Author Topic: REVIEW - Rigol DS2072 - First Impressions of the DS2000 series from Rigol  (Read 1199747 times)
Online EEVblog
A wiki is a good solution for this kind of thing.
I don't have time to maintain one, which tends to be everyone's problem with this kind of thing, but if someone wants to step up and manage the content I am willing to host one.
It could go on the EEVblgo wiki, but of course someone needs to maintain it and organise it which is a massive job to do it properly with different pages for all the issues and content that interest people.
Offline Carrington
Wow! No doubt, is a massive job, unfortunately I do not have experience with these things. Apart from that I have little free time.
But surely, no shortage of brave people that want collaborate. Go it!  :clap:
My English can be pretty bad, so suggestions are welcome. ;)
Space Weather.
Lightning & Thunderstorms in Real Time.
Offline Carrington
Could someone explain to me why 50,000 wfs are only reached at 20 ns and it decrease to lower base time? It is due to software, hardware or both.
Thank you very much.
Cheers.
Space Weather.
Offline Hydrawerk
I think it is mainly due to hardware... Well, they have no custom ASIC.
Offline Carrington
Yes is possible, and therefore the gds-2000a series uses a [[500Ms ADC x2] x2] to reach about 100,000 wfm/s. But I do not understand why the Rigol DS2000 not keep the 50,000 wfm/s for time base < 20ns.
This could be improved via firmware?
« Last Edit: July 17, 2013, 02:53:40 pm by Carrington »
Space Weather.
Offline CodyShaw
    • My Blog!
This is a great idea for the site, and for anyone interested in making the DS2000 community a better place. We would be able to keep the forum to resolving issues rather than documenting.
Candidate for Bachelor of Applied Science, Electrical Engineering, University of Waterloo, Waterloo, ON, Sept. 2011 – Present
3A Electrical Engineering
Offline marmadTopic starter
  • Country: aq
    • DaysAlive
You don't have your facts straight: the GDS-2000A only does it's 80k wfrm/s maximum with a 200MSa/s rate - 10 times lower than the 2GSa/s maximum - so 10 times lower the BW. In fact, at 2GSa/s, with it's small 1k sample size, the 2000A is not significantly faster than the Agilent or Rigol (it does a max. ~55k) - and likely slower when using the 1M sample size (no one has done tests yet).
Also, the GDS-2000A series update rate drops dramatically < 50ns - much more than the Rigol.
« Last Edit: July 17, 2013, 09:43:27 pm by marmad »
Offline Carrington
You don't have your facts straight: the GDS-2000A only does it's 80k wfrm/s maximum with a 200MSa/s rate - 10 times lower than the 2GSa/s maximum - so 10 times lower the BW. In fact, at 2GSa/s, with it's small 1k sample size, the 2000A is not significantly faster than the Agilent or Rigol (slower at many settings) - and likely slower when using the 1M sample size (no one has done tests yet).
Wow mate! I believe you.  :)
I rely on this table:
http://www.ittsb.eu/GDS-2102A%20Wfms%20measurments.html
And: Let me be clear, I am delighted with the DS2072.
« Last Edit: July 17, 2013, 09:48:01 pm by Carrington »
Space Weather.
  • Country: aq
    • DaysAlive
That upper table is nonsense - Kiriakos didn't use the correct measuring equipment for measuring < 50ns - he claims the DSO is much faster than even Instek claims it is.  ;D
You can see the real wfrm/s @ <50ns in Grego's video when he uses a Picoscope to measure the frequency.
Here is a table comparing the update rates and sample rates of the Rigol (w/14k) and the Instek (w/1k). I'd love to see someone measure the Instek's rate when it's using 1M sample length - I think the Rigol would beat it with 1.4M:
Offline Carrington
Thanks for the information marmad. Spectacular the fall for t <50ns.
Could you please explain to me why 50,000 wfs are only reached at 20 ns and it decrease to lower base time?  It brings me head  ^-^
Could be the Wfrm/s improved via firmware?
Space Weather.
  • Country: aq
    • DaysAlive
Something to do with the way that Rigol has tuned the system. If you look at wfrm/s rates of other DSOs, it's not uncommon for the speed to reach a peak at a certain time base, then drop off.
I doubt it (at least, not by much); I'm sure Rigol has already spent much time working to get as much speed as possible out of the design.
Offline CodyShaw
    • My Blog!
Just unpacked my 2072!
Looks like it's running Software Version 00.00.01, and Hardware Version 1.0.
Offline Carrington
Thank you very much marmad, I had seen this Application Note, and the truth is that Rigol has done a good job.  :-+
I am impressed with the DS2072.
I compared it (at 20MHz BW) with an old analog HP1222A, from the viewpoint of noise and refreshment, and the refreshment in both screens is very similar (as far as my eye can discriminate). And in both the noise level is very low for a BW of 20MHz. Awesome!
With the DS4000 series also occurs this fall for t<20ns? You have a table?
Space Weather.
Offline Carrington
Mine:
  Software version: 00.01.01
  Hardware version: 1.0
Yours is fast and loud?  :-DD
« Last Edit: July 17, 2013, 11:12:10 pm by Carrington »
Space Weather.
Offline CodyShaw
    • My Blog!
Mine:
What do you mean by that?   ::)
Offline Carrington
CodyShaw:
Nothing bad, I'm just kidding, my apologies.  :)
In my DS2072 the fan is quite noisy (loud). But here the temperature is 30 ° C, perhaps the fan is regulated by temperature (fast).
"Let the future tell the truth ...
« Last Edit: July 17, 2013, 11:31:45 pm by Carrington »
Space Weather.
Offline Carrington
Grego's video (See  at ~ 12 min):
Space Weather.
Offline CodyShaw
    • My Blog!
CodyShaw:
Thought so! :-DD
Mine is noticeable, but not loud. Cold basement (24 degrees or so)?
Offline CodyShaw
    • My Blog!
Sorry, I didn't check my FW correctly...
Actual:
SW: 00.00.01.00.05
HW: 1.0.1.0.0
Offline UberSteve
Hi All!
New DS2072 owner here! Unit arrived today from Emona Aus. Unit is apparently new stock just arrived from China and reports the following info in the System Information screen:
Serial: DS2A15270XXXX
Software version: 00.01.01.00.02 (latest I believe?)
Hardware version: 1.0.1.0.0
FPGA version:
 SPU 03.01.05
 WPU 00.06.05
 CCU 12.29.00
 MCU 00.05
Huge step up from my Bitscope...  :D
Thanks to all that have contributed to this thread, it's the main reason I decided on the DS2000.  :-+
-Steve
« Last Edit: July 18, 2013, 10:10:46 am by UberSteve »
Offline Carrington
To UberSteve:
What model of probes was bringing?
Space Weather.
Offline darrylp
To UberSteve:
As in are they rp3300 or rp3300a ?
The "a" version are not switchable between x1 and x10
 Darryl
Offline CodyShaw
    • My Blog!
To UberSteve:
 Darryl
My DS2072 I got yesterday came with the switchable RP3300 probes.
IIRC, you got the 3300A probes?
That is very lame on Rigol's part.
Offline jsykes
Hi All!
FPGA version:
 SPU 03.01.05
 WPU 00.06.05
 CCU 12.29.00
 MCU 00.05
-Steve
Congrats! Yours is VERY new. That 27 in the serial # denotes it left the assembly line the 27th week of the year, (a bit over 2 weeks ago) They must be shipping them air freight to your area.
« Last Edit: July 18, 2013, 04:55:35 pm by jsykes »
Offline Carrington
How about if we create a topic about the new/future verison/model of the Rigol´s oscilloscopes?  ^-^
Including: DS1000-Z, DS2000-S, DS2000-Z, etc.
With specifications, rumors and other.
What would be the suitable name for this topic?
« Last Edit: July 18, 2013, 05:14:25 pm by Carrington »
Space Weather.
