Anyone else has troubles using the rotary encoder right to the menu button? it really is sensitive
everytime I just press it, it registers a rotation
for example: I try to select a different probe ratio. turning is is kinda sluggishly jumping to the next value, sometimes it skips 2 or 3
and when you push it after it's successfully on the correct value it jumps to the next value and selects this before the menu closes
it wouldn't be a bad idea if Rigol would make it possible to ALSO use the up/down buttons below to select something in the menu that's currently open (instead of the menu below it)
Yes I agree, and here is a message I sent to Rigol NA
Here is some feedback on an annoyance that I have encountered with the DS2072.
When using the Multi-function Knob after rotating the knob to my desired selection, I press the Knob, but
I have selected the incorrect pick, options, or letter, I end up picking the one before or the after!!!
This has occurred more than 10 times in the 2 days since I received the Rigol DSO
Please understand that I have Large Hands
(a 250 Lbs. Canadian Mohawk) and as I push the Multi-function Knob
the Knob
turns a bit just before the Push switch is engaged/sensed.
I am not Asian with Diminutive Digits that can Discern Delicate Details.
I am suggesting the amount of rotation to jump to the next selection be a bit larger, and as such the few more degrees of rotation should not be detrimental to the easy of operating your Product.
Also
When I am Trying to select the letters in a file name from the menu of horizontal letters
then once the letter is Highlight with a Orange Box
when I push the Multi-function button the letter orange box moves.
I have checked the rotation and 6 letters change in 90 degrees rotation
that is 1 letter change in only 15 degrees of rotation ( 24 letters /rev)
NOW the top on the Knob is only 0.375 Inches in diameter
Therefore a movement of only 0.05 inches ( 1/20 of an inch) will cause the letter to Change
I seriously think this is too sensitive of an Adjustment!!!!!
Here is Rigol's response
I do. Thank you for the explanation.
Your measurements are exactly as I experience,
but I don't seem to have the same issue with the usage.
My letters are selected as expected.
I have had this trouble with some of our other scopes....
and it has to do with how I was pressing the multi-function knob.
I was actually rotating it a bit when I pressed.
I will submit that suggestion as an improvement.
Also, here is the license to reset the trial software options:To Avoid any rotation of the Multi-function knob during selections,
I have design a new Rigol Selection Tool.
See the Thumbnail picture below.Feel free to grow your own.
