Author Topic: REVIEW - Rigol DS2072 - First Impressions of the DS2000 series from Rigol  (Read 1199498 times)
Offline Galaxyrise
Re: REVIEW - Rigol DS2072 - First Impressions of the DS2000 series from Rigol
« Reply #2100 on: January 07, 2014, 04:35:25 pm »
How are you getting a continuous trace of closely spaced dots?  You should be seeing only one dot per horizontal division (1 ns/div, 1G samples/second).
Looks like hi res acquisition
I am but an egg
Offline JDubU
« Reply #2101 on: January 07, 2014, 04:41:50 pm »
Ah yes!
Offline alank2
« Reply #2102 on: January 07, 2014, 04:42:52 pm »
Does anyone have a good description for how the hi resolution mode works?  The manual didn't really help me understand it.
Offline Carrington
« Reply #2103 on: January 07, 2014, 04:46:35 pm »
Please search on the forum, because it has already been discussed in detail.
My English can be pretty bad, so suggestions are welcome. ;)
Space Weather.
Lightning & Thunderstorms in Real Time.
Online PA0PBZ
« Reply #2104 on: January 07, 2014, 04:56:38 pm »
Ah yes!
Yes it is in hi res because the original from EV was also in hi res.
Offline Carrington
« Reply #2105 on: January 07, 2014, 04:59:01 pm »
Please can you repeat the same test for 1ns/div, but not in stop mode and/or hi res.
Thanks.
Space Weather.
Offline marmadTopic starter
  • Country: aq
    • DaysAlive
« Reply #2106 on: January 07, 2014, 06:14:41 pm »
At those time bases in HighRes, the DSO is just doing sin(x)/x interpolation and filling in the display memory with points instead of vectors. It does absolutely nothing that Normal mode and sin(x)/x don't do - except display the trace dotted.
  • Country: aq
    • DaysAlive
« Reply #2107 on: January 07, 2014, 06:31:03 pm »
Bandwidth DS2302 HW 2, signal generator on 1 volt, 10 Mhz steps:
Sorry, but I'm not sure I buy this BW chart.
If the filter is really only ~-5.5dB down at 500MHz, I believe the DSO will run into problems with sin(x)/x interpolation - which is highly susceptible to errors if the original signal contains frequencies higher than the Nyquist frequency. With 2 channels turned on and a 1GSa/s rate, the Nyquist frequency is 500MHz.
According to previous BW charts posted, the original DS2202 was ~-16dB down at 500MHz. Having a slower roll-off and a higher passband is NOT a good thing if the rest of the hardware doesn't support it.
Online PA0PBZ
« Reply #2108 on: January 07, 2014, 06:35:15 pm »
Atttached Excel sheet with the measurements.
Online PA0PBZ
« Reply #2109 on: January 07, 2014, 06:40:39 pm »
Hmm, this is indeed a bit  :-BROKE
Just turning on the grounded channel 2 kills the channel 1 waveform:
  • Country: aq
    • DaysAlive
« Reply #2110 on: January 07, 2014, 06:42:17 pm »
Well, I believe you made measurements and a chart - but that doesn't mean it's accurate.  ;)   Hell, you had HighRes mode on - which is an averaging technique, and thus a filter - which would normally be the last thing you should do if trying to accurately measure bandwidth.
But, IMO, if your measurements ARE correct, I'd say Rigol made a mistake in redesigning their filter - and it makes me feel better about owning a HW v.1 ;D
Online PA0PBZ
« Reply #2111 on: January 07, 2014, 06:45:29 pm »
I just had hi res on for the other screenshots because I figured that EV had it on too (too many dots) in his original posting and I switched it off after taking the shots. Not sure what is going on, going to test my sig gen now  ;)
Offline EV
  • Aficionado
« Reply #2112 on: January 07, 2014, 06:48:36 pm »
I got explanation to this from TEK Forum:
"When at 400ns/div or faster horizontal time base, the sample rate is maxed at 2.5GS/s. To overcome the max sample rate, the instrument goes into real time interpolate mode and mathematically adds points depending upon the horizontal time/div setting. What you are seeing are the interpolated points, not actual samples."
My old TEK TDS3032 has 2.5 GS/s and 5 samples per division with 1 ns time base. It is so regardlss whether both or only one channel is on.
But that doesn't make sense mathematically. If 2.5GSa/s is the maximum rate, 400ps is the smallest sample period. That would be 2.5 samples per div @ 1ns. 5 samples per div would require a 5GSa/s rate (200ps sample).
  • Country: aq
    • DaysAlive
« Reply #2113 on: January 07, 2014, 06:52:26 pm »
Ok, sorry, my mistake. :)
Again, I have no problem if the -3dB BW is up around 350MHz - but the rolloff according to your chart is so slow I think problems could arise with signal reconstruction.
Compare it to the rolloffs in the two bandwidth charts posted on this page.
"...and mathematically adds points depending upon the horizontal time/div setting. What you are seeing are the interpolated points, not actual samples."
Which is basically what the Rigol is doing in HighRes mode below a certain time base.
« Last Edit: January 07, 2014, 06:59:35 pm by marmad »
Offline Carrington
« Reply #2114 on: January 07, 2014, 06:54:55 pm »
A few days ago someone mention something about a Tek oscilloscope that in dots mode showed more samples than should be.
It's not magic, are interpolated (maths).
https://www.eevblog.com/forum/testgear/sniffing-the-rigol%27s-internal-i2c-bus/msg355318/#msg355318
Space Weather.
Offline Carrington
« Reply #2115 on: January 07, 2014, 06:55:26 pm »
DS2072, DS2072 (HW2.0) and DS2072A have all different input stages.
Space Weather.
Offline Carrington
« Reply #2116 on: January 07, 2014, 06:58:05 pm »
And no idea why this happens:  :-//
@ PA0PBZ: Thanks.
« Last Edit: January 07, 2014, 07:08:01 pm by Carrington »
Space Weather.
  • Country: aq
    • DaysAlive
« Reply #2117 on: January 07, 2014, 06:58:22 pm »
Yes, clearly I know that. But if PA0PBZ's chart is accurate, IMO it indicates a poorly designed filter for the sampling hardware.
Offline JDubU
« Reply #2118 on: January 07, 2014, 07:03:23 pm »
What does it look like when switched to "Dots" mode?
Offline Carrington
« Reply #2119 on: January 07, 2014, 07:04:45 pm »
Well, who knows, it may be an error in the measurement.
Space Weather.
Offline Galaxyrise
« Reply #2120 on: January 07, 2014, 07:24:28 pm »
I'm unable to infer from that screenshot what is surprising to you.
I am but an egg
Offline Carrington
« Reply #2121 on: January 07, 2014, 07:45:15 pm »
Why do you think that there is nothing unusual?
« Last Edit: January 07, 2014, 07:47:24 pm by Carrington »
Space Weather.
Online PA0PBZ
« Reply #2122 on: January 07, 2014, 08:20:14 pm »
Dots mode is ok.
Offline EV
  • Aficionado
« Reply #2123 on: January 07, 2014, 08:38:13 pm »
There are too few sample points for Sin(x)/X interpolation.
Offline Teneyes
« Reply #2124 on: January 07, 2014, 08:42:15 pm »
Hi All
  To Help show how DS2000 makes vectors out of sample points. I have constructed waveform files that have a low number of sample points. The sample points are calculated perfect sin values. I have chosen repeating patterns. I show 6, 4 and 2.5  sample points per cycle and at 1GSa/s.  You can see how the DSO interpolates the sin in the vector displays
These are stopped displays,  In run mode the varying trigger scanning causes the sampling to collect a series of sample along the sin display and if not a sin wave(step function) the DSO will create a sin wave overshoot.
Note : At 2.5 samples/ cycle the frequency will be accurate but Vpp is NOT.
   AS EV says very few points
IiIiIiIiIi  --  curiosity killed the cat but, satisfaction brought it back
