Author Topic: Rigol DM3058 no LAN Ethernet  (Read 2216 times)
Offline cubitusTopic starter
« on: July 03, 2015, 05:35:38 pm »
Hello,
I have a problem with the device RIGOL DM3058 (Rigol Technologies, DM3058, DM3L162450050,01.01.00.02.01.00)
The entire device seems to work fine except the Ethernet connection.
I tried with 3 different network cables, the connection is not established.
The LEDs do not light on the plug.
Will there a trick to fix this?
Is a failure?
Thank you
RIGOL DM3068, DG4062, DP832A MSO4014
FLIR E4 SSA3021X Plus
Offline DD4DA
Re: Rigol DM3058 no LAN Ethernet
« Reply #1 on: July 05, 2015, 07:04:47 pm »
Open a ticket to Rigol at the local representive - they are fast and helfull.
« Reply #2 on: July 06, 2015, 10:49:39 am »
I sent the device warranty.
