 »
  • Country: bg
« Reply #604 on: December 14, 2024, 01:46:46 pm »
Thank you very much, is that hole to hole or to the end of the stubs? Looks like M3 size to me
Offline Aldo22
« Reply #605 on: December 14, 2024, 02:00:26 pm »
Hole to hole, of course.
M3: This has no thread, you simply choke a wood screw into it.
  • Country: bg
« Reply #606 on: December 14, 2024, 02:41:44 pm »
I was thinking single 2 tap 12V 5W transformer that goes into the PCB into a full wave bridge rectifier (With proper caps ofc). The +12/-12 can be from the LDO's direct, and for the 5V I will make a high efficacy, low EMI buck down to around 6.5V for the 5V LDO. Will be quite cheap, probes BOM + single PCB around 10USD. I can filter the output of the BUCK for even less EMI, it wont be much added cost. I wonder if 5W will be enough.
  • Country: bg
« Reply #607 on: December 14, 2024, 02:42:59 pm »
I got M3 brass inserts, if the hole is M3 I can just melt some in the plastic so its a better fit/ M2 outer brass diamater needs to be between 2.8 and 3mm, for m4 I think it was around 4mm. Too much trouble to check the hole diameter please?
Offline Aldo22
« Reply #608 on: December 14, 2024, 03:41:33 pm »
Don't you think you're exaggerating a bit?
The FY3200 is OK as it is for the price, but I wouldn't invest much time in “improving” it.
I have taken a photo (top view) for you.
You know that the longer hole spacing is 600mm, so you can calculate everything else from the photo.
I think it's about 2.2mm (from the photo).
I can't measure it to the micrometer anyway.
« Last Edit: December 14, 2024, 03:48:49 pm by Aldo22 »
  • Country: bg
« Reply #609 on: December 14, 2024, 04:16:37 pm »
I am not trying to improve it, I am trying to make it safe, I live in Eastern Europe and Earth is tied to neutral. So running a wire to the plug earth does nothing. Using a Linear AC transformer with LDO's is the only real way to get no leakage voltage on the BNC's
  • Country: bg
« Reply #610 on: December 14, 2024, 08:58:55 pm »
Hmm I wonder if the + and -12V rails are accurate enough on this
  • Country: bg
« Reply #611 on: December 18, 2024, 12:54:00 am »
Welp I finished the PSU,
Here it is if anyone has anything to comment/improve before I order it:
Schematic
Pcb View
3D Top
3D Bottom
« Reply #612 on: December 18, 2024, 01:07:05 am »
Consider changing the layout in some areas to make the PCB more friendly to repair/rework hand soldering.
  • Country: bg
« Reply #613 on: December 18, 2024, 01:10:32 am »
I am using 0805, that's as friendly as I can make it haha. I normally use 0402.
Also just did BOM cost. Its 10 USD BOM
And PCB is 2 layer less then 100*100 so each PCB comes to around 1.2 USD.
So call the entire board less then 12USD.
Which part do you think its not easy to repair?
All parts are over-specced by a minimum a factor of 2 so there should be no need to repair lol.
« Reply #614 on: December 18, 2024, 01:17:04 am »
L3 = rotate
R2&3 = move
  • Country: bg
« Reply #615 on: December 18, 2024, 01:21:15 am »
L3 = rotate
R2&3 = move
R2 and 3 are feedback resistors that need to be placed close as possible to feedback pin in order to have correct and stable feedback.
L3 is a filter inductor and moving it anywhere will increase ground loop of other components.
Thanks for the suggestion though. I will post the project files and gerbers so you can fork it and make the mods if you think its hard to solder :)
« Reply #616 on: December 18, 2024, 01:24:49 am »
L3 = rotate
R2&3 = move
Then consider moving the other components that restrict access to R2/3.
  • Country: bg
« Reply #617 on: December 18, 2024, 01:31:25 am »
L3 = rotate
R2&3 = move
Better?
  • Country: bg
« Reply #618 on: December 18, 2024, 04:20:42 pm »
Made a version with Earth Connection between 2 Y capacitors after the CM Choke and a bit more safety aspects.
This is mainly for the people that already have an 3 pin earthed connector fitted.
There is a few more changes, its a bit bigger but based on the pic and some image measuring software it should still fit :)
  • Country: bg
« Reply #619 on: December 20, 2024, 11:24:35 am »
After a bunch more tweaking, I think its ready.
Fixed some routing, added a filter for the +12V rail and added an Parallel damped filters to all the LDO inputs where there was a bit of a peak at around 20khz due to the filter:
The following users thanked this post: ledtester
