Thanks to all that responded to the Beeper issue:
I should have mentioned that in my previous post, I mentioned contacting tech support in China, actually I did contact tech support in Schenzen (headquarters) who provided a confirmation of items for when the "beeper" should be heard and it should be loud enough to be plainly heard on the bench when pressing buttons, touching the screen.
To Sorama: No hearing problem, I have my hearing checked every 6 months, and it's ok, thank goodness.
To: 2N3055: Yes, I am expecting a clicking sound.
I of course did a Default setting and still heard nothing. Upgrading the firmware to the latest (1.1.6.7) for the 1000X-HD series also seemed to make no difference.
To my surprise I did the following:
Looking at the front of the scope, I put my head and ear to the left-side airflow vents, and sure enough I could hear a clicking every time but it is barely audible, and if I moved my head in a certain position, the clicking could not be heard, move it back to a different position and the click could be heard; It clicks as I expected, on touching the screen, pressing buttons, or making menu selections.
So the problem is no longer that the "the beeper doesn't work" but rather the volume level is so far down that it cannot be heard. I even had a few associates see if they could hear the beeper and they could not.
The question becomes would it be worth it to somehow amplify the existing beeper or replace what seems to be a faulty beeper. Of course, I could send it back to the distributor for a replacement unit (I only have it now for 2 days), but I suspect that after having the same issue with 3 scopes so far, that even a replacement could result in the same issue. In fact, I asked Siglent North America (I'm in the US) tech support about it and they said even a replacement is no guarantee (!) that the beeper will be any different(!). So much for quality control. Yeah, the beeper clicks, but unless you put your ear and head right at the left of the scopes air vents, it's inaudible in a totally noise-free room.
Any further comments or suggestions appreciated.
Thanks for all the input.
