Author Topic: Field Fox question for an owner (power supply)  (Read 182 times)
Offline akamomo
« on: October 20, 2020, 05:51:46 am »
Hi!
Picked up a used Field Fox and can't suffer for the $165 Agilent branded power adaptor if not necessary.... I see its 15VDC 4A, can someone tell me the dimensions of that connector so I can get a sane adaptor and get started with the new toy please?
Thanks so much!
Offline akamomo
Re: Field Fox question for an owner (power supply)
« Reply #1 on: October 20, 2020, 06:10:47 am »
newbie searches... think I might have found it
https://www.eevblog.com/forum/testgear/u1620a-power-supply-specs/msg3058628/#msg3058628
I believe this may work? 0950-5014 is certainly available used so seems worth trying.
The Fieldfox is model N9912A btw if it wasn't clear... though fairly sure it's the same all models.
Thanks again I'll still take any added info re a 3rd party adaptor sure to work.
Online TheSteve
  • Living the Dream
« Reply #2 on: October 20, 2020, 07:34:52 am »
Why not buy yourself the real thing - https://www.ebay.com/itm/293721061834
I hope your fox has some good options installed.
VE7FM
